Question about Gigabyte GA-7VTXE Motherboard
Gigabyte GA-7vtxe+ Motherboard cannot boot up
I have a computer with the above motherboard.  the computer will not boot up.  The fan on the CPU spins for about a second then nothing.  There is a little light on the motherboard near the main power connector that lights up after the fan quits spinning or so.
I've already tried the video card, RAM, hard drive, etc.  Nothing.  The power supply is good as I've tried another with the same results.  Any Ideas?
I've read about capacitor problems.  the unit was built in 2001.
thanks
Mike
  • Anonymous Nov 20, 2007
    I have the same problem. The power comes up for a second and then nothing. The LED near the power connector comes on after the CPU fan stops. I noticed 4 leaking capacitors on the motherboard. After replacing the capacitors, the power came on but the power supply fried. After replacing the damaged power supply the system powers up but after about 8 beeps from the POST I powered it down. Will continue to troubleshoot, but a new MB may be in my future.
    Pug
  • 101 Answers
Sounds like the motherboard died.
Posted on Oct 11, 2007
SOURCE:
Wiring diagram for ga-7vtxe motherboard
Hello you can download the manual here:
http://www.gigabyte.com/products/product-page.aspx?pid=1310#manual
You will need adobe reader to read the content.
The drivers can be downloaded here:
http://www.gigabyte.com/products/product-page.aspx?pid=1310#driver
But first select your windows system.
Good luck
Jan 10, 2013 | Gigabyte GA-7VTXE Motherboard
GA-7VTXE BIOS update
MAKE YOU SELF 100% SURE THAT IT IS THE RIGHT MODEL.
You can get the software here:
http://www.gigabyte.lv/products/page/mb/ga-7vtxe/download/bios
Or use this upgrade utility:
http://www.gigabyte.lv/products/page/mb/ga-7vtxe/download/utility
If you are not sure you can download and install a small program here:
http://www.cpuid.com/softwares/cpu-z.html
You may have to use a unzip program like win rar or 7 zip.
I wish you the best luck.
Feb 23, 2011 | Computers & Internet
New system biuild won't boot to bios. Gigabyte GA-Ep45-UD3L Rev 1.0, Zalman CNPS9500, Intel Q8400, G.Skill 1066 2X2GB Memory, Radeon HD 4650 Graphics card,Antec Sonata III case w/ Earthwatts 500W PS. When...
ok well make sure you have the right ram look in the manual and see if it needs to be non error correcting or error correcting (non ecc or ecc) and if it needs to be registerd or unregisterd ram (AKA: bufferd and unbufferd Ram) dont run it very long with no CPU FAN or it will burn and check that fan by pluging it in someware els thats strange cpu fan is always running when mobo is on.
Feb 24, 2010 | Intel Motherboard
I have a problem with my board Gigabyte GA-G31M-ES2L, encounter no display & no beeps even though I remove the RAM in the board please help me to solve this problem?
Do the fans still start spinning ? And did you do a CMOS clear ?
You should also try booting it without a graphics card and/or any other audio/network card, etc, so you only have the CPU and motherboard (and also try it with 1 RAM bank and without). When it beeps, it's probably alright (implicating other failing hardware).
When you hear no beeps at all (but the fans spin), it's pretty likely that the board is gone. You might want to doublecheck the powersupply and CPU nevertheless.
Aug 18, 2009 | Gigabyte GA-G31M-ES2L Motherboard
Wont boot
i think the cpu may have a problem with the board or the memeory. either its bad, damaged or incompartible with your system. try out another cpu
Mar 24, 2009 | Gigabyte GA-K8VT800 Motherboard
No display by gigabyte GA8i915me motherboard
It sounds like your CPU might be overgeating. Check the CPU heatsink fan to see if it is spinning. Also, make sure that you clean out any dust, as this can lead to overheating also.
Jan 23, 2009 | Gigabyte GA-8I915ME-G Motherboard
GA-7VRX Motherboard won't boot
Hi sebaswis, am I correct that this Gigabyte GA-7VRX is a replacement MB? (I read your other posted questions). http://www.fixya.com/support/t1399506-computer_boot_when_power You mentioned you put your old system back together & it worked fine. If mother board is shorted to the system case you will see the CPU fan spin for a second. Most motherboards use a green led which represents there is stand-by power running to the board.(This is normal). I am unsure why your led is orange. (Its not mentioned in your manual & manual does not show the led?s location). Was the other GA-7VRX MB led always orange or was it also green? Suggest you disassemble the heat-sink from the CPU. You mentioned you installed a new XP 2500+ CPU. If a pin on the CPU was bent during installation of CPU into the socket or if no thermal grease was applied or too little to the top of CPU, either would give you: CPU fan spins for a second & nothing else seems to run. Look over the link provided below. It is a guide to how to install a motherboard. (You may not need this but Its worth going over all the steps). http://www.hardwaresecrets.com/article/145 As far as the power supply. If the MB's are the same (GA-7VRX) & the old system ran with 220W, the newer one should also function. Clarify these questions for me sebaswis. Mike
Dec 18, 2008 | Gigabyte GA-7VRX Motherboard
GA-7VTXE
According to what I have read the Intel SSE support was added to that board.
Jan 27, 2008 | Gigabyte GA-7VTXE Motherboard
Open Questions:
See all Gigabyte GA-7VTXE Motherboard Questions
Gigabyte GA-7VTXE Motherboard Logo
220 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
Ekse
Thomas F. Schneider
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
