Question about Philips DVDR520H DVD Player/HDD
DVDR520H factory reset
Philips DVDR520H DVD Player will not recognise disc
Disc must be the right type (+R) . Not faulty, and have nothing on it if it is a use once disc . If it does not work then after a reboot , the drive may be faulty .
Aug 18, 2012 | Philips DVDR520H DVD Player/HDD
Hi I am trying to copy a video to dvd on this recorder What dvd disc do i use as after recording says this disc cannot play- would appreciate the exact direction how to do this Tks
The DVD-burner inside the DVDR520H is a very cheap LiteOn-burner (model: DDW451S). It would be better to replace the burner, but it would be difficult to find a product which will fit in the limited space. I'm having troubles with burning DVD's since I had bought this peace of ****. The machine have been repaired three times, but it is still not functioning properly. Shame on Philips for assembling such a weak product and their very bad support!
Sep 19, 2010 | Philips DVDR520H DVD Player/HDD
My philips dvdr520h dvd player does not recognise the DVD+R or +RW blank disc's
because there is no way to use that, if you look at the manual that dvd only rec DVD-R
Jun 04, 2009 | Philips DVDR520H DVD Player/HDD
Audio is out
Hi, try this:
Reset the whole machine by doing the following (this will not erase your HDD by the way):
1. Turn off at wall for 5 minutes
2. Turn back on at wall WHILE holding the standby/on button on the front until the front panel display goes black.  The recorder should then be left for a few minutes and then turn it on on remote, when the machine should prompt for language, time and date and work normally again!
Dec 31, 2008 | Philips DVDR520H DVD Player/HDD
No sound on scart 1 to tv . on model:DVDR5520H
seems your scart is not plugged in all the way -- ie U have a weak connection. try a new scart lead-my regards
Jun 25, 2008 | Philips DVDR520H DVD Player/HDD
Invlaid region code
Sounds like you are trying to play a DVD of a different region to that of the player.
Worldwide region codes, sumarised:
1 - US / Canada
2 - Europe
3 - Asia
4 - Australia
5 - Africa
6 - China
You can change the region code of the DVDR520H to any region or use region 0, which makes the unit multi-region to play DVDs from any region.
  1. Go into the main menu
  2. Highlight the exit button
  3. Type 2960
    This should give you access to a hidden menu form where you can change the region code.
Feb 20, 2008 | Philips DVDR520H DVD Player/HDD
System seems to have crashed
there is no way you can restore them consider the pictures lost you will have to delete them in order that your set wil function properly.
Mar 11, 2007 | Philips DVDR520H DVD Player/HDD
Rolling picture on Philips DVDR 520H
If you are using an American TV, then it's because your DVD player is set to PAL. Set the DVD player to NTSC and all should be good. peace. p.d.
Dec 31, 2006 | Philips DVDR520H DVD Player/HDD
Philips DVDR520H DVD Player/HDD Logo
26 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
