Question about Kodak Dock Series 3 Laser Photo Printer
Paper will not feed
The paper will lift when asked to do so but it will not stay up to feed into the printer
  • 1 more comment
  • Anonymous Dec 07, 2007
    paper will not feed into kodak easyshare printer
  • Anonymous Dec 13, 2007
    paper will not feed
  • Anonymous May 18, 2008
    I have the same problem with my series 3 plus printer dock the paper will lift up but not feed into the printer
The link above solved my problem. So simple, all I did was wet a wash cloth and carefully clean the upper roller. I let it try and everything worked like it used to.
Posted on Aug 16, 2008
SOURCE:
How do I get rid of paper jam that stays on even if nothing jammed
My guess is that there is a piece of paper somewhere blocking a light beam or in a contact switch.
Try a little air if you can't manually feed a sheet of paper. Use the heaviest bond you have.
Jan 06, 2015 | Canon Office Equipment & Supplies
Check printer E-02-01 error
Your paper tray 1 paper lift motor is broken. You can still make copies from the bypass feed on the side. Switch machine of, open tray 1 slightly and load paper into bypass feed on the side of the machine. Remember to select the bypass as paper source by using the buttons under the screen or the properties of the printer driver. This is only a temporary solution, and you should contact your service centre for a replacement of the paper lift motor
Oct 01, 2013 | Panasonic WORKiO DP-8016 Printer
Bizhub C300 error C8103
To improve paper-feeding in the paper take-up section of the document feeder some adjustments have been newly made. Please ask a technician for this updates, but the error code suggest binding in the lift motor (may need to be replaced) or the lift plate is not producing enough pressure.
Jan 15, 2011 | Konica Minolta Bizhub C300 All-In-One...
My brand new hp laser 1005 says out of paper and wont feed any of the paper through?
HP LASERJET P1005
PROBLEM: it was out of paper, new paper was installed, but printer wouldn't feed or print
SOLUTION: Lift the top cover of the LaserJet (where the printed paper would come out) and close it again. This resets the printer. Now the printer should feed and print again.
Jan 11, 2011 | HP Hewlett Packard LaserJet P1005 Printer
Feeding paper: how to fix the automatic feeding from the tray? I think the printer won't pick up the paper from the tray. we always have to manually feed the paper. How to fix it?
Pull out a paper cassette, lift up the printer and under you see paper feed roller (it is rubber), just clean roller with cloth and water or alcohol
Dec 13, 2010 | Xerox DocuPrint 203A Laser Printer
Kodak PD6000 Printer Dock will not lift and feed paper from paper tray
Greetings,
Here's the link for your products Troubleshooting Guide
Keep us posted and thank you for using our service.
FixYa - Technical Support, Instructions & Repair Service
Jul 30, 2008 | Office Equipment & Supplies
Paper feed
Feed roller is dirty or worn thin, wipe rubber roller with damp cloth.
Nov 03, 2007 | Kodak EASYSHARE Printer Dock Thermal Photo
Paper feeder
usaully yuo need to bring your computer to a repair shop to replace the spring on the riser
Oct 27, 2007 | HP DeskJet 5550 InkJet Printer
Kodak Dock Series 3 Laser Photo Printer Logo
74 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Clive
Clive
Ekse
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
