Question about Nikon D5100 Digital Camera
Error r27 appearing in viewfinder in iso box
Error in viewfinder r27
I keep getting the "wrong disc inserted error". I'm using windows 7 with virtual box, and I've made an .iso file of the actual install disc. I installed the game onto a virtual machine (running windows xp)...
OK, so most Discs have a key hardcoded into the actual disc. when you do an ISO of the disc, the game won't play.
these are anti-piracy tactics. Playing games off and ISO is ******* in most places.
Nov 14, 2017 | Global Star Software Army Men: Sarge's War...
Nikon d50 error code r27
r27 is not an error code. the camera is telling you that you can take 27 photos (app) before the camera's internal memory is full and it has to stop and write data to the SD card. This is a normal function of this camera.
If the camera will not fire, check to make sure that there is a SD card inserted. If not, set the camera menu so it will fire without a card. Also check to make sure there are no plastic bits from the broken lens jamming the shutter or mirror. Also, try pressing in the reset button on the bottom of the camera.
Feb 15, 2013 | Nikon D50 Digital Camera with 18-55mm Lens
Runtime error 429
You probably have a serious a virus infestation.
Download The following iso listed below. It is the latest version of the Kaspersky rescue disk. You need to burn it to a CD with a program like Imgburn (Which is also FREE like the iso file). Then you need to boot from the CD and run the scanner. It should fix you right up.
Kaspersky rescue cd download:
http://majorgeeks.com/downloadget.php?id=6501&file=1&evp=ef4247319d4b536cb88b74d1ae4842b0
Imgburn download:
http://majorgeeks.com/downloadget.php?id=4870&file=15&evp=0636b68877cb69b15faa3374cb1dcd89
Aug 18, 2012 | Dell Computers & Internet
Randomly, many of my photos are blurry.....
Looking at this camera manual I see that you can switch to PASM mode which I'm suggesting you use "P" Program. Also to get the best ( steadiest) photo's switch to the EFV (electronic viewfinder) there is a little swich just below and to the right of the viewfinder for switch from and too. it may have LCD/EFV on the switch A great idea for the very best photo to print is to use ISO 100 but this may prove difficult in some lighting situations try it and if you have some problems this can be changed to ISO 200 or higher but the higher the ISO number the grainier the pictures will become.
So a reap. Change to "P" program in the PASM mode. Switch to the EFV viewfinder, try ISO 100 but ISO 200 will work as well. What the big change is, is to use the Electronic viewfinder this brings the camera closer to your face and your arms are tucked into your body making it much more stable to hold. Happy New Year
Dec 31, 2010 | Kodak EasyShare Z740 Digital Camera
I have a sony cybershot dsc w55 with error e:91:01. i have pressed the reset button and initialised the camera numerous times. the error is removed but the camera will not take a picture in auto or p mode...
E:91:01 is an error code that indicates problem with flash unit circuit in camera.
Flash unit board will be replaced to resolve this problem and temporary fix is to set flash Off quickly, before error could appear after initializing camera, hope this info will help you.
Thanks.
Oct 18, 2010 | Sony Cyber-shot DSC-W110 Digital Camera
I can't open my windows xp in virtual box because of these errors VD: error VERR_PATH_NOT_FOUND opening image file 'C:PROGRA-1Sun|Virtual-1VBoxGuestAdditions.iso'(VERR_PATH_NOT_FOUND). Failed to open image...
try reinstalling it and if that doesnt work i maybe able to help you if reinstalling doesnt work, because it maybe that it didnt install all the files or some are corrupt or it could be the location you installed it to
Feb 17, 2010 | Computers & Internet
Iso error
What is your ISO set to? Why not try a camera reset...you can find that in the setup menu.
Aug 16, 2009 | Nikon D70s Digital Camera
Error coe 31094D-34-00000000
the error code it meens that you have a wrong image file size
try another iso, or download again the file
Oct 16, 2008 | Toshiba Satellite A135-S4527 Notebook
Will not take picture
Some digital SLR camera have a mirror lock and others have a viewfinder shutter In each case this will be a knob in the region of the viewfinder that turns. Check that this model has it and it has not be inadvertently turned. Then come back
May 21, 2007 | Nikon D70s Digital Camera
Viewfinder out of focus
Hello nikkid, E..:.. indication means that you should contact the nearest Sony Service. Possibble cause of this error can be the optical unit itself. Best regards, Arpad
Mar 13, 2007 | Sony Handycam DCR-HC30E Mini DV Digital...
Nikon D5100 Digital Camera Logo
93 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
