Question about HEALTHRIDER R60 SoftStrider Treadmill
Key replacement magnet - HEALTHRIDER R60 SoftStrider Treadmill
My NordicTrack x9i will not recognize the magnetic safety key - it was working fine and now nothing? any ideas?
The magnetic read switch is faulty . You have to replace the reed switch.If you wish to get some details; check the site linked here. Pull up older posts
http://electro-medical.blogspot.com/
Nov 01, 2016 | NordicTrack Exercise & Fitness
I have an old kettler LCD 6K tradmill.The safety key has snapped in the machine.can it be replaced? the treadmill keeps stopping so wondered if this was a safety mechanism
A magnetic read switch is used as the safety switch in treadmill. And the key you use is magnet. First of all try to by a new key and the check. Sometimes the magnetic property can change after years of use and can lead to such problems that you are facing now.
Sep 27, 2016 | Kettler Exercise & Fitness
The magnet is missing from my key for the Proform 908cs treadmill where can I get a magnet to fit the key I ordered a key and this key did not come with a magnet
search fFITNESSREPAIRPARTS.COM for a key. Otherwise any "rare erath" strong magnet should be strong enough to set the sensor off.
Jan 04, 2013 | Exercise & Fitness
Cannot turn on proform 380 cs treadmill
1) test the outlet wall with a desklamp, if the lamp turn On THE circuit is o.k otherwise, the problem is fuse blown or c. breaker tripped, reset or replace fuse.
2) test the power cord for open or faulty. with VOM usin continuity
3) test the fuse y/o c.breaker inside of machine and reset or replace.
4) Turn on the machine if the machine keep the same simpton, test the key(magnet) the key is a magnet, test vs your magnet from seal magnet of your refrigerator for atraction or repulsion, if doesnot pass the test replace the magnet from some hardware like home depot.
and PROOF again, can be work. see the block,
Otherwise if the problem keep you must call some tech profesional, maybe you have Main switch open or defective and need replace, or power supply, capacitor, transformer, etc defective. or faulty.
God bless you
Sep 20, 2012 | Proform 380 CS Treadmill !
Nautilus t514 safe key issue
1_ reset the machine, disconnect the machine.
2) test the magnet, the key is magnet, test for attraction or repulsion with the magnet from your refrigerator, if do not pass the test replace the magnet.
3) replace and go and buy in homedepot for little price!
God bless you
Jul 18, 2012 | Nautilus T514 Treadmill
I have a sportcraft tx400 (model 04040) and i lost the key to it.
you can buy in www. fitnessrepairparts.com or www.treadmillspartszone.com or www.doctortreadmill.com
or you can buy small piece a magnet in any Hardware, since the key is small magnet.
God bless you
May 08, 2012 | Sportcraft Replacement Treadmill Round...
WOODWAY "replace magnetic key SAFETY"
Yes, it is likely that it is the switch directly underneath the magnet - it may be possible to bypass it, but not a good idea. You can order a switch direct from Woodway 1800WOODWAY
Mar 18, 2012 | Exercise & Fitness
Ive lost the magnetic key . Can the magnetic key be bypassed or what can I do
Sometimes they can be bypassed. If you have a thick refrigerator magnet, try passing that over they key area to see if that will unlock it. Thin business card style magnets are not strong enough. If that does not work, call the manufacturer for a replacement key, they are around $20 plus shipping.
Nov 07, 2010 | Health & Beauty
I have lost the safety key for my Weslo treadmill
Hi I folded up a piece of paper several times to make it into a small rectanguler shape and inserted into the slot for the key and it worked.
The replacement key doesn't need to be magnet just small enough to fit the shap of the slot is fine.Mine was a Weslo cadence 1000 (bought in 2002)
Jan 29, 2009 | Exercise & Fitness
HEALTHRIDER R60 SoftStrider Treadmill Logo
22 people viewed this question
Top HEALTHRIDER Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Techmotionusa.com
Techmotionusa.com
Matty Piilo
Matty Piilo
Are you a HEALTHRIDER Exercise and Fitnes Expert? Answer questions, earn points and help others
