Question about Homelite Leaf Vac Attack
Leaf blower starts, won't rev up unless turn it upset down, what's wrong?
Starts but won't keep running unless turn upset down and then only runs for a short while.
chad7houston
  • 62 Answers
SOURCE: Homelite leaf blower bogs down.
I don't mean to over simplify this, but are you using fresh gas? Gas blowers are extremely ticky when it comes to gas. They like it SUPER fresh. And while the gas and oil mixture should be right, it can be off a little bit and still run. Try draining all of the gas out, and then filling up with fresh mix. This is ALWAYS my first step with gas blowers, and it fixes the problem 75% of the time. Also make sure your spark plug is clean. If you are not sure, a new plug couldn't hurt.
Hope this helps!!
chad
Posted on Oct 08, 2008
boscia
  • 163 Answers
SOURCE: mightylite 26 leaf blower
have you tried changing the air filter and spark plug?
Posted on Nov 29, 2008
  • 398 Answers
SOURCE: Homelite 26D leaf blower bogs down in Run position
check the air filter.
Posted on Mar 02, 2009
  • 574 Answers
SOURCE: 2-cycle blower starts up but wont run full power rpm
Have you tried choking it about half way and see if that helps? Does it do the same after it is warmed up?
Posted on Mar 11, 2010
  • 15 Answers
SOURCE: yard broom leaf blower will not stay running I
It seems that the carb is not getting fuel. It could be a cracked fuel line. The fuel priming bulb could also be cracked/dry rotted. Possibly the fuel pump in the carb is bad. The carb is rather intricate and not something anyone without training should try to repair. The overhaul kit will cost $15 to $20. I suggest you take the blower to a repair shop.
Posted on Apr 19, 2010
Testimonial: "Thanks will do"
I have a blower/vac made by McCulloch that won't start! I tore the carb apart & cleaned it! Got it started but w n rev up! Turned I&H screws all t w in & bk out now won't start! help!
McCulloch 2 cycle leaf blower vac - YouTube
? 3:40
https://www.youtube.com/watch?v=skwugvObHtU
Dec 1, 2013 - Uploaded by Alan Marshall
McCulloch 2 cycle leaf blower vac. ... Your brand new leaf blower won't start? Try this ... starting contest echo pb251 vsmcculloch leaf blower.
cold start of my mcculloch leaf blower. - YouTube
? 4:24
https://www.youtube.com/watch?v=MgfmIezh65c
Mar 13, 2010 - Uploaded by keepin'itcountry
cold start of my mcculloch leaf blower. ... Your brand new leaf blower won't start? ... starting contest echo pb251 vs mcculloch leaf blower.
McCulloch won t start Leaf Blowers Questions & Answers ...
www.fixya.com > Forum > Tags > won t start > Leaf Blowers
McCulloch leaf blowers won t start related questions and answers. Ask your McCulloch questions. Get free help from leaf blower experts.
Nov 07, 2015 | McCulloch Garden
Hello, I have an old small engine snow blower ariens at 824 that starts and runs for about 30 seconds then dies. I just replace the floater from metal to a plastic one because it keep overflowing gas by...
The bowl on the bottom does it have a step in it. If it does make sure the bowl is positioned so that the float can drop down all the way.
Nov 18, 2014 | Garden
How do i adjust the carb on an echo blower
Not sure what carb you have..You should be able to see a spring loaded air/gas adjustment screw on the carb..once running turn clockwise until motor starts bogging down then the other way until it does the same..keep adjusting back and forth unti it runs smooth..
you may have another on the bottom of the carb bowel..do the same with it...if this doesn't work needs a rebuild kit..good luck..
Sep 27, 2014 | Echo Pb-403T Leaf Blowers
Won stay running
Needs a carb adjustment, cleaning, or possible rebuilt. Try adding a little seafoam and running at half choke for about 5 mins or longer this may clean it up nicely. also check the spark plug.
Nov 09, 2013 | Poulan WEEDEATER FEATHER LITE 1500 GAS...
Kawasaki krb 300 blower runs rough
remove the muffler and try it if ok open the muffler and clean the screen
May 22, 2012 | kawasaki Krb300a Backpack Leaf Blower - In...
My styhl 550 4-mix back pack leaf blower will not rev up,even after installing a new carb
Go to the exhaust muffler and use a socket to remove the muffler screen. If it is clogged, use a small propane tourch to burn the carbon inbedded in the screen. Once it turns to a greyish ash color. Lightly tap it to remove the ash. Reinstall it and then try again.
Mar 08, 2012 | Garden
I have a CCR 3650 Snow Blower ,The engine is racing at idle. How do I adjust?
Try the spring on the governor. sounds like it's not hooked up, or extremely week. I rebuild and sell these all winter. I've had it happen a few times. Runs really good! but, will ruin the motor running over speed like that. There are adjustments- some have the spring on a long flange of metal so it can be bent backwards to add tension- it doesn't take much! If the motor starts to rev up and down and up and down, add a hair more tension. It there is too much tension it will stall out when you hit heavy snow.
Feb 01, 2011 | Toro Snow Blower Ccr 1000 Belt 715381...
Homelite leaf blover run with choke soon when chokeis off ,cant rev up and die
if he put fuel in it dump it out & put yours in it , if problem persist there are 2 screws on the carberator turn the 1 on the right or th bottom 1/4 turn to the left!
Jun 02, 2009 | Homelite 'Yard Broom' Leaf Blower
Leaf blower will not continue running unless primer bulb is pushed intermittently
Hi
Priming the engine(put some gas in the sparkplug hole)..If.Start the engine.If only the gas from the cilinder is burned change the lines prom primer bulb.
best regards savumihai71
Oct 25, 2008 | Craftsman 4 Cycle Blower/Vac
Homelite Leaf Vac Attack Logo
57 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
