Question about Canon PIXMA MX310 All-In-One Printer
Cannon mx390 ink volume unknown
The Ciss wire for black ink empty ,but the black ink in the CISS i already refill
SOURCE: refilling ink tank
please donot use refilling system it is not for printer
it is new catridge after finishing you can refil for once dont use more times
it depends upon refilling-the quantity-before refilling you should clean with boiling water and then start refilling-if you shake the hands it ink will come out nozziles then use if not see the contacts of the catriges-if not just replace new catridge
Posted on Jan 01, 2008
SOURCE: Cannon Pixma MP500 - Waste Ink Reset
I don't belive there is a reset device for the MP500 tanks. However, when you get the empty error message, just follow the instructions about pressing OK as many times as it asks for (I think it is four time). At that point, you can continue to use the cartridges. The printer will no longer keep track of the ink level. You will have to do that yourself. But, you can continue to use the printer with all colors.
Posted on Jan 03, 2008
  • 5 Answers
SOURCE: my cannon printer pixma ip1800 cannot detect ink pls help me...
If after you install the cartridge you get a yellow light and error message:
“The following may have run out of color. The function for
detecting the remaining ink level will be disabled since the
ink level cannot be correctly detected. If you want to
continue printing with out this function, press the printer’s
start button. Canon recommends using new genuine Canon
cartridges in order to obtain optimum quality.”
Do not click “cancel printing”. Press printer start button
to start printing. This action will bypass the ink level
detection from the recycled cartridge. It will not damage the
printer! With a recycled cartridge this action needs to be
done one time.
A full recycled cartridge ink level may not display correctly.
It may show empty.
If you want to check the ink level, you can do a “Nozzle
check” by follow the directions below:
Go to menu File select print click on “Property” click
on “Maintenance”
Click on “Nozzle check” to print out the color check.
Click on “Cartridge Alignment” to align the cartridge.
See pictures for above process at Inktelligent ip 1800 topic
Also the refills refered to above are at the IP 1800 inkfilling page
Posted on Feb 23, 2009
SOURCE: COL INK VOLUME UNKNOWN MESSAGE
Something that worked for me, I opened the Conon MX310. took out both cartridges, and for 10 seconds I held the Reset. put the cartridges back in, closed the lid, and again, for another 10 seconds held the reset. SLOW seconds. this reset, ink levels recognised,, and it's working as it should be.
Regards
Shane (AKA Reef_Lex)
Posted on May 26, 2009
  • 159 Answers
SOURCE: how do i refill the ink myself cannon mp520
You need to reset or replace the ink level monitoring chip on these cartridges for refills to work. I know some refill kit sellers don't like to mention this to people before they buy the ink. Otherwise, I would recommend Cartridge World for ink refills because it can be messy to fill these cartridges and they always reset the chips for you.
Posted on Mar 08, 2010
How do i get rid of HP ORIGINAL INK DEPLETED ON C6280 ALL IN ONE PRINTER?
The empties you can drop at any fry's or anywhere they refill ink empties
May 07, 2017 | HP Office Equipment & Supplies
Tip
Ciss and refillable cartridge systems
Depending on printer brand and model, there are lots of ciss (continuous ink supply system) solutions to buy.<br /><br />Bare in mind, though, if you are planning to use printer heavily, there are other considerations you should think about:<br /><br />1. If not used regularly, an air bubble may occur and it takes a while to pop it up. Also ink may dry in certain area and it's a mess to resolve.<br /> <br />2. The ink supply (depending on supplier) may not be good as the original; color depth and durability wise.<br /><br />3. Cartridge recognition problems may occur from time to another, so it must be removed and inserted again.<br /><br />4. CISS system usually have a chip to fool the printer and it may fail with any liquid contact.<br /><br />5. ink pad inside printer fills quickly on heavy use, thus its wise to direct the pipe into an external tank (found inside and in the back of printer for Epsons) <br /><br />In conclusion, if you intend to have more than 100 pages/month, consider compatibles or refillable cartridges. ciss is good for +200 pages/month.<br /><br />e.g. (epson rx685 blanks out all 6 cartridges except for the black after 10x15 photo's in with high quality enabled)<br /><br /><span style="font-style: italic;">Please note that these tips are based on experience with 4-6 cartridge systems for Canon and Epson printers.</span><br /><br /><br />If you find this informative, kindly <span style="font-weight: bold;">vote positively</span> for me to continue sharing. Good luck and thanks.
on Nov 26, 2010 | Office Equipment & Supplies
Black ink volume unknown
Problem is you refilled the cart and didn't reset it properly so it looks like a new cart, check your other carts and see if gears or holes are wrong.
