Question about Exercise & Fitness
Cybex 625 t error code 140
Error code 140
Cybex 625T
Most commonly this error code is caused when a software error has occurred in program. Start by replacing the EPROM. If this does not correct the issue, move on to the microprocessor.
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Jul 10, 2014 | Exercise & Fitness
Cybex belt not starting
Are you getting any error codes. Usually no belt movement is bad or short motor brushes. I would start there first.
Apr 24, 2014 | Cybex 530T Pro Plus Treadmill
Que es error 5 tectrix personal climber
Error 5, No Slack, Cybex/Tectrix Climbmax 2000/3000, 700S and 800S Steppers Probable Cause An error 5 on the Tectrix Climbmax models 2000 and 3000 as well as Cybex stepper models 700S and 800S indicates the following:
a) Test switch is in test mode.
b) Possible cut in display cable.
Corrective Action a) Adjust slack switch.
b) Inspect display cable; Replace cable if necessary.
Error 5 No Slack on Cybex and Tectrix Steppers Climbmax 2000 3000 700S 800S
Apr 10, 2014 | RTO Tectrix Personal Stair Climber
Cybex 530t error 1
Error 1, Err1 Belt didn't start (or no speed sense) 1. Perform speed calibration procedure
2. Check speed sensor
3. Check motor brushes
4. Check drive motor
5. Check lower board
I am attaching a link for the service manual. This information can be found on page 65. You can use this manual to determine the steps required for checking the above mentioned items.
http://www.sportsmith.net/images/product_support/cybex/Manuals/Service/LT177304-CybexProPlusTreadmillOwnersServiceManual.pdf
Cybex Pro 530T Treadmill Parts Deck Belts Motor Rollers SPORTSMITH net
Apr 09, 2014 | Exercise & Fitness
Err 5
Feb 22, 2014 | RTO Tectrix Personal Stair Climber
Screen shows error code 5
Feb 20, 2014 | RTO Tectrix Personal Stair Climber
Screen shows err 5
Cybex 520T error message 3
Error 3 is a speed signal lost error. Check speed sensor, lower board, drive motor then display.
Feb 08, 2012 | RTO Cybex 520T Remanufactured Treadmill
My Cybex 520T is comming up with Error 9 on the Screen
Hi, Error code 9 on your treadmill means the brushes on the motor need replacing. This is an automatic indication that is set for 100 miles of use to prevent damage to the motor. Replace both sets of brushes and this should Fixya!
Mar 25, 2009 | RTO Cybex 520T Remanufactured Treadmill
Exercise & Fitness Logo
254 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
