Question about Philips Magnavox 20MT133S 20" TV
DSP7700P with no remote; no menu
Converter box has no remote, and no menu appears when unit connected. No coherent picture.
I operate my TV with the convertor box remote control, how can i get a brighter picture using the remote control?
Most converter boxes will not perform that function unless you have a menu on the screen.
Jan 28, 2015 | Televison & Video
I have a dsconverter 9550 with no remote. I can't get the scan wizard set up menu to show and of course no remove. How can I get the Scanwizard to appear from the converter with out the remote that was...
Hello mmorris926,
I would advise that you take the unit back to where you got it from and exchange it for one with a remote. What you can also do is if your box has a menu button on it press that and it will bring up the menu.
I hope this helps
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jun 18, 2009 | Philips Magnavox 20MT133S 20" TV
How do i program the control to the converter box!
Try these steps: 1. Turn on your TV and change it to channel 3 or 4. 2. Press the power button on your Insignia Remote control. The converter light will be turn on in stand by mode (the red light appears). Press the power button again, the blue light will be on. 3. On your Insignia remote control, press the menu button. 4. A menu items appear, navigate to the autoscan item to scan channel.
Jun 13, 2009 | Insignia Digital-to-Analog Converter for...
Insignia tv, universal remote, and.....
Follows steps below to program your Insignia Converter Box:
1. Turn on your TV using your TV remote control and change its channel to 3 or 4.
2. Turn on the convert box; the blue light on the converter box is on. If you press the power button again, the red light on the converter box will be on, but do Not turn it to Red!!! Your insignia's other buttons will not response if it in red light mode!!!
3. Then press the Menu button on the Insignia remote control. A wizard will appear. The wizard does not appear if your TV is not in channel 3 or 4.
4. Follow the wizard instructions to scan channels.
Remote to Insignia Digital converter box will not do anything but turn unit on/off, although the light does flash when buttons are push - nothing happens.
Well, try it two different ways, as follows: But be sure that the tv-channel that's selected for tuning will be identical to the "output-channel" which you'll then select for the Insignia converter-box. So, if you first select Channel 3 for tuning the tv set, then you must later select Channel 3 on the "Output Channel" choice for the Insignia "set-up" menu. Similarly, if you first select Channel 4 for tuning the tv set, then you must later select Channel 4 on the "Output Channel" choice for the Insignia "set-up" menu. Be consistent! If you find that the Insignia menu-screen does not subsequently appear after tuning the tv to Channel 3, then start-over with Channel 4 as your proper tv-tuned station to initiate the pop-up screen for the Insignia menu.
Now, here's an example that assumes Channel 3 is the proper tuning-station for your tv-set within your particular region: You will first tune your tv-set itself (by means of its handheld tv-remote) to Channel 3. Be sure, however that your Insignia converter-box is turned-on and properly connected to your tv-set and antenna.
On your tv's hand-held remote-controller, you should find a button that serves as its "input selector" -- with a typical descriptor such as "Input" or "Line" or "Video/Antenna." Press that button, and enter successive channel numbers until you get to Channel 3. You may need to press the digits 03 to signify Channel 3. The tv-screen may be colored bright blue at that point.
Then, as you switch to holding your Insignia remote-controller, press the "Menu" button. (Please note that you will need to press hard and firm upon the buttons of the Insignia hand-held in order to get proper responsiveness; a quick touch of the button will not be effective.) After pressing the "Menu" button, the Insignia menu should now appear on the tv-screen. Now, you need to use your Insignia hand-held remote-controller (not the tv hand-held remote-controller again) to travel through the menu-screen to the "Setup" feature. Then, select "Output Channel." Proceed to select Channel 3 -- which will then be printed for you next to the Output Channel feature. Finally, under the same Setup menu, go to "Auto Tuning" -- which will commence a complete scan of all available channels.
Remember, if tuning by Channel 3 is inappropriate for tv-tuning within your particular geographic region, then repeat the above process by substituting Channel 4.
When you are done, you will rely almost exclusively upon the Insignia hand-held remote controller. You do not especially need to use your tv hand-held remote-controller again.
However, be sure to avoid standing in front of your tv-set to change channels by buttons or knobs upon the tv-set itself. Tuning again upon the tv-set itself will negate your prior tv-setting for either Channel 3 or Channel 4 -- and thereby sabotage your working set-up!
