Question about Brandt WTC0815F Top Load Washer
No instructions! Hi, I have a Brandt Malice washer dryer in my boat with no instructions, can you help?? Many thanks
  • Anonymous Mar 18, 2014
    instructions booklet
I have the same problem.
did you find one?
thor@millennium-lifestyle.no
regards from thor
Posted on Jan 25, 2010
Hi guys! Please help me. I used the Brandt Malice top loader with a horizontal drum. I don't think the doors on the drum were clipped closed properly and now when I open the machine the drum is not facing...
Hello!
That's a nasty situatiuon... Most probably the door is opened and stuck in the heating element. The easyest way is to plug off, drain out the water, take off the right side panel, identify the heating element (it's hold in place with an 8mm screw and has a 3 thicker wire and a connector with 2 thin wires (from heat sensor) remove them, ) loosen the screw, but don't unscrew it completelly. Push the bolt in ant try to pull out the heating element. Once the heating element is out you can rotate manually the drum to the upward position (it won't be easy). It is very possible, that the driving belt to be worn out or to be broken too, ususally it does this when drum is blocked, so most probably you will need to order a new one.
P.S - if all abowe is too complicated, then better call a tehnician!
Sep 19, 2017 | Brandt Washing Machines
How to operate top loader brandt malice AA washing machine
Hi guys! Please help me. I used the Brandt Malice top loader with a horizontal drum. I don't think the doors on the drum were clipped closed properly and now when I open the machine the drum is not facing up so I can't open it? It also won't spin. What do I do? There is clothes in there and the machine is off, but the drum seems stuck? Please help!
Sep 29, 2013 | Brandt WFH1176 Front Load Washer
Instructions for washer / dryer
I'm so sorry but this forum does not, nor is in a position to, supply any type of manual (service or otherwise), parts list, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
Also members on Fixya are not 'affiliated' to, or representative of, any manufacturer at all, just using their experience gained probably over many years
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Sep 21, 2011 | Brandt Washing Machines
Hi - I have won a Brandt digital photo frame and radio in a raffle but unfortuantley, it has no instructions - can you help ?
Sorry- not from the WASHING MACHINE forum ;-0(
You will need to type into your search engine/web browser 'brandt digital photo frame' and you MAY be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
John C.
Aug 15, 2011 | Brandt Washing Machines
I have just moved into a flat with a Brandt washer dryer and i have no idea how to use it is there an instruction manual I can access its a built in unit and the only model indication on the front is that...
Sorry but to obtain a manual from anywhere will require the model number of course ;-0(
Have a look inside the door around the opening- details are often on a label there for exactly the reason you have!
Manual
John C.
Jul 18, 2011 | Brandt Washing Machines
Dear sir, we bought some time ago one brandt washing machine model no WFU0811K, which has also drying system. soon after we made a removal to another house and we lost the book of the instructions. now we...
I have found some website that could help. What I done take your model number of your washer machine and do a Google search, and type in instruction manual.
May 05, 2011 | Brandt Washing Machines
Problem with Brandt WBD1211 Washer/Dryer program 2
COULD BE A PROBLEM WITH THE HEATING ELEMENT IN THE MACHINE WOULD NEED MORE INFORMATION
Jan 07, 2010 | Washing Machines
Brandt WTC0815F Top Load Washer Logo
1,065 people viewed this question
Top Brandt Washing Machines Experts
Gerry Harvey
Gerry Harvey
john mabry
Are you a Brandt Washing Machine Expert? Answer questions, earn points and help others
