Acer aspire mc605 bios 4 beeps check power message
4 Suggested Answers
  • 233 Answers
SOURCE: ACER Aspire- beeping sound - 6seconds when I power machine on
The beeps are telling you there is a hardware failure (POST). The number and length of beeps will give a better indication as to what has failed. Write back with that info and someone on this web site will interpret this for you.
Posted on Jan 19, 2009
  • 1019 Answers
SOURCE: Acer Aspire T690 will not post. When powered on no video
You need to remove The Side-Panel. ( Power Lead out )
locate A small round Button Cell Battery.
As big as a 1p or a Cent Piece. ( Usually silver )
carefully prise the Battery Out For Between 10-15 Seconds, And Replace it. replace the power cable. switch on the computer, the bios has now been reset to it,s factory default settings.
if you are prompted to set date/time enter bios ( F2-del Or esc ) dependant On Bios request.
This Should cure your Problems.
Mike @ Compurepair.
Posted on Oct 16, 2009
parrotheadpc
  • 2600 Answers
SOURCE: trying to update bios get message about a jumper.
Below is the link to the service manual for your desktop. On page 84 is a picture of the motherboard and a list of the components including the cmos jumper location for clearing cmos. It is located under the SATA ports.
http://support.acer.com/acerpanam/manuals/acer/0000/servicemanuals/AST160-ASE360_SG_Book.pdf
Posted on Oct 25, 2009
Testimonial: "got it on the first try thanks "
When I go to the bios settings on my aspire mc605 it won't let me override the onboard graphics settings, I need to disable this to fit a new graphics card
You can disable onboard graphic on BIOS. Make changes to start on discrete graphic not dual graphic ( discrete vga+onboard vga )
Jan 13, 2015 | Computers & Internet
Dead
Hi
THe most common beeps that you will encounter 95% of the time in repairing PC's are:
1 beep - computer ok
continous beeps / long beeps - memory error
continous short beeps - bios boot block/corrupted bios
1 long beep followed by 3 short beeps - video card error
or this might help
you can check out this list
AMI BIOS
1 short - Computer ok
2 short - RAM failure
3 short - Parity RAM failure
4 short - System timer failure
5 short - Motherboard failure
6 short - Keyboard controller error
7 short - CPU failure
8 short - Video RAM failure
9 short - ROM BIOS error
10 short - CMOS read/write error
11 short - Cache RAM error
1 short, 3 long - Memory failure
1 short, 8 long - Video adapter failure
Check board/chipset makers website for more infomation.
AWARD BIOS
1 long - Memory error
1 long, 2 short - Video error
1 long, 3 short - Video failure
Continuous beeps - Memory or video failure
note that AWARD relies on motherboard manufacturers to develop their own beep codes - the above are only their own internal codes. You will need to refer to your own manual for an explanation of precise codes.
Standard IBM beep codes.
No beep - Power supply or motherboard failure
1 short - System is ok
2 short - POST error (code displayed on screen)
Repeating short - Motherboard failure
1 long, 1 short - Motherboard failure
1 long, 2 short - Video display adapter failure
1 long, 3 short - Video display adapter error
3 long - Keyboard error
Pheonix beep codes
1-1-3 CMOS memory failure
1-1-4 BIOS failure
1-2-1 System timer error
1-2-2 Motherboard error
1-2-3 Motherboard error
1-3-1 Motherboard error
1-4-1 Motherboard error
1-4-2 Memory error
2-x-x Memory failure (any number of other beeps)
3-1-x Chipset error (any number of other beeps)
3-2-4 Keyboard controller error
3-3-4 Video adapter failure
4-2-4 Expansion card failure
4-3-4 Time of day clock failure
4-4-1 Serial port error
4-4-2 Parallel port error
4-4-3 Math co-processor error
pls rate as fixya if it helps. thanks
Jul 04, 2008 | Acer Aspire 5100 Notebook
Acer aspire 1600 four error code on pre boot then
Please reseat your RAM, and your CPU. Also check that the CPU is locked tight and that the RAM is seated properly. Run off A/C without battery then test with Battery only then with A/C on and battery connected.
May 22, 2010 | Acer Aspire 1604LC PC Notebook
Will not boot to operating system or the bios. no messages and no beeps
You probably have a bad power supply or one of your components is bad. I don't have enough info to point to anything specific, but here is some ideas you can try.
1) unplug all components internally but the power supply and check for bios beeps. Not the front panel wires though.
2) swap power supply or check with voltmeter for +5vdc, +12vdc, and -12vdc.
3) check for operation of fans attached to motherboard.
4) most likely suspects are motherboard, processor, or power supply.
Nov 16, 2009 | Acer Aspireā„¢ T180 PC Desktop
Acer Aspire One continuous beeping at power on, until Windows screen comes on
Need to check the BIOS beep codes but I'm fairly sure that continuous beeping on boot is a display adaptor card issue. If you don't see anything on the screen until that point it may be something is set wrongly for the display within BIOS and it can't sort it out until Windows takes control of the system.
Oct 11, 2009 | AcerPower Sn PC Desktop
Bios reset on a acer aspire 1640z
To reset the bios in a laptop you need to unplug the power supply and remove the battery. Once you do that press and hold the power button for 45 seconds then put the battery back on and plug it in and then try starting it. Everything in the bios will be reset to the factory.
Good Luck
May 04, 2009 | Acer Aspire 1640Z Notebook
BLANK SCREEN-ACER ASPIRE 3661
You can check the little indicator light on the notebook.
If the hard drive was dead, that wouldn't cause the display to go blank.
If your problem was with your hard drive, you would still get the BIOS screen and then a message about being unable to load an operating system. So, I doubt if that is the problem.
My guess is that you have a relatively serious motherboard, video card, memory, or CPU problem.
When you turn it on, does it beep ? If so, how many times ? You can translate these beep codes at: http://networking.ringofsaturn.com/PC/beep.php __________________
Oct 22, 2008 | Acer Aspire 5610-4648 Notebook
Display problem
The most common beeps that you will encounter 95% of the time in repairing PC's are:
or this might help
AMI BIOS
AWARD BIOS
Pheonix beep codes
1-1-4 BIOS failure
1-4-2 Memory error
the vga board has failed, its a very common problem in acer laptops, you can get a replacement part from www.acerparts.com im not sure if they ship into us but for europe thats where I get my parts.
my acers vga failed two times, ones within warranty and 12months after that, I have to say that acer products are really bad quality, I'm not sure about the latest models but from what I've seen the vga chipsets have real issues with the motherboards and keep failing over and over again.
I have not looked inside your model but the vga is either integrated into the motherboard = that means the repair will cost the whole motherboard, better to buy a new one.
if your model has a removeable vga like mine does, then you can consider changeing it to a new one. contact acer parts.
One of the covers in the bottom is the memory, one is network and last one I don't remember.
here are the contact details if your acer is out of warranty
http://www.acerparts.com/contact_us.php
The parts for your model are at http://www.acerparts.com/index.php?cPath=561_562_1064
you will have to contact acer parts directly, it may be that the vga is build into the motherboard or then the vga parts are not listed.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Jul 29, 2008 | Acer Aspire 5570-2758 Notebook
Computers & Internet Logo
228 people viewed this question
David Payne
David Payne
