LED is blue not RED
The LED is BLUE not RED.... is this normal? Thank you for your help Lloyd Simon lsimon14@hotmail.com
    Sergeant:
  • 175 Answers
Hi..its normal,nothing to worry.
thank u..
kindly rate my response..
Posted on May 08, 2009
I have a Samsung 55" LED TV (un55es6100) and the red color is flaring up. Green/Blue are perfectly normal. All other tv functions are normal. Can someone please help me figure out what to replace?
Are you using component cables or HDMI? If component, make sure your red, green and blue are pushed in all the way. Too, make sure your red audio is not the red video. If hdmi is used try a new one. If these do not help unplug your t.v for 10-20 seconds and plug it back in. All else fails reset your t.v to default factory settings.
Apr 04, 2017 | Samsung Televison & Video
LLoyd. Why doesn't it turn on?
If the led is red that means its stuck in stand by mode which is an indication that you have a problem in the power board
Mar 05, 2016 | Televison & Video
I have 5 wires red,white,green,blue and yellow, but i dont now how to instale those cables please show mi how do it.thank you
This is if you have gas furnace and central air conditioning.
Normally this is the way.
Red wire to R (or if your stat has Rc and Rh, wire to both of these
White wire to W
Green wire to G
Yellow wire to Y
Blue wire to C
If you want to check, before you connect to stat. Connect red and white (heat should come on)
the connect red and green (blower should come on) Normally yellow is for air conditioning and Blue is common DO NOT CONNECT ANY WIRE DIRECTLY TO BLUE, if blue is common it would short out fuse
Jan 26, 2011 | Heating & Cooling
I,ve connected my wii to the led tv using a wiii component cable(5 leads) but have used only 3 of them red green & blue 1,s leaving a red & white 1 left i have good picture but no sound help please
your cable is split into two different connections for your tv... the red green and blue cables are for HD only. They are their own little set. the yellow cable is your video cable for normal tv's. the red and white cables are sound cables, also for normal tv's. I would unplug the red, green, and blue cables, and use the yellow, red (right sound), and white (left sound).
Dec 31, 2010 | Nintendo Wii Console
The front LED flashes red & blue when I turn it on. What does this mean?
LED Indicators - LaCie 2big Network
The LED indicators above the drive bays and the front LED indicate drive status and activity.
During Startup
  • Front LED – blinks red/blue until both disks are powered on, then turns solid blue.
  • Rear LEDs – blinks red/blue until corresponding disk is powered on, then turns solid blue.
NOTE: If the device is not able to initiate the boot process following disk startup, the front is solid red.
During Bootup
  • Front LED – solid blue
  • Rear LEDs – solid blue
NOTE: If a disk is failing, both the disk’s corresponding rear LED and the front LED will be solid red.
During RAID Synchronization
  • Front LED – solid red
  • Rear LEDs – The LED corresponding to the original disk will be blinking blue and the one being synchronized is blinking red
  • Once both disks are synchronized, their corresponding rear LED and the front LED will be solid blue.
Apr 06, 2010 | LaCie 2 TB 2big Triple Interface External...
I have a 3TB big disk quadra and the blue light in front started blinking between red and blue. What does that mean? I still saw the drive on the desktop and access to the files, but I shut down the...
If the drive front LED alternates between Red and Blue, whilst the rear LEDs are normal, then it is a tempertaure warning. Ensure that there is plenty of space around the drive and at the rear.
Mar 06, 2010 | LaCie (301082U) 250 GB Hard Drive Array
Inoperative LCD TV
Welcome to Fixya! My Name is Travis! I have heard this Problem Before on Another Model. Turns out it was the Power Switch in that case. Yours has the Exact same Symptoms. Get that Checked and let me Know so we can go Further or if that is it.
Jan 02, 2009 | Televison & Video
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