Nov 26, 2013 | Canon PIXMA MX310 All-In-One Printer
Canon ip 7240 i used refill ciss but 4 flash
Hi, My name is Liam from rihac, although we do not sell printers I work very closely with them via our inklink products. When a printer flashes 4 times this is a sign that an ink tank is not installed correctly or that the cartridge will need to be replaced as it is low on ink. As you are using a CISS the cartridges will always have ink in them. To bypass this error all you will need to do is press and hold the RESUME button on the printer for 10 seconds and this will turn off the cartridges ink status monitor and allow you to continue printing.
Canon Error Codes
I hope I was of help to you
Oct 30, 2013 | Office Equipment & Supplies
I had fully-refilled the ink into the CISS tank of my printer (CANON IP1980) however, the only colors that went out were magenta and yellow only. no black or cyan. the ink from the CISS tank did flow into...
You could try a head cleaning or a deep cleaning. You can find them in your printer properties under maintenance. After a few cleanings, try a test page. Keep cleaning and trying a test page until it prints like it should. If it never prints black and/or cyan, the print head is either seriously plugged or damaged.
Aug 23, 2011 | Office Equipment & Supplies
Add sublimation ink to cartridge for epson c88
The CISS are auto resetebale? If not, you must get a CISS with an autoreset button to get the printer work with the CISS
Oct 06, 2009 | Epson Stylus C88 InkJet Photo Printer
Ink is not visible on paper
First NEVER raise the tanks of a CISS above the height of the printer otherwise all that is going to happen is that the ink will syphon out and end up getting everywhere.
As you have not used the printer in a long time there wil be dried ink in the print heads 3x head cleaning is nowhere near good enough to clear the blockages.
One thing I would do as you have a set of OEM carts is the following presuming you have the equipment.
Drill a small hole in the top of each cart and extract as much ink as ps=ossible with a syringe (you can put it in the ciss ink tanks) and replace with head cleaning solution. Reseal the ink carts (if clean selotape will do) insert carts and do 5x head clean, leave 24hrs and do 5x head clean again. This will allow the head cleaning solution to get right insine of the print head, soften the dried ink and then flush it through..
A lot of messing about I know but you've just shelled out a few bob for a CISS so it's worth it.
NB
Make sure you keep the CISS carts above the tanks whilst outside of the printer.
Aug 24, 2009 | Epson Stylus C88 InkJet Photo Printer
Hi my epson r285 with ciss is leaving ink blotches all over my print outs, predominantly black, but less frequent with the other colours. This is only a new printer. Head cleaning, noxzzle cleaning and...
It might be caused by waste ink at bottom plate around head sprayer. For some CISS (bottle) design, ink will flow to head, and then flow to pad, when printer off. So, you must close respiratory hole at bottle when printer is not used. For cleaning, turn off printer (unplug power) when head is not in parking position. Move head to center. Put wet tissue (with cleaner or hot water) at top of pad (at head cleaning mechanics). Move head to parking position. So bottom plate contact with tissue. Wait for 10 minutes, repeat 3 times. Check nozzle.
Jun 21, 2009 | Epson Stylus Photo 1290 InkJet Printer
Ciss ink won't work on hp c7280
Must use included HP "starter ink" cartridges before the CISS can work. There's a 3-button sequence [OK-Cancel-Black Button] sequence when powering on that will reset the printer and bypass the "starter ink" wall you're hitting
Jun 11, 2009 | Epson Stylus CX5400 All-In-One InkJet...
R265 printer
hmm the only thing I can think is that there is a issue with the ciss system, but cant be sure unless tested which would mean new carts being bought but could it be possible if the ciss system got plugged?
I have not used the ciss setup before just used one never looked into them fully before.
Let me do some more reading and see if there is anything else that I can add to this, I need more education on the ciss system my buddy owns a ink refill place so im gonna see what he has to say.
Aug 13, 2008 | Epson Stylus R265 InkJet Photo Printer
Canon PIXMA MX310 All-In-One Printer Logo
290 people viewed this question
old marine
old marine
