Question about Sony Bravia XBR KDL-40XBR6 40-Inch 1080p 120Hz LCD HDTV
Kdl-40xbr6 won't turn on stanby blinks 3 times
I just connected the main board A1727318A to Sony tv KDL-32XBR9
How many blinks do you have?
Main Power 2 Times (PS Board, G2CE Board)
DC Alert 3 Times (BM3 Board, G2CE Board)
T-Con 4 Times (T-CON Board)
HDMI 5 Times (BM3 Board)
Backlights 6 Times (Inverter Board)
Temp 7 Times (BM# Board)
HFR Error 8 Times (LCD Panel)
I hope that it will help you.
Apr 02, 2015 | Sony Televison & Video
Sony KDL-32S3000 BLINKS 5 TIMES STUCK STANDBY MODE
Remove all speaker wires and try again. If it unlocks one or more speakers are bad. If not service required for amp. Good luck.
Apr 16, 2014 | Sony Bravia S-series Kdl-32s3000 32-inch...
SONY KDL-40XBR6 12 BLINKS (I HAVE NO IMAGE, BUT SOUND)
I would be more inclined to check the power supply board first. Check the outputs to make sure the voltage is correct getting to the inverter. You should be able to pull up specs online if the expected voltages are not already printed on the board itself.
Apr 01, 2014 | Sony Bravia XBR KDL-40XBR6 40-Inch 1080p...
KDL-52w4100 won't turn on and LED blinks 6 times
Bus clock and/or data lines low at power on. 6 blinks of standby light denotes this. Actually, it should be a motherboard problem. Your TV need a thorough checkup before confirmation. If you wish to get more details about the blinking codes to Sony TVs, check this link.
Feb 19, 2013 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
No power 2 stanby blink light
It could be a power board problem. Why don't you please refer it to a qualified service technician?
Jul 30, 2012 | Son KDL-40EX600 40" LCD Edgelit LED HDTV
Sony kdl-46w5100 shuts itself off then goes to stanby flashing 10 times
I have the same tv with the same problem, replace the power supply boards and still had same problem, called in a tv repair man and I was told I have a main board problem bu board Watch Dog Timer used to track micro processors, led flashing 10 times cost around $425 parts and service call
Feb 24, 2012 | Sony KDL Televison & Video
Stanby light blinks 9 times after powering on but no picture
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections.
Hope that helps.
Jan 17, 2011 | Sony KDL-46XBR2 Television
The inside of my sony KDL-40XBR6 screen is crack, the outside is fine, no pictures on screen when turned on. How much does it usually cost to repair it?
first you should pin point on the actual parts you will need in order for some one to provide you with a fair estimate
Mar 29, 2010 | Televison & Video
Sony Bravia XBR KDL-40XBR6 40-Inch 1080p 120Hz LCD HDTV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
