Question about Health & Beauty
On my charger both, lights flash green as i try to recharge, but it only recharges a little.
I don't know if its the cord, or the batteries, or what?
  • 1,271 Answers
Hi , use the scooter for about 10 minutes, okay now plug in the charger, do any of the lights go red or orange to indicate it's charging, if not , remember one green light is to indicate it's turned on...
1. Check the voltage can be seen at the charger socket, (mulitmeter required here volt DC setting looking at the two outside holes)
2. Is it not possible to try another charger ? as long as it the same fitting ...
3. Is there a fuse for the charging line?.
4. If all fails then it seems the batteries need be replaced.
Regards
www.gewizrepairs.co.uk
Posted on Nov 26, 2013
dromtonpa
  • 40 Answers
SOURCE: can I recharge a 24v gel battery with the
 yes. only if the volts have fallen below 24VDC. I would`nt make a habit of it though
Posted on Apr 05, 2009
SOURCE: 4 whhel strider won't run, batteries charged
the motor is not working perfectly and chnge motor or check the connection perfctly
Posted on Jul 14, 2009
gewiz
  • 1271 Answers
SOURCE: Scooter batteries will not charge. Green light on
ok, this could be a dodgy connection with the batteries or the charger is at fault ?
1. try another charger
2. check the batteries if possible on another scooter.
3. check the connection on the battery and the charge socket connector.
Regards
GeWiz.
Posted on Oct 01, 2009
  • 26 Answers
SOURCE: Battery drains within 2 blocks? Charger is green
need new batteries
can get from 0208 676 0944
Posted on Apr 15, 2010
Testimonial: "Your answer was my first thought. Thanks for verifying my guess. I could not think of anything else."
HoverTech
  • 232 Answers
SOURCE: MY scooter battery needs recharged
Has the scooter been stored unused for a while? If so, the batteries may have gone solid from improper maintenance. There is a gel inside the batteries that needs to have current run through it at least once a week to keep them fluid. The charger is showing a green light because it senses the batteries are full, but instead of being full of power, they are full of crud and need to be replaced again. If the batteries have been properly charged but you still cannot get power, check all your connections to make sure they are tight and that your fuses are not blown.
Posted on Oct 13, 2010
AA battery recharger is flashing red
All I can see is that your charger is flashing red. There wasn't any brand mentioned. Most battery chargers flash green when in charging mode, solid green when charging is complete and flashing red when there is an issue with the battery/batteries being charged. Rechargeable batteries don't last forever (usually 200-300 charges) and perhaps this is the case with yours. Also, if you are using imported batteries (China), that would be a major red flag!
Aug 15, 2014 | Electronics - Others
My battery charger stopped charging the battery. Whenever I put the battery in the charger the green light flashes signaling a problem. I tried wiping the contacts as the book suggested but with no...
How long do you have the camera?
Rechargeable batteries don't last forever, and when they are too weak to take a charge, the little light just blinks.
They could also be shorted out.
This flasing is a problem code. "The book" should also tell you what these flashes mean, although it usually means: replace the battery.
Jun 24, 2011 | Panasonic LUMIX DMCTS2 / DMCFT2 Digital...
Re: Battery Charger BC-45W I just purchased a Fuji JZ500 and the battery needed to be charged. When I plugged the charger into the power outlet, the indicator light (yellow) turned on but after a few...
Ok all mine had the same problem however problem has been solved! The power cord that plugs into the charger is a common cord you may have laying around the house. I switched the power cord to my charger and the dreaded blinking stopped! Its just a bad power cord to the charging unit! Hope this helps!
Dec 23, 2010 | FUJIFILM BC45W Rapid Travel Battery...
What does it mean when a household battery charger flashes red then green? The charger is a SYNERGY DIGITAL rapid quick charger. I'm trying to charge new AA Energizer Lithium batteries.
When the charger light is changing from red to green that is a indication that it is charging the battery. When the charge is complete the light will stay green until the battery is removed or the charger is unplugged.
Jun 06, 2010 | Energizer Rechargable Battery with Charger
Charge
You need a separate battery charger for this camera. It does not have a battery charger built into the camera itself and can not be recharged thru any cords connected directly to the camera. The USB cords only transfer the files to the computer, they don't recharge the camera.
Dec 30, 2008 | Sony Cyber-Shot DSC-P50 Digital Camera
Cannot recharge iRiver iHP-120 battery
Battery replacement directions are advaliable from misticriver.net.
Oct 06, 2007 | iRiver iHP-120 MP3 Player
My camera eats batteries like candy!
Alkaline batteries are a No-No Rechargeable Ni Cads are little better The Best are NiMh Rechargables in the AA cell range or Li-on in the specialist range. Always get for the best.
Jul 10, 2007 | Vivitar ViviCam 8400 Digital Camera
Durabrand portable dvd player
Try a standard multi voltage charger. These come with a selection of connectors each one of a specific size and color coded. so you pick the connector to fit the input jack then set the charger to the appropriate color to give the correct voltage.
May 22, 2007 | Durabrand 8.5'' Portable DVD Player
Health & Beauty Logo
85 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
