Question about HP LaserJet 8150n Printer
Am picking multiple drawings to print on my Laserjet 8150N and keep getting the following error:81.0180 EIO 1 Error
I am picking multiple drawings to print on my Laserjet 8150N and keep getting the following error:81.0180 EIO 1 Error
  • 3 Answers
SOURCE: HP Colour LaserJet 4600dn printer problem
Try to remove the jet direct card into another slot. If that does not work you need to purchase a new jet direct card.
Posted on Oct 31, 2007
wprodgers
  • 32 Answers
SOURCE: 82.0180 EIO 2 ERROR
This is an error caused by the jet direct card in your printer, try one of two things.
Move the Jet Direct card from port 1 to port 2 on the printer.
Replace your jet direct card with one that you know is good.
Test to see if either of these resolves the issue.
The problem is usually a faulty card.
Posted on Jan 26, 2009
SOURCE: EIO 1 ERROR
There's probably a problem with the card in the printer. It may need a firmware upgrade, you may need to adjust settings or even change the slot. The EIO 1 means it is now in slot 1. Here are some steps to try from the HP website:
Press (Select) to enter the MENUS.
Press (Down arrow) to highlight INFORMATION.
Press (Select) to select INFORMATION.
Press (Down arrow) to highlight PRINT CONFIGURATION.
Press (Select) to select PRINT CONFIGURATION
Check if the I/O card is on ready state.
Make sure that TCP/IP status is ready.
Check the network statistics for any bad packets or bad transmition.
Try to use another slot then the one that the JD is installed on.
If the problem persist,try performing a cold reset with the JD inside.Warning: This will reset the printer's configuration to the default settings,and also to the JD so you will need to set again the network values.
Posted on May 19, 2009
KingDWS
  • 1606 Answers
SOURCE: ''HP Laserjet 4600, Error code 81 0180 E10 1 Error''
That indicates that the printer has a network card problem. You can try rebooting/resetting which can clear it but usually means a trip to the hp repair shop.
Posted on Jul 09, 2009
SOURCE: Print error job storage
The printer needs to have RAM drive off, mopier mode disabled. Also the device settings for the printer needs to have Printer Hard Disk set to not installed and job storage and mopier mode set to disabled.
Posted on Oct 02, 2009
Laserjet 2605 49 error
Error 49 is a firmware error. Try following these steps:
1. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. You can try reprinting the job to see if it was a temporary error. 3. If error persists, try printing a job from a different software application. If the alternate job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or certainprint job, try upgrading the printer driver and / or firmware.) 4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. Turn the printer off and delete the print queue. Then reboot printer AND computer, reconnect cables, and try printing again. 6. Remove all EIO devices from the printer (JetDirect cards, hard drives, etc.). If 49 error goes away, turn printer off, re-install EIO devices one at a time, and reboot printer each time to determine which EIO device is failing. 7. If printing still fails with all EIO devices removed, remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM-- printer won't function without this installed.) Turn the printer on with DIMMS missing. If the error no longer exists, install each DIMM one at a time, turn printer on, test printer. Replace a DIMM if you determine that it causes the error. 8. Remember to reconnect all cables that connect the printer to the network or computer. 9. If the error persists, replace the firmware DIMM. 10. If error persists, replace the formatter.
Mar 10, 2014 | HP LaserJet 2605dn Printer
How solve error 49 on 4730mfp
it's a long one !
Dec 18, 2012 | HP LaserJet 4730mfp All-In-One Printer
Error code 40.0
A connection with the card in EIO
slot X has been abnormally broken.
1. Press to resume printing.
NOTE
A loss of data will occur.
2. Check that all cables are
connected to the EIO ports
and that the EIO board is
seated properly.
3. If possible, print to another
network printer to verify the
network is working properly
Jul 24, 2012 | HP Color LaserJet 5550 Printer
We have a HP 8150N. The printer will not print and is giving a 62.0 printer error message. We have turned the printer on and off which has not helped. Is there an eazy fix?
