I was having problems with a black line on the edge. I ran several clean cycles and got the line to disappear and now the colors have except for black have stopped working. HELP!
My Epson C88 won't print colors. I was having problems with a black line on the edge and run several cleanings. I got the black line to go away and now it won't print any colors.
  • crystal205 May 08, 2009
    How do these cleaners work? And do I have to order on line or can I get from an Office Supply store like Office Mas or Staples? I really need this working today ASAP!
  • 495 Answers
If you have carried out 4 to 5 head cleans, waited about 8 hours anddone another 3 or head cleans doing nozzle checks after each clean (asrecommended by the manual) and there is still no improvement then youwill need a third party head cleaning solution such as this one:
http://websites.uk-plc.net/UK_Inkjet_Cartridges_PLUS/products/Print_Head_Cleaner.htm
Other makes & brands are available just google "inkjet head cleaning solution" Hope this helps.
Posted on May 08, 2009
  • Manoj Rout
    Manoj Rout May 08, 2009
    Try in office stores. You should get it. If not then order it online.
Kodak esp-3 cannot purge air from print head
WE HAVE AKODAK ESP-3 ALL IN ONE.
RAN OUT OF BLACK INK. HAVE REPLACED BLACK CARTRIDGE 2 TIMES BUT CANNOT GET BLACK TO PRINT. WHAT SHOULD I DO NEXT???
Apr 23, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
White stripe in print-outs
This is a common problem with this printer. Each toner color has it's own roller. The tin blade on the inside edge of the roler gets plasticy buildup and needs to be cleaned.
Pull out the entire toner roller assembly for the color that is problmatic. Unscrew the tin blade from the roller assembly. Clean the inside edge of this blade (the part that scrapes on the roller) completely. NOTE: After cleaning mine with toilet paper & water I ran my fingernail along the edge to find that the waxy buildup was still there. I gently took my fingernail and scraped at it until it felt smooth -- no burrs.
NOTE: The edge of this blade is very sharp! Be careful. Don't run your finger along the edge.
Reinsall the tin plate maing sure that the foam sweeps (on the right and left of the blade) are not stuck under the tin blade. (If you do, it will dump large amounts of toner on your pages. Very messy).
Give her a whirl.
Apr 05, 2009 | Samsung CLP 300 Laser Printer
Printer won't print out test paper.
you may try this
1) do clean nozzle cycle (do more times) until print normal, refill enough ink., not fixed go next
2) clean the color ink cartridge nozzles, put the cartridge down the soft paper damped with solvent or water, do it again untill to see three different color inkgo out on the paper.
Feb 08, 2009 | HP PSC 1600 InkJet Printer
Very Faint Printouts
I find the best way to clean the heads is buy some cleaning cartridges as they have cleaning fluid in them and use them to clean it will take about 10 or more times to clean the heads then put the color ones back in and try again.
Just keep putting it on clean the head don't do a print out till at lest you have cleaned 10 or more times.
Rgs
The StickMan
Dec 08, 2008 | Epson RX620 All-In-One InkJet Photo...
Brother MFC 5840-CN Black Ink Not Dispensing
No, they cannot be cleaned once you lose the color completely. You'll need to replace the head.
Sep 16, 2008 | Brother MFC-5840CN All-In-One InkJet...
Hi, I have an Epson Stylus 4000 printer at home. I had no problem printing high quality prints untill now. I thought that my nozzles were clogged (I haven't use it to print for a several months), so I...
print head clogged..if you remove it try cleaning it...or sink it in a boiled water to released clogged.....used tissue on cleaning...maybe its effective coz i repaired same printer you have...
Aug 27, 2008 | Office Equipment & Supplies
Black won't print
I have this same model printer and had this same problem. I solved it by running the cleaning cycle repeatedly (30 times or more). It nealy drained the black cartridge, but they're cheap compared to a new printer ($100 for the mfc240c that replaced it). Press the ink button to the left of the display. Select "test print" and "print quality from the menus, then hit print. After printing, the display will ask if quality is ok. Press 2 for no. It will ask if the black was ok, press 2 for no, if the color looks ok, then press 1 when it asks if color is ok, then press 1 when it asks to start cleaning. In a minute or so, it will beep and tell you to press start. Once the sheet prints again, repeat the same sequence. I didn't even wait for the display, I would just press 2,2,1,1, each time it printed. At first the black section was blank, the one dash appeared, then two or three. I gradually gained on it until I had most of them working again, then let it set overnight and ran a few more cycles the next day and it finally all started working.
Jun 22, 2008 | Brother MFC 210C All-In-One InkJet Printer
Print color not functioning correctly
Is there a printer calibration program on that printer?
You should run it an make sure the color distribution settings are correct.
Jun 14, 2008 | Brother MFC 4420C All-In-One InkJet...
MFC440CN PRINTING - ALL BLACK
I understand that the machine is printing only in BK. You have lost color.
If so, do run the cleaning cycles several times and run quality check test prints after each cycle.
There should be color again.
Otherwise the ph is defective!
Feb 11, 2008 | Brother MultiFunction Center MFC-440CN...
130 people viewed this question
k24674
