Question about Western Digital Caviar SE WD1600AAJS 160 GB SATA Hard Drive
Could this hard drive have failed plain due to long period of disuse?
Hi, I have a Western Digital 160GB hard drive. I bought it last year in July but only started using it this month. However, it sometimes stops in the middle of the system uptime and recently it just stopped working altogether. I put it back on the computer today after about two weeks and it started running again. I think it has suffered a mechanical failure because I heard it make some clicking sounds a few times during system startup. I feel this might have happened because the read heads might have got stuck since this drive was in disuse for almost a year. I need to know if it is a possibility that this drive could have got bad due to a long period of disuse.
  • unitedroad May 12, 2009
    I didn't remove the circuit board but a large part of it is already visible. I didn't see any visible dark spots on it but the circuit wiring seems to have got very brown especially where its thicker.
    Could that mean its circuit board may have got damaged?
    Also, sometimes at the boot time, the hard drive spins up and then spins up again, like its unable to kick itself into the action.
    I have Linux on another hard disk and it tries to initialise the drive in question from the faster to the slowest UDMA modes and then the PIO modes.
    Does this happen due to a burnt out circuit?
  • unitedroad May 18, 2009
    Hi Chris,
    I have an amatuer radio but I have lost its power adapter so I couldn't test the drive. However, since this drive is under warranty and I didn't have any important data on this drive, I am sending it for warranty repair/replacement. Thanks alot for your help and suggestion. You helped me through and improved my knowledge about hard drives alot.
    Regards,
    Dhruv
  • 696 Answers
Generally drives can be left sitting for a year or more without problems but if it was bumped or jarred hard enough the heads may not be releasing from the park position, otherwise clicking sounds usually mean problems with the circuit board. If you give it a visual inspection(requires removal with a torques 5 or torques 8 bit) you can look for any signs of a burnt out circuit.
Respond back on this post if you have any further questions.
Chris
Posted on May 08, 2009
  • Chris
    Chris May 12, 2009
    Hello again,
    Thanks for the extra info. The brown areas could be due to overly hot tooling in manufacture or due to overheating which could result in damaged circuits.
    Thanks for the info on the linux boot, generally if it is having cicuit troubles one of the lower speed methods might overcome that, but if it has worked it's way down without success then it's likely that in combo with the browning the circuit board is damaged.
    The repeated spinups are likely a sign of it getting power but not getting a good read, which could be any of a dozen circuits. If you own a short wave radio, like a baby monitor or older 900Mhz portable phone, try powering the reciever on next to the drive while it spins up. If you get a great deal of interference coming through the speaker you may have a blown voice coil(drives the HDD heads, resembles the coil in a speaker).
    If this is the case it will likely need to be sent to a clean room for recovery(if it's worth the expense). If not it's likely just something in the circuit board. This can be replaced easily enough.
    If it passes the radio interference test let me know as I have a few WD 160GB drives stockpiled for this very occassion. I normally use them for paying data recovery clients and would be happy to help you repair the drive or if you're so inclined and if they are matching circuit boards will happily sell you the appropriate one.
    Chris
Western Digital Crackling noise
This hard drive maybe still under warranty, I recommend you get a replacement and back up your data before the hard drive fails completely.
Jul 11, 2012 | Western Digital My Book Essential 2 TB USB...
Hi i have a western digital wd1600 160gb hard drive last year i used the hirens boot disc to completely wipe my hard drive and repartition the drive but now when i try to use my western digital tools for...
Have you tried setting the jumpers on the new drive to CS (cable select) If you use that setting, the position of the drive on the cable determines whether it is master or slave. For example, the plug at theend of the IDE cable is the master and the plug in the middle of the cable would be slave. Just a suggestion. If you are using SATA, this does not apply.
Jul 18, 2010 | Western Digital Caviar WD1600 (1600YD) 160...
Hi there, the red light on my ps3 is blinking and it wont take disc either. So what is the problem with it? thanks!
The Red light is due to the HDD (hard drive). There is one of 2 problems: 1. The connection is loose or 2. The HDD is just bad. This was an issue that has been discussed over in the Playstation forums and it seems that re-seating (removing & reinstalling) the HDD has solved the problem for many but some people have just received bad hard drives period. If you reinstall the HDD & it still beeps 3 times & gives you the red light, then you will have to replace your HDD. If I remember correctly, PS3s use Hitachi Laptop Drives. IMO, Hitachi is not well known for good drives. I replaced mine with a 160GB Western Digital drive I got for free a few months ago. I haven't had any problems since. Hitachi makes a good drive, but the ones that fail seem to fail really bad. Western Digital seems to make the best drives and
Apr 15, 2010 | Sony Playstation 3 (PS3) Console
Solid red light unit wont play
The Red light is due to the HDD (hard drive). There is one of 2 problems: 1. The connection is loose or 2. The HDD is just bad. This was an issue that has been discussed over in the Playstation forums and it seems that re-seating (removing & reinstalling) the HDD has solved the problem for many but some people have just received bad hard drives period. If you reinstall the HDD & it still beeps 3 times & gives you the red light, then you will have to replace your HDD. If I remember correctly, PS3s use Hitachi Laptop Drives. IMO, Hitachi is not well known for good drives. I replaced mine with a 160GB Western Digital drive I got for free a few months ago. I haven't had any problems since. Hitachi makes a good drive, but the ones that fail seem to fail really bad. Western Digital seems to make the best drives and they offer a very good warranty service as well.
Apr 10, 2010 | Sony Playstation 3 (PS3) Console
Blinking light, clicking sound?
Hard disks clicking is not a good thing. Did you drop it?
Open the case and check connections.
If you can, install it as a slave drive on another machine and attempt to recover data from there.
Afterwards check the drive for errors, reformat and delete partitions. If it is damaged then parts of it could be used as storage, but I'd advise against using it as a bootable disk and as a storage location for precious data.
Failing this, there are specialists who can recover data from corrupted drives. You'd have to speak to them about it.
Hope this helps
Wheal :)
Mar 01, 2010 | Computers & Internet
I purchased this product the 160 gb external harddrive for western digital for 60.00 on sale.. and the company told me my 1 year warranty was expired after i only had the product for 2 months.. and then...
trial versions are free for 1 month
you bought the unit at a sale so if the trial version was installed , the free period is well over so you have to pay or uninstall
next point warranty is from day of sale . not day of manufacture so discuss that with the shop because for them to deny warranty full period means that it is not new but second hand and all you got was the remainder of the warranty period
In other words , you have been had
you can get brand new 1T hard drives for less than $90.00
Nov 02, 2017 | Western Digital 160GB MyBook Essential...
Drivelock hdd bay password
Hi
This drive may have been used before and may have had a password set on it. If it is new take it back and exchange it
Cheers
David
Jun 21, 2009 | Western Digital Scorpio 160GB Internal...
Need help to locate Western Digital Passport 160GB External Drive
Could be a hard drive logic board issue since the computer bios recognizes the drive but the computer operating system does not. Not good.
Jun 25, 2017 | Western Digital Passport 160GB External...
Western Digital Caviar  SE WD1600AAJS 160 GB SATA Hard Drive Logo
326 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