62.0 memory error. This error indicates that the memory that is soldered to the formatter is likely bad. If the error was 62.1 or 62.2 that would indicate that the memory in one of the upgrade slots was bad. The only real solution to 62.0 will be to replace the formatter.
Jun 13, 2011 | HP LaserJet 8150n Printer
My HP 4100tn will not print and I am getting error message as follows: 82.0180 EIO 2 ERROR I printed a document and then when I tried to print another document I got the error message. How can I fix...
Thank you for contacting FixYa with your printer inquiry.
  1. Move the Jet Direct card from port 1 to port 2 on the printer.
  2. Replace your jet direct card with one that you know is good.
J7934-69011 JetDirect 620n internal print server - 10BaseT and 100BaseTX LAN interface board - Plugs into peripheral EIO slot - Has an RJ-45 connector
Vender
http://www.dectrader.com/J6057-61001-New-HP-JetDirect-615N-internal-print-server-10Base-T-and-100Base-TX-LAN-interface-board-Plugs-into-peripheral-EIO-slot-Has-one-RJ-45-connector.html?utm_source=googlebase&utm_medium=shopping&utm_campaign=parts
image.php?type=p&id=223008&t250=y
Hope this helps helps. Please keep us updated and remember to rate this answer.
Feb 22, 2011 | HP LaserJet 4100n Printer
Hp Laserjet 2300n printer with error 81.0180 EIO 1 ERROR
You have a problem with the device plugged into EIO slot 1. Most likely it's a JetDirect card. Turn power off and reseat the card. Power up, if problem is still there put the card in the other EIO slot. There should be 2 EIO slots. If it still fails you will have to replace the JetDirect
Oct 07, 2010 | HP LaserJet 2300N Printer
Have been getting the following error 83.0180 EIO 3 Error on an HP LaserJet 9000. Don't have the manual so don't know what it is.
this is a network card error. the EIO card in slot 3 is probably faulty. Try swapping the card into slot 1 or 2. If you get the same error then you will need to replace the card.
Nov 06, 2009 | HP LaserJet 9000 Printer
ERROR MESSAGE
This error is usually caused by a bad formatter board.
But try the following:
1. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. 3. Try printing a job from a different software application. If the job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or print job, contact the software vendor for assistance.)
4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. 5. Turn the printer off. 6. Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in the lowest DIMM slot.) 7. Remove all EIO devices from the printer. 8. Turn the printer on. 9. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each device. 10. Replace a DIMM or EIO device if you determine that it causes the error. 11. Remember to reconnect all cables that connect the printer to the network or computer. 12. If the error persists, replace the firmware DIMM. 13. Replace the formatter.
Dec 13, 2008 | HP Hewlett Packard LaserJet P3005n Printer
Sysytem Error 009B002 007A046F
System Error: 09xxxx (Non-Continuable)
Problem
Description:
EIO Accessories (EIO Card/Hard Disk Drive) Error.
Corrective Action: Try the following:
n Switch the Printer OFF and ON again and wait for the initialization.
n If the Error code continues to appear, switch the Printer OFF.
Remove the EIO Card (if installed) and make sure that the Hard
Disk Drive is installed correctly by pushing it firmly inwards and
checking that the two installation screws are completely
tightened. Switch the Printer ON again. If the error codes 09Axxx
or 09Bxxx appear then replace the Hard Disk Drive.
n If the Error Code disappeared after removing the EIO Card, then
switch the Printer OFF and reinstall the EIO Card, making sure
that the two installation screws are completely tightened. Switch
the Printer ON again. If the Error Code reappears, then the EIO
Card could be faulty. Replace the EIO Card.
n If Error Code 09Cxxx appears after initialization, then replace the
Electronics Module
n Once the Error Code has been solved, print an Internal Demo
Print to make sure that the Hard Disk Drive is functioning
correctly. If the Error Code reappears, then use the above
information to troubleshoot the problem
Nov 21, 2008 | HP DesignJet 1050c InkJet Printer
HP LaserJet 8150n Printer Logo
289 people viewed this question
Seeker5211
Seeker5211
