Question about Nextar X3B GPS Navigation System
Gps new unit charged 5 hrs, still says charging and won't turn on
  • verse Nov 15, 2007
    I have the same problem. When I turn on the system just the red light comes on and nothing happens. This is a nextar p3 and cant find out any solution. It is brand new. Paul
There are two on buttons, one on the top and one on the back
Posted on Dec 26, 2008
SOURCE:
How long does it take to charge up we just bought a new one and it was plugged in the car for 2 hrs and only lasted about 2 hrs
Garmin satnavs come with a charge out of the box. In most instances you will not need to charge before using. Your device will charge while attached to your 12V vehicle power cable.
In some cases your device may have lost a charge during shelf life. In this case you can charge these units in three ways:
  1. Place unit on computer with USB cable for approximately 8-12 hours
  2. Place unit on Garmin specified AC adaptor for approximately 4-6 hours
  3. Place unit on 12V vehicle adaptor for approximately 4-6 hours
Your device should be fully charged after applying one of the steps from above.
Aug 09, 2010 | Garmin nuvi 250W GPS Receiver
Unit will not starthave left on charge overnight
The batteries are only small in these units and only require 1 maybe 2 hrs charge, so if it has been on charge all night there is a fair chance it has cooked the battery.
Jul 11, 2010 | Tomtom RIDER GPS Devices
My nuvi 260 will not display anything . It turns on okay with the Garmin introduction and then screen goes blank
Sounds like a battery problem. You may have to send to Garmin for replacement of the battery as it's not user fixable. I also highly suggest using a Garmin approved charger/ car charger if you don't have that!!
Or understand this:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} There are three ways to charge the internal battery in your automotive GPS unit.1
  1. Use the provided vehicle power cable that came with your GPS unit. The unit will charge while powered on and using the device as well as when the GPS unit is powered off and plugged into a running vehicle. About 3 hrs for a full charge. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
  2. Use an AC power adaptor. Some units come with this power cable to plug the GPS unit into a wall outlet allowing the GPS unit to take a charge. For units that do not come with this cable, one can be purchased from Garmin's online store.
  3. For most units, the final way of charging the battery is to plug the GPS into a powered on computer with a USB cable2. This method of charging will be a trickle charge and it may take longer (like a full day) than the other two options, however it will still charge the battery. A USB cable is provided with a few GPS models. For those that don't come with this cable, one can either be ordered from the online store or you can use a standard USB to mini-USB cable that fits the unit and plugs into your computer.
Oct 06, 2009 | Garmin nuvi 200W GPS Receiver
Why doesn't my garmin nuvi 200 gps system charge?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Sounds like a bad or low battery. Do you have the Garmin approved charger / car charger?? You may have to send your GPS in for battery replacement or try this:
1 - Please note that temperature can play an effect on the charging of a device. If the battery registers a temperature of 0°C and below or 45°C and above (32°F and 113°F respectively) then it will not charge. When connected to external power it will only be operating off of external power.
Jun 30, 2009 | Garmin nuvi 200W GPS Receiver
Need to know how to charge garmin nuvi 255w using home wall charger.
2 - The Quest® and Quest® 2 will not charge using a USB cable.
Jun 26, 2009 | Garmin nuvi 255W GPS Receiver
My garmin nuvi turns on for a second then turns back off whats wrong?
Jun 10, 2009 | Garmin nuvi 200W GPS Receiver
Garmin nuvi unit was indicatig battery charging when i . conneted to my computer. I removed and tried to turn this on ...it did not and then I have re-connected to my computer again and even tried to...
It take a day to charge the 260 WITH the correct cable for your computer as it will only trickle charge it.
Car charge does it in 2 - 3 hrs. If car is not charging it check the fuse in the end of the charger
And:
  3. For most units, the final way of charging the battery is to plug the GPS into a powered on computer with a USB cable2. This method of charging will be a trickle charge and it may take longer than the other two options, however it will still charge the battery. A USB cable is provided with a few GPS models. For those that don't come with this cable, one can either be ordered from the online store or you can use a standard USB to mini-USB cable that fits the unit and plugs into your computer.
Jan 04, 2009 | Garmin nuvi 260W GPS Receiver
Unit won't remain powered-up
You are absolutely correct Jim. Low Battery
Dec 25, 2008 | Garmin nuvi 260W GPS Receiver
Magellan roadmate 2000
I Reset the unit by switching reset switch on and off.
The switch is on left side of my gps.
Mar 02, 2008 | Magellan RoadMate 2000 GPS Receiver
Tomtom720
there is a reset button on the bottom of the unit ,take a paper clip or pin and pus in for abut 30 seconds then try to turn on.the reset is a small hole about a 1/4 inch from front of unit on bottom it says reset withan arrow pointing to hole
Dec 28, 2007 | Tomtom GO 700 GPS Receiver
Nextar X3B GPS Navigation System Logo
Top Nextar GPS Experts
Marvin
Marvin
Thomas F. Schneider
Are you a Nextar GPS Expert? Answer questions, earn points and help others
