Question about Avaya 700340193 Corded Phone
Ghost extention answering calls
An extention that does not exist blinks about every 5 seconds, taking while one of the line lights blinks at the same time. it has been picking up calls and hanging up on them...
What extension number is it? Unplug it from the phone system.
Posted on Dec 21, 2007
How do I fix vertical lines and no picture.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Line, faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 20, 2015 | Vizio E320VP 32" LCD TV
Do ghosts exist
Some people agree that Ghost really exists but some of them do not believe them. Most of the people say that all this thing is just a myth.
But you can't ignore the sayings & seeings of the old people, who claim to have seen the ghosts or being with them.There are many television shows that show the real story of ghost angel. To learn real kabbalah or truth of ghost you see the website mention abov
Jun 24, 2014 | Computers & Internet
My problem description: when i turn the ignition key on the FI led is lit for 3 seconds and goes off (normal) then 2 seconds later it blinks 5 times go off and do not blink again, I must...
Hi, Nickey_star this is above my pay grade so for this situation, I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your problem. Good luck and have a wonderful day.
Apr 21, 2017 | Hyosung Motorcycles
I have an Acer AL1912 that when you plug in the ac, the green power light will blink for about a minute and a half then go solid. The backlight will come on and you can see a faint ghost of vertical lines...
If it is still in warranty call the manufacturer.
if not give more info May be somthing simple like a cable
shutdown computer unplug then disconnect the video cable on the computer from the monitor, plug monitor back in and turn it on, there should be a display that says no video source within a few seconds, if unit is working properly. shutdown and connect video again and then reboot computer. sometimes it just takes a compleat power disconect to reset things,
Jan 30, 2010 | Acer AL1912B 19" LCD Monitor
Blue and yellow convergence? problem...power light blinks 6 times
This is a common problem. Its called a convergence failure. You can get all the parts from
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
You can see some examples and find a fix here...
Jan 28, 2010 | Sony KP-51WS510 51" Rear Projection...
How do I set phone to ring at my extention?
Partner, all releases.
Receptionist Call Routing. If you want calls to be answered by the receptionist first, set the lines at the receptionist’s extension to Immediate Ring and the lines at the users’ extensions to No Ring. (This is the factory setting)
Receptionist Backup. If you want all calls on a line to ring directly at users’ extensions -with the receptionist providing backup -set the line at the users’ extensions to Immediate Ring. Then set the line (or lines) at the receptionist’s extension to Delayed Ring. An incoming call that is not answered by a user within 20 seconds will also ring at the receptionist’s extension.
To change the way outside lines or pools ring at an extension:
  1. Press [ Feature ] [ 0 ] [ 0 ] [ System Program ] [ System Program ] [ Central Tel Program ].
  2. Enter the number of the extension to be programmed for Line Ringing. The green lights next to the line or pool buttons on the phone show the current Line Ringing settings for all lines assigned to the extension. (If a line is not assigned to a button, the green light next to the button is off.) The following ringing options can be shown by the green light next to the line button.
    • Immediate Ring - on steady
    • Delayed Ring - flashes slowly
    • No Ring - flutters quickly
  3. To change Line Ringing for any line, press the line or pool button until the button light shows the correct setting (the setting for the currently selected line or pool also appears on the display).
  4. Continue programming or exit programming mode.
Dec 01, 2009 | AT&T Lucent MLS-12D Phone
On the gage cluster what does F1 or FI mean
The Fl lamp lights up when the computer finds a malfunction in the programmed Fuel Injection. There are 33 different codes. The offending code is denoted by how many times the Fl light blinks.
Nine of the 33 codes do not show symptoms since the engine still runs okay. If the Fl light just stays on then the engine will not run because the computer will not let it run, (except in two cases).
"MIL" translates as "Malfunction Indicator Lamp ".
This is what the service manual says:
" The PGM-Fl MIL denotes the failure codes ( the number of blinks from 0 to 33 ). When the indicator lights for 1.3 seconds it is equivalent to 10 blinks. For example, a 1.3 second illumination and two blinks ( 0.5 second X 2 ) of the indicator equals 12 blinks. Follow code 12 on page 5-26.
When more than one failure occurs, the MIL shows the blinks in order of the lowest number to the highest number. For example, if the indicator blinks once, then two times, two failures have occurred. Follow codes 1 and 2 on page 5-12."
BOTTOM LINE > A blinking light that can't be understood, combined with instructions that can't be understood make the entire Honda "malfunction alert system" totally worthless and a pain in the neck to the owner. Why can't someone in Japan write a computer program that would render something like " Code 23 error " instead of a blinking light that means nothing because it is not user friendly.
You asked what the FI light means. It means you are forced to take your bike in for service at a Honda shop and pay big bucks to the dealer for something you could have done yourself for $12.00. This is a built-in money maker for Honda dealers.
Please rate this answer. Thanks.
May 16, 2009 | 2001 Honda CBR 929 RR Fireblade
Problem with answering machine on Panasonic Model # KX-FPG376
i followed the advice posted & it worked fine after that. thanks.
Nov 22, 2008 | Panasonic KX-FPG376 Plain Paper Thermal...
How to cofigure epbx 303 incoming hunding ringing
This is Tahir ansari from indore, I have faced problem of epbx machine, problem is that, I have 15 extention in my epbx & 3 telephone line connected in my epbx, now all 15 extention are used by me but 3 telephone line are not running my extention why ?
Nov 16, 2008 | Lands Phones
Pick up handset to answer a call and NOT have to press a line
if your phone had set for ringging assignment, u no need to press any key to answer the call.
check the indicator light,
if green light turn on, u can direct answer the call
if red light turn on, u ned to press the line to answer the call
kindly ask the phone provider the set yr extention for incoming ring assignment
Nov 12, 2008 | Toshiba DKT-2020 Corded Phone
Avaya 700340193 Corded Phone Logo
173 people viewed this question
Top Avaya Lands Phones Experts
Oloyede Monsuru
Shehu Pro
Shehu Pro
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
