Question about Yamaha Full-Size Keyboard
Psr-8000 taking out the rubber contact strip
Rubber contact is bad
2 Suggested Answers
SOURCE: My yamaha psr s900 has
http://www.retrevo.com/support/Yamaha-PSR-S900-Music-Keyboards-manual/id/20332ci477/t/2/
Above are some manual links.
Hi, underneath if you look carefully you will see the Holes that contain the screws, no srtart in one corner, have a look at this one, there are often little arrows besides the correct ones to take out, in any event, work around the edges of the unit, undoing screws as you go.. look for all similar screws too, anyway remove them all.. now using a flat non-sharp instrument say a Butter Knife, at one corner again sort of slide the blade in between the case halves and pry open carefully. Put your screws into a container as you remove them, if there are differing types use different containers.
Observe all settings etc, write stuff down, plugs cables etc. do a drawing if necessary just go slow and methodical. Now once you have access, and that may not mean entirely taking the case in half even, whatever is required. now identify the piece you wish to replace and examine it, have a look to see how it is fastened, what wires go where etc. then remove the "Old" board, and replace it with the "new" board. (If you are confident all is well it may just pay to power up and see if it works)
If all is well, then carefully refasten it down, connect up as necessary, and make sure everything looks as it was, and close the case back up, doing the reverse procedure.. make sure you get it right first time or you'll have to do all those screws again. :)
Some screws can be under labels, so don't get caught by that one.
Always lay the unit on a big sheet of paper.
Posted on Dec 20, 2010
Install PSR E413DRIVER
What driver do you want to install?
Jan 14, 2014 | Yamaha PSR-E413 Portable Keyboard
Yamaha psr 295
Hi, This is probably due to worn rubber contacts. The sound is switched by pressing a key which in turns press a carbon contact on the PCB under the key. In time these wear out and need to be replaced.
Firstly open up the keyboard and locate the rubber contacts, check to see if each one is seated squarely, if they are not seat straight then this can create the problem you mention.
If all are OK then you will need to replace the strip which is causing a problem.
Spares are available from many sources including :
http://www.beckettsmusic.co.uk/shop/scripts/prodView.asp?idproduct=16049
Jul 20, 2013 | Yamaha PSR-295MS Portable 61-Key...
YAMAHA PSR 9000 D NOTE VERY LOUD INTERMITANT
If you have any key note problems with your yamaha psr 9000 and need It repaired contact a qualified engineer at stephenhns5@gmail.com
Jan 28, 2013 | Yamaha Music
Some of the keys do not play on our Yamaha PSR-330. How can we fix that?
The key contacts have gotten dirty. The contacts are CONDUCTIVE rubber pills that are pressed onto circuit traces on the circuit board under the keys. Onehas to dis-assemble the keyboard very carefully noting the size and location of all the screws and using great care of the cables that connect the top and bottom of the case.
when you remove the keys, you will find silicone rubber strips with the black pills underneath, two pills per key.
Clean these with ONLY 99% isoprophyl alcohol and Qtips as well as cleaning the circuit board traces they contact.
Carefully re-assemble the keyboard.
Jan 09, 2011 | Yamaha MM6 Mini Mo Keyboard Pro
Yamaha psr s900 screen/display gone bad
MR SATISH IF YOU WANT TO SOLVE THIS PROBLEM CONTACT:9887070565,94136768(ANAND NARWAL)FROM RAJPUTANA ENTERPRISES
Jul 22, 2010 | Yamaha Full-Size Keyboard
Do you have yamaha keyboard psr 2000 spare parts?
My keyboard yamaha psr2000,so I want parts silicone rubber keypad 61 and including electronic board,thank you.
Feb 12, 2010 | Yamaha Full-Size Keyboard
My psr-230 keyboard does not work well, some keys
The key contacts proabably need to be cleaned.
One has to disassemble the unit being very careful of cables. Do not force anything.
The contacts are usually black conductive rubber "pills" under silicone rubber domes. These are often in strips covering several key contacts.
Clean both the pills and the circuit traces on the board they contact with 99% isorophyl alcohol and Q-Tips.
Jan 23, 2010 | Yamaha Music
Keys stick on Clavinova CLP 360
A contact rubber for CVP-35, part number VS549800 will work, that's how I fixed my sensor problems on my CLP-360.
Jan 19, 2009 | Yamaha Full-Size Keyboard
Yamaha Full-Size Keyboard Logo
82 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
