Question about Nordic Track Recumbent Exercise Cycle GX4.0
Plug in and nothing happens
It does not turn on
Kocaso m9200 will not turn on-what do i do. It has been plugged to be charged but when I press on the on bottom nothing happens
My tablet turns itself off and won't come back on unless I plug it in...... It's a Kocaso m9200.
Dec 31, 2013 | Computers & Internet
Battery light flashes and nothing else happens
Yes, the socket broken loose could be your trouble and is common as we are not careful when we insert the plug all the time.
Apr 19, 2012 | Computers & Internet
Nothing happens when you plug it in & turn it
First be sure it is plugged into a working outlet, try another power cord (a 3 wire computer cord will work) look on and around the PC board for vdebris. If these don't help byou probably need a tech.
DickyO
Jul 22, 2010 | Lexmark Wheelwriter 1000 Typewriter
My laptop fell down and now my screen does not display anything
try to press and hold Fn and F8 - this is to toggle screen setting to ext and back to LCD on laptop. if nothing happens turn off computer by pressing power button, unplug the ac adapter, remove the battery. remvoe residual electricity from computer by pressing power button 10 times. just plug again the ac and leave the battery out. Pres and hold the letter D and while holding that press the power button once and release both of them. it will perform the built in self test on the lcd. if nothing happens, turn off computer. press anf hold Fn and while holding it press power button. it will perform diagnosis on computer. if still nothing happens need to repalce motherboard and LCD.
Mar 03, 2010 | Dell Inspiron 6000 Notebook
NOTHING HAVPPES WHENI PLUG IT IN AND TURN SWITCH
Hello Sir,
Make sure that the fuse or the relay of the supply unit is intact and in working condition. If not that there is some trouble in the power supply unit.
Regards.
Nov 15, 2009 | Magic Chef MCWC16MCG Wine Cooler
Plug in my hard drive and nothing happens
Make sure that your usb hard drive is inserted properly into the computer but if nothing happens, go to your bios settings of your computer and be sure that usb function is set to on. Save changes and restart the computer. If you dont know how to do this, first turn on the computer and press the delete key in the keyboard, once you enter the bios screen look for the usb settings and make sure it is set to on. Hope this could help. Thanks
Oct 23, 2009 | Computers & Internet
TV will not Turn On.
same thing,tv won,t come on,unplug the tv, nothing at all,just yesterday my tv was fine, this is the first time this has ever happen
Mar 13, 2009 | Samsung HC-P4363W 43 in. TV/DVD Combo
Sansa mp3 locks up
Make sure the hold/lock is not engaged.
Jan 08, 2009 | SanDisk Sansa Clip MP3 Player
System turns on however hard drive will not cycle nor will mouse or key board activate
Turn power off and unplug power from computer.
Unplug printers,backup drives and speakers.
Open case and unplug power supply from the board.
plug power cord back in press the power button.
Of course nothing will happen.
unplug power cord again.
plug power supply back into the board.
plug power cord backup and press power switch.
If nothing happens unplug power cord again.
pull out your memory sticks and plug cord back in and press power button.
Of course not much will happen.
But really something is happening to your computer so continue.
Pull power cord and replace memory sticks.
replace power cord and press power switch.
Continue this pulling out pci cards one at a time until you find out what the problem might be.
Try different keyboards and mice too.
Good Luck
Oct 27, 2008 | Intel Computers & Internet
Matsui MAT 140 MR wont turn on
If you can check the rechargeable batteries try that. If you plug it into a wall socket with the adapter and nothing happens you might have other major problems. Just a little education: when you buy something especially from other countries alway check it before leaving to make sure it works. Unless there is a company that you can send the warranty unit to you may be out of luck. Sorry.
Jan 14, 2008 | iLO (2 GB) MP3 Player
Nordic Track Recumbent Exercise Cycle GX4.0 Logo
54 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
