Question about Microsoft Windows 98 for PC
Lost ide controller ....asterisk in device manager
No rom available because the controller went awol.No reinstallation available because of this. how to sort this out without reformatting drive?
Also trouble getting setup to run, in any case. when i go caldera dos and enter setup prompt using floopy to With/Without cd rom support all i get is bad command and cannot access the startup prog for re installation.( Other computer)both  win 98se.
  • 116 Answers
Re: lost ide controller ....asterisk in device manager
Your problem and description does not make sense, any chance by rom  you mean CDROM?
Do you have an original 98 CD? Or a copy. Rather than using caldera, use a 98 boot floppy?
Their are lots of ways to fix this, but i cant quite understand what your wanting to fix, or do.
Give a bit more information and i'm sure we can get you going.
Posted on Oct 10, 2007
0 characters
3 Points
Repair isatap drivers windows 7
if the drives are working, leave it be. There can be false positives. If the drives are slow or some thing else is odd, try the following solutions. Try to locate the driver needed by going to system devices and looking for a yellow or red icon next to a device. If there are no marked devices, you are probably ok.
Computer icon, properties, select device manager.
Open the properties for that device. details tab, properties and select hardware id. Copy the hardware id information and google it (sample:IDE\CdRomATAPI_iHAS324___B_______________________AL1A____ trimmed and adjusted becomes IDE\Cd Rom ATAPI iHAS324) Find drivers for that hardware if you can and update. You can also just uninstall the device and click rescan from the device manager menu. It should reinstall.
May 12, 2012 | Microsoft Windows 7 Home Premium 64BIT...
Hi my computer doesn't see dvd/cd drives .When i pull it up in device manager it shows drives but they have a yellow exclamation point in front of drives what can i do . thanks hotrize
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
Aug 18, 2011 | Microsoft Windows XP Professional
Cd rom driver
in most cases your CD-Rom drive won't need any external driver, because they are embedded in the OS. In case you are experiencing problem with your optical drive, just try to remove and then reinstall it from windows' hardware managment software.
Hope it helped,
Mar 02, 2011 | Operating Systems
Hello My Hp pavilion dv2000 is ready for vista but nowadays i install windows 7 home edition and after install my cd/dvd rom icon don't show in my computer. i try to solve this by removing disk drive...
Go to Control Panel-->Administrative Tools-->Computer Management
Your CD/DVD rom would be listed there... Just right click on the DVD rom and select"Change drive letter and path". Then select "Add" and change the drive letter..
Oct 06, 2010 | Operating Systems
Problem associated to the booting sequence, the 'my computer window ' is divided into four fragmentations .at the floppy and dvd. thedvd is not highlighted therefore imposible to access thecd player
You mean the CDROM or DVDROM is not selectable as a booting option in the BIOS, right? There must be something wrong with the device, the driver or your BIOS. Is your hard disk still bootable? If so, you can boot in hard disk and see whether the DVD-ROM is still there and check the device manager of your Control Panel to see if any errors about it. If it is not working there, you can check whether all the cable connections are connected well and the jumper settings are fine. There could only be one master device on a single ribbon of the IDE interface. So if you have a hard disk and your DVD-ROM connected to the same ribbon and the jumper settings of both are set to master, you will need to adjust one of those settings to slave or cable selection. Then you can use the AutoDetect feature of your BIOS to detect the CD-ROM if available. If those are not working, you can uninstall and reinstall the driver of your DVD-ROM if available when you boot in hard disk and open device manager for hardware change scan or directly right click on the CD-ROM icon in device manager and select update driver then select the right driver downloaded from the manufacturer's web site. You can also plug that DVD-ROM to another computer and see whether it is working there to detect mechanic issues of it. If everything is working on the other computer about this DVD-ROM and it is not working on yours, you can also try to flash your BIOS and/or replace the ribbon and see if it works before you replace your motherboard.
Aug 23, 2010 | Operating Systems
Dvd/cd drive is not shown in my computer
1) Veify its listed in device manager? To check that Right click on My computer and got to manage.There you need to click on device manager.On right side, check whether you are able to see CD/DVD listed. see the pic
If its not listed you need to reconnect the power supply.
If its listed and still not working, check the IDE or Sata cable to connected to it.Refix it.
If you are seeing an yellow mark near CD/DVD drive you can download microsoft fixit from
2)Verify that the CD/DVD drive is detected by the BIOS when the computer starts
You can see how to access bios at
3)Verify that the CD/DVD drive has a drive letter assigned in Disk Manager
a. Click Start, and then click Run. Or click Start Search.
b. Type “diskmgmt.msc” (without the quotes), and then press ENTER
c. Verify that the CD/DVD device is assigned a drive letter (for example, “D:”)
d. If the device does not have a drive letter, then right mouse click on the CD-ROM (highlighted in red above), and select Change Drive Letters and Paths
e. Click Add, click Assign the following drive letter, and then click a drive letter from the list
4)Uninstall & Reinstall the DVD/CD-ROM drive in Device Manager
b. Type “devmgmt.msc” (without the quotes), and then press ENTER
c. Double click to expand DVD/CD-ROM drives
d. Right-click on the name of your DVD/CD-ROM and click Uninstall
e. Select OK to the Confirm Device Removal (Windows XP) or Confirm Device Uninstall (Windows Vista) dialog
f. Right mouse click your computer name and select Scan for hardware changes
g. Close Device Manager
f: Click OK twice, and then close Disk Management
If all these not solved your issue you can have a look at
Aug 19, 2010 | Operating Systems
Trying to boot from windows CD and not working
If its the full windows xp cd by booting it from the cd drive it will erase everything and ask if you want to upgrade or advanced install I think. Your correct in choosing the atapi cd-rom as 1st boot device. The cd should be in the drive on startup. IDE is the type of hard disk drive. I'm guessing the FDD stands for floppy disk drive which you might not have that many but you have that many bay windows available.
Put disk in, shut down computer, Start computer and it should give you the xp disk contents. Be aware of data loss though.
Nov 14, 2009 | Microsoft Windows XP Home Edition
How do you change dma for xp to default
Open Device Manager.
Double-click IDE ATA/ATAPI Controllers to display the list of controllers and channels.
Right-click the icon for the channel to which the device is connected, select Properties, and then click the Advanced Settings tab.
In the Current Transfer Mode drop-down box, select DMA if Available if the current setting is "PIO Only."
If the drop-down box already shows "DMA if Available" but the current transfer mode is PIO, then the user must toggle the settings. That is:
• Change the selection from "DMA if available" to PIO only, and click OK.
• Then repeat the steps above to change the selection to DMA if Available.
Sep 23, 2009 | Microsoft Windows XP Home Edition
My internet connection gets lost after shutting down!
Got to control panel. Double click on modem, then driver. Select update driver. Let it search.
Dec 28, 2008 | Microsoft Windows Vista Business Edition...
Drive not working properly
Delete the drive from device manager. Reboot. If necessary check for driver updates and try disconnecting disbaling anything that could be conflicting with it.
Sep 07, 2007 | Microsoft Windows XP Professional With...
Microsoft Windows 98 for PC Logo
111 people viewed this question
Top Microsoft Operating Systems Experts
Brian Sullivan
Brian Sullivan
Scott Fryer
Alex Krenvalk
Are you a Microsoft Operating System Expert? Answer questions, earn points and help others
