Question about Source Technologies ST9612 9620 MICR Toner 3 000 Yield STI-204513
Light blinking light above "!" is blinking and printer won't print
My Status light is blinking, red orange, green and It won't stop
This just happened to me! I found this fixya and it didn't help me. So I checked the status of the printer and it was trying to print some 3,000 envelopes, OOPS!!! Needless to say I cancelled the job but it still had to go through all of the pages before cancelling and finally stopped blinking!
Jul 18, 2012 | Brother HL-5370DW Duplex Wireless Laser...
Blinking/flashing lights(orange & green) & won;t pring. Have rebooted computer and unpluged printer. still won't print.
that is because ur head of ur printing cartridge is damaged.
remove ur cartridges black as well as color
n install only black cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur black cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of black cartridge is damaged
after this process remove the black one cartridge and install the color one cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur color cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of color cartridge is damaged
now take a dry cotton cloth n gently clean ur cartridges head install both cartridges on ur printer n check ur blinking light on ur printer that will work only if u r too lucky other wise u have to purchase a one cartridge.
May 29, 2011 | HP DeskJet 5550 InkJet Printer
Orange ink light blinks. printer will not print.
turn on/off, unplug, plug in, should reset configs.
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above. HP has an awesome trouble shooting site
hope this helps and good luck
Apr 29, 2010 | HP DeskJet 932c InkJet Printer
Hp 5510 io keeps stating to check color cartridge/3 lights blinking/won t print/installed new color'' Let our Experts solve your ''hp 5510 io keeps stating to check color cartridge/3 lights blinking/won t...
hi..
try to install and reinstall the printer cartridge...and also clean the tab circuit of the cartridge and tab circuit of the printer carrier..
if the problem still exist..
rebreak the printer by full-out the power supply...to reset the settings and then turn it back...
Apr 01, 2009 | HP Officejet 5510xi Printer
Document is not printing
Press the feed button. If that doesn't work, turn the printer off, wait a few seconds, and turn it back on again.
Feb 03, 2009 | HP DeskJet 932c InkJet Printer
Hp lj 2500 flashing yellow light
The yellow-print-cartridge
light is blinking, and the
printer stops printing.
 The print cartridge is
empty or missing.
 The printer cannot
detect the print
cartridge correctly.
1. Reinsert or replace the print cartridge.
2. If the print-cartridge light is still blinking but the
Attention light is not on, turn the printer off and
then back on.
3. If the problem persists, repeat the above steps
with yellow print cartridges until the error is
resolved.
4. If the problem persists, replace the printcartridge
E-label reader, which is located on the
pressure assembly of the print-cartridge
carousel.
Jan 09, 2009 | HP LaserJet 2500L Printer
The printer apear to be dead!
Buttons and lights on the printer Two buttons and three lights are located on the front of an HP Deskjet printer.
  • The lights tell when the printer is working or when it needs attention.
  • The buttons help control the printer.
Buttons and lights Purpose c00123886.jpg POWER button and light Push the POWER button to turn the printer off and on. When lit, the light shows that the printer is turned on. c00123889.jpg RESUME button and light The light blinks when there is a problem with paper. When the problem is corrected, press the button. c00123892.jpg Print cartridge light The light blinks when there is a problem with a print cartridge. When the problem is corrected and the top cover is closed, the light will stop blinking. Troubleshooting blinking printer lights Blinking lights Reason c00123895.jpg
All lights are off. The printer is off (asleep).
Press the POWER buttonc00123886.jpg to turn the printer on.
The printer should turn on automatically when a print job is sent to it. c00123898.jpg
The POWER (top) light is on. The printer is idle.
The POWER (top) light is blinking. The printer is busy printing.
Allow enough time to print. When a document has many fonts or graphics or uses complex color such as a color photo, it takes longer to begin printing. c00123902.jpg
The PRINT CARTRIDGE (bottom) light is blinking. Possible causes:
  • The front cover is open. Make sure the front cover is completely closed.
  • The print cartridge is missing. Make sure the print cartridge has been installed correctly.
  • The print cartridge is broken or incompatible. Lift the front cover, and wait for the print-cartridge cradle to slide out. Check the part numbers on the print cartridge:
Black: 51645A
Color: C1823D,
If the print cartridges are compatible and correctly installed, they may be defective. Try replacing the print cartridges.
If none of the above suggestions fix the problem, and, if the error message still occurs, it may be a hardware failure. Call the HP Customer Support Center.
Jan 20, 2008 | HP DeskJet 710c InkJet Printer
Source Technologies ST9612 9620 MICR Toner 3 000 Yield STI-204513 Logo
57 people viewed this question
Top Source Technologies Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Source Technologies Office Equipment and Supply Expert? Answer questions, earn points and help others