I myself incurred chronic anxiety yesterday (June 13), as I was stunned that the Insignia menu-screen did not appear immediately when I pushed "menu" on the Insignia hand-held.
The only buttons that worked on the Insignia handheld remote-controller were the Power-on for the converter-box and the Power-on for the tv-set.
(continued next page)
Because my expectation had been this process would take just a few minutes, I was deeply frustrated and impatient. However, I recognized that my apprehension of impending loss was absolutely appropriate as emotional "signal-processing" for me personally -- in contrast to my formerly high expectation of immediate fulfillment, completion, and gratification. Instead of my intention for quick success, I faced the stunning dread that the Insignia box had become defective or that I'd fail to ever figure-out the problem. I would not have been so impatient if I hadn't expected immediate success for the set-up.
I rejected the slogan that "I just want to get this over with!" I rejected the option of stomping upon the Insignia box! Amidst my hour-long anxiety, I summoned "Courage" -- a mode of patience to accompany my internal "quivering." I did a Google search.
From this Fix-Ya web-site and other troubleshooting sites, I had strong clues that improperly setting Channel 3 or Channel 4 was a primary culprit for the failure of the Insignia's menu-screen to appear. When I finally succeeded, my anxiety dissipated quickly with a temporary relief. But then came the anger that the Insignia "User Guide" had not been clear to explain the process. From that aftermath of outrage, I decided to promptly compose this protocol to assist others who have been similarly tormented -- perhaps to the extent of incorrectly believing that the Insignia converter-box was a defective product requiring prompt replacement.
Jun 02, 2009 | Insignia Digital-to-Analog Converter for...
Trouble programming Universal Remote to a DTV Converter Box...
Not a complete solution, but, around the last page (pg. 14) of your converter box manual there are codes listed for universal remotes. I happen to have a Philips remote that is listed. My code to control my dtv box is 0354. It appears that they have all codes listed for all Radioshack model universal remotes. I would suggest getting a Radioshack remote for Your "Digital Stream" (Radioshack) dtv box...
Apr 21, 2009 | GE JASRM24912 Remote Control
We have an older tv with an indoor vhf/uhf antenna. We have hooked up the converter box according to directions and even watched a video showing how to hook it up. However, with the tc on channel 3 and...
Sounds like a connection problem, if coaxial connection was made and box is turned on, then something should show up on channel 3. If rca composite connection was made something should show up on video 1 or 2. Make sure box's power button is pushed to 'ON'.
Mar 24, 2009 | Insignia Digital-to-Analog Converter for...
Lost the Welcome/Installation Menu
http://www.ezdigitaltv.com/support-files/ns_dxa1_manual.pdf
All you have to do is use the auto tuning function. Your remote control has a menu button, you can get to the feature via the on-screen menu.
If you press the menu button while the box is on and you see no menu, change your television's input to match what the box's output is.
Nov 23, 2008 | Insignia Digital-to-Analog Converter for...
Problem programming Zenith Digital TV Converter DTT901 remote.
Be sure that your TV is set to channel 3 or 4 if you are using the RF cable or Video 1, etc if using the Audio/Video cable.  The Installation  Guide should appear.  The "improved" picture that you are seeing is simply the analog throughput, not the digital conversion.
Nov 21, 2008 | Zenith DBZN-311 Remote Control
Tv stuck on zoom
Hi
Thanks for using FixYa. Please check your cable box settings first. Sometimes the remotes have a picture size button on them, and the in-laws could have pressed that by accident. Check the TV settings, press Menu Button & then go to WINDOW/IMAGE SIZE. Now select normal size.
Also check the settings of the converter box (if you are using it). The boxes also have a peculiar problem: Unless users manually change settings from show to show, the picture from many stations either won’t fill the screen, or it will be so big that part of the picture is cut off by the edges of the screen. The solution is to press the “zoom” button on the remote that comes with the converter box. That will expand the picture so it fills the screen. If still the issue persists, then you’ll need to go to the service menu. To go to the service menu please start with the TV off and press mute > 1 > 8 > 2 > power the remote on. Now the TV will come on with the menu displayed and from there you can change the settings as required.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 27, 2008 | Televison & Video
Philips Magnavox 20MT133S 20" TV Logo
53 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
