Question about Intel Motherboard
CPU fan switching on and off repeatedly, computer not switchingon
Hello,I have a desktop with an Intel DP965LT motherboard. Usually when I switch on the PSU, the fans turn on momentarily and then turn back off again. Recently this motherboard died and I got a replacement from Intel. Now when I have put the computer back together, the fans keep on swtching and on and off, I get short static like sounds when they do and the computer doesn't respond to the cabinet's power on signal so the computer doesn't boot. Why do the fans turn on momentarily in the first place and what could be the reason for what's happening now? I have Intel Conroe 1.86 GHZ CPU and Antec 550W PSU
. Please help me
  • unitedroad May 18, 2009
    this PSU worked fine with my MSI motherboard for AMD AM2 processor. This second motherboard doesn't switch on momentarily when the PSU to which it is connected is switched on.
    I later connected the motherbaord in question to a spare cheap PSU I had. After a few starts, it now seems to have died again. This doesn't even power on anymore when the power switch is turned on.
    Maybe the motherboard was faulty or probably my entire power infrastructure is a mess.
  • 67 Answers
Check the power supply switch of your cpu casing, make sure that it will not stuck when you switch on the power.
Posted on May 08, 2009
Trying to find heatsink unit to be able to use the board
Hello here is the intel homepage:
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+945+Express+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D945GCZ
Your mainboard is using the LGA 775 socket.
The heatsink fan looks like this:
The fan can still be bought in a computer store, online shop or a repair shop.
I will recommend to but a better fan, like the brand northq, because the standard fan is difficult to mount correctly on the mainboard.
Remember to add a bit of cooling paste on the cpu, before you mount the fan.
Good luck
Sep 17, 2013 | Intel D945GCZ Motherboard
My computer switch off itself within a minute
Hello here are the intel site:
http://downloadcenter.intel.com/Default.aspx?lang=eng
Or visit the pc`s homepage for more info.
Is it a laptop or a desktop ????
If it is a laptop, the cooling fan is probably blocked by dirt = overheating.
If it is a desktop, blow the pc out for dust.
Open the case, and look for the cpu fan is spinning, when you press the power button
Try also to renew the power supply.
A pc repair shop, can help you get the pc running again.
Good luck
Feb 02, 2013 | Intel Computers & Internet
The green LED light on the board is lighted. When I push on/off button the CPU fan moves for 1/2 a second .I tried a different power supply, but that did not work. I replaced the CPU fan, but that did not...
Hello here is the homepage:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+3+Series+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DG31PR
Any abnormal beeps at startup ???
http://www.computerhope.com/beep.htm
The problem could be a ram module failing, or the graphic card if installed on the mainboard.
Or a short circuit somewhere.
Look also here:
http://www.tomshardware.co.uk/forum/243625-13-turns-wont-boot
Try starting with only 1 stick of Ram, the monitor and the keyboard connected, no other USBs to be connected.
Look also for bad caps on the mainboard:
If they look like this, the mainboard is dead.
It does not pay, to let them be changed.
Good luck
Jan 28, 2013 | Intel DG31PR Motherboard
D854gvsr motherboard manual
David,
Intel Support > Intel D845GVSR Desktop PC motherboard > Product Guide download page, (Motherboard Manual),
http://www.intel.com/support/motherboards/desktop/d845gvsr/sb/cs-008823.htm
On this page click on the blue -
Intel Desktop Board D845GVSR Product Guide (PDF)
Ignore the following if you are aware;
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the above file name, it may take up to 30 seconds before the first page comes up.
(The file is downloading to your computer in the background. When it has fully downloaded, the first page pops up)
The Zoom In icon ( + ) increases the view size.
The Zoom Out icon ( - ) decreases the view size.
The PDF file page number box is to the Right of the Down Arrow.
You can use the Down Arrow to go through, page by page, or IF you know the page you want, you can do this;
1) Put your mouse cursor in the page number box. Left-click Once.
2) Type the page number
3) Press the Enter key
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the wires from the Front Panel go to, is the Front Panel header. (Wires such as the Power On switch, Power On LED light, HarDDrive activity LED light, Reset switch, {IF a Reset switch is used )
Page 11 shows a basic Top View illustration of the motherboard.
The motherboard in the illustration is turned 90 DEGREES to the Right, in comparison to how it sits in your computer.
Page 12.
The Front Panel header is shown by the letter S.
If you have further questions about your motherboard, just state in a Comment.
Regards,
joecoolvette
( Also want you to have this,
http://www.playtool.com/pages/psuconnectors/connectors.html )
Jun 13, 2012 | eMachines D2880 Motherboard Replacement...
Hello sir my intel 845 mb switch on time cpu fan is just rotating and suddenly off
There should be loose connection in the motherboard. Please press the fan connection head hard on the motherboard.
Dec 07, 2010 | Computers & Internet
When I try to install my Intel DP965LT, an error E0441203 appears.. What can I do to fix this problem? Thank you very much!
Download (as in Save, not Run) the installers for the latest versions of all your drivers directly from Intel (using another pc of course if you don't have the network working), then install them.
Apr 18, 2010 | Intel DP965LT Motherboard
Intel desktop board D845wN - no screen display
HI,
Switch on your computer and listen for a beeb sound.... if no beeb sound available then your Motherboard has a problem.
if beeb sound comes then switch off your computer and see for the loose contacts on motherboard.
eg. remove ram, clean ram socket and put back the ram
your problem may solved.
thanks
ehsan (md_ehsan_1@yahoo.co.in)
Jun 15, 2009 | Intel Desktop Board D845WN Motherboard
Processor fan slow
There is usually something in the BIOS settings that control the speed of the fan at certain temperatures. check those. Set it on auto if you can
Jun 05, 2008 | Intel Motherboard
Intel Motherboard Logo
125 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
