Question about Kenmore Washing Machines
Kenmore 28002010 lid lock light flashes
Replaced the lid lock switch. Now it powers up but only clicks a few times from behind the control panel and the light keeps flashing
SOURCE: My Kenmore Catalyst's control panel is flashing "PF"
PF means power failure
the power must have went out in your home some time during the day or night
Posted on Feb 16, 2008
SOURCE: all lights flash - machine does not work
the machine is unstable as in you have to big of a load in or uneven load it happened to me when i put really heavy bath mats.
Posted on Jul 25, 2009
TheMobilian
  • 8220 Answers
SOURCE: I have a Kenmore Elite 110.26962502 and need to remove lid.
Once those are removed you flip up the whole control panel. You do not remove the end caps on that particular washer. Here is some PICTURES
Posted on Sep 07, 2009
blueextc3221
  • 15935 Answers
SOURCE: Lid lock light beeping continuously and flashing
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Posted on Sep 18, 2010
jamesstoner
SOURCE: want to disengage lid lock on maytag centennial
I had the same problem. The lid lock assembly is broken. If you are under warranty get it replaced. If not remove the top of the washer and take out the switch assembly. The 4 wires going in are Yellow, Red, White, and Blue. If you short the white and blue together, the washer thinks the lid is closed. If you short the red white and blue together the washer thinks the lid is closed and locked. The yellow is only there to activate the electromagnetic switch.
Disconnecting the switch assembly will not work.
The electromagnet locks the lid and it also unlocks the lid. It is not a matter of cutting the power to the magnet.
Installing 2 switches that connect the red white and blue is the best option if you want to remove the lock.
The first switch should connect the white and blue. (LID CLOSED)
The second should connect the red to the white/blue connection. (LID LOCKED)
After that the lid should work.
Please post a follow-up if this works for you.
GOOD LUCK
Posted on Aug 06, 2012
Won,t work just flashing blue light
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitThe Kenmore Elite HE3 is a washing machine by Kenmore. ... Whatever cycle I choose, the light just flashes and holding the start button ... I don't seem to have a black pin....the normal wash button just keeps flashing and won't let me start or .
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors Red Lid Lock light flashing intermittently when you try to start a cycle. ... Mode -- Lid Lock won't work, nor will anything that requires the lid to ... Once the lid has locked the second time, the washer ... shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors ...
Nov 26, 2015 | Washing Machines
LID LOCKED LIGHT ON AND LID WILL NOT OPEN
I had a Kenmore washer for a few years, and the motherboard (control module) that turned everything on and off, locked the lid, controlled the various settings, etc. would often blink and flash like a spaceship. I replaced the unit and three months later it was defective, right after the 90 day warranty was up. Don't, and won't, own one anymore. Anyway, you might want to try a "hard restart". This is a computer board, sometimes removing the electricity letting it sit for an hour or two, push in the start button with the unit off, and then plug the washer back in might help. If that doesn't work, the switch may be defective and need to be replaced. Hope this helps.
Keith
Nov 22, 2015 | Kenmore Washing Machines
Lid light flashing
OK have you tried unplugging the machine for 15 minutes and then re-plug in? This will reset it. If it still does this then the switch (little hole with white rubber depression on side where lid closes) is bad and needs to be replaced. It is a safety warning indicator telling you the machine is not Locked! It is annoying for a reason cause you can get hurt!
Jan 16, 2014 | Kenmore Washing Machines
My kenmore washer will click on and off but will not start
It is a problem in the electronic control board. It must be replaced by a technician.
Dec 15, 2013 | Kenmore Washing Machines
How to bypass lid lock control on kenmore elite oasis type 581 washer model 110.28032701
there isn't any way to bypass this type of lid switch as in the old 2 wire type lid switches,as the 5 wire type lid switch you have has to be connected to the control board located behind the control panel,it has to see the lid is closed and sends a magnetic signal to the control board to start the wash cycle
Oct 29, 2012 | Washing Machines
Kenmore washer model #21302 lock on light is flashing, will not start
Kenmore top load washer 21302, the sensor light is on and the lid lock light is on with a clicking noise. What could be wrong with it and how do I fix it?
May 21, 2012 | Kenmore Washing Machines
Washer flashing dl on the screen
"dL" indicates Door Lock Failure: dL flashes if the following conditions occur:
Door lid is not closed completely due to interference.
Wash media buildup is preventing the lock bolt from extending.
Machine/motor control detects open door lid switch when attempting to lock.
Machine/motor control cannot determine if door lock is in a locked state.
Check for lock interference with lid or lock bezel
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
76 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
