Question about Garden
Homelite csp 3316
Fuel oil ratio
  • 97 Answers
SOURCE: what is th petrol and oil ratio for a homelite petrol chainsaw
Generally you're looking at a 50:1 ratio on most chainsaws and I wouldn't see any reason the homelite should be any different. Usually it's one 2.5oz container of the oil mixture to one gallon of gasoline but check the label to be sure.
Posted on Jul 30, 2009
dontbother10
  • 2220 Answers
SOURCE: would you belive all i am after is the ratio of
Good answer Rick
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
Lou
Posted on Jan 15, 2010
SOURCE: Homelite CSP 3314 Chainsaw
starts no prob will not rev , just stalls when you try
Posted on Feb 14, 2010
  • 14 Answers
SOURCE: What is the proper oil to gas ratio for a Homelite...
Most of the old Homelites were 32:1. I eliminated the mix problem for all my equipment when I started using a synthetic 2-cycle oil called OPTI-2. Somehow it works for all 2-cycle saws/trimmers/blowers etc. I've got equipment that's 20+ years old and still running strong with the OPTI-2.
Posted on May 20, 2010
SOURCE: I am looking for a homelite super 2 service manual
I have that saw. The manual states if you are using Homelite 2 -cycle oil read and follow the instructions on the package. If you use other than Homelite oil use 16 parts gasoline to 1 part 2- cycle oil, 1 gal / 8oz
Posted on May 26, 2010
On the homelite DM 50 model 05020 what is the fuel mixture ratio?
What Fuel Mixture Do I Use for a Homelite Chainsaw Model ...
homeguides.sfgate.com > Foreclosures > Avoid Foreclosure
It has a two-stroke engine similar to newer models made by Homelite. The recommended fuel mixture is a 50-to-1 ratio of unleaded gasoline and two-cycle ...
Oct 25, 2015 | Homelite Garden
Homelite chain saw csp 3314 will start if i tip petrol in spark plug home but wont stay running
There could be a problem with either the fuel line going to the carb or the impulse line that's connected from the cylinder base that generates the 'pulsing' action that operates the diaphragm fuel pump. Today's alcohol rich gasoline has a tendency to weaken or even rot the rubber lines causing fuel delivery issues.
If you don't use your saw for extended periods, dump the tank empty then start the engine and run the residual gasoline from the line. This will help extend the life of the fuel lines.
Another possibility could be a blocked fuel filter, but that is remote.
Feb 22, 2015 | Homelite 12" Oregon Chain Saw Repl. Chain...
I brought a brand new homelite 33c-csp 3314 and my wife threw the manual out or i lost it ,how much chain and bar oil do you put in the oil part? i cant open pdfs cause somethings wrong with that thank...
Hi, basically you fill it up every time you fill up with two stroke fuel as it uses about 3/4 of a tank of bar oil to a tank of fuel. Regards Phil.
Aug 11, 2011 | Homelite Garden
Need gas/oil mix for Homelite 330 10604A, HJ
To the best of my recollection the 330 is an older model saw and should be running about a 16:1 ratio. 8oz. of oil to 1 gallon of fuel. Hope this helps.
Note: You're always better being a bit richer (lower ratio) than you are leaner (higher ratio).
Feb 20, 2011 | Homelite Gas, 20 In. Bar, 46 CC, Chain...
What fuel does the csp 3314 use? I bought this chainsaw second hand and i am unsure what fuel to put in it. Thanks in advance for any assistance Kelly
You need to mix 3.2 oz of 2 cycle oil to 1 gallon of gas. Some may disagree but a 40:1 ratio is better than a 50:1 mix. It gives more oil in the mix to keep the cylinder/piston lubricated. Any less and you will burn up the engine. With this new mixture you may need to get a professional to readjust the carburetor to this new mix.
Sep 25, 2009 | Homelite Garden
What is th petrol and oil ratio for a homelite petrol chainsaw 33c- csp 3314
Jul 30, 2009 | Homelite Garden
What is the oil-gas mix for a homelite superxl chainsaw? For 1 gal.
16:1 ratio for most 2-stroke oil brands. A service manual recommends tro check the ratio marked on the bottle if using Homelite brand 2-stroke oil. For other oils, 16 parts of gas to 1 part of oil.
For 1 gal of fuel, that is 270cc of oil required to meet the 16:1 ratio.
Please rate this solution on FixYa!
Jul 16, 2009 | Homelite Garden
Feb 11, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
