Question about Dryers
LG dryer DLE2350R will not heat up. Checked vent and fuse they are okay. If heating element where is it located?
ronpar
  • 27 Answers
SOURCE: Whirlpool Duet Dryer - Working but no heat
it sounds like your heating element is gone bad. there is no heat if they burn out or get corroded
Posted on Jun 29, 2008
AlmostBob
  • 550 Answers
SOURCE: Replacing Heater Element in Roper Dryer
before you replace the heater most common cause of heating failure is burn out of the thermal cut-out. (also called thermal fuse, overtemp cutout and probably half a dozen other names) These are a small screw on device on the exhaust duct, when exhaust air reaches too high a temperature, like a blockage, they fail before a fire.
examin the exhaust duct inside the dryer for devices that look like this 641e982.jpg or like this dd7fd44.jpg with wires connected to the terminals. there may be 2(hi lo), test with a ohmmeter -conductivity good, no conductivity replace.
there are only a few different kinds the local parts guy will have them all. take the dud one for him to match.
Posted on Aug 27, 2008
SOURCE: Maytag dryer: pye2300ayw
I had the same problem last month. My heater element broke in two places. This created an electrical open that prevented the heater from functioning. I replaced the heater element and my problem was solved.
In order to check your heater element: With the machine unplugged, disconnect one wire to the heater element and then use an ohm meter or multimeter across the heater element lugs to read resistance. Infinite ohms = open circuit.
Posted on Nov 04, 2008
hunter19_46m
  • 7482 Answers
SOURCE: LG Dryer won't dry, no heat.
The heating coil is not too big of a problem to replace if you are mechanically inclined and have tools to do the job.
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the saftey of overheat from the machine.
Good Luck,
Hope this helps
Posted on Oct 17, 2009
  • 45 Answers
SOURCE: lg dryer dle5977w heating element dryer
Yes the heating element is out.
Posted on Apr 28, 2010
Lg dryer keeps blowing thermal fuses we have checked the thermostat and the element all have continuity
The thermostats (outlet and on element case) can still allow the heat to go to high, restricted airflow will also cause them to go.
Jan 31, 2015 | LG DLE3777 Electric Dryer
I have a Sears dryer, model # 110.87562601.
#1 reason of dryers going bad is woman's bra's....the medal sewed in the cloth itself for support comes out and goes into the small holes and hits the heating element on both sides and shorts it out...Change the heating element....It's in back of dryer.
Oct 06, 2017 | Kenmore Dryers
Lg dlex7177wm heating element
If the dryer doesn't heat, but the drum turns, check the thermal fuse(s). The thermal fuse protects the dryer from overheating and helps to prevent fires. If the thermal fuse is blown, it will have to be replaced.
If the dryer doesn't heat, the element assembly should be checked for continuity. The heating element assembly cannot be repaired and must be replaced if defective.
This is a specialised job and should only be attempted by technically competent persons.
Mar 13, 2014 | LG DLEX7177 Dryer
Electric LG DLEX2801W (steam dryer) not heating.
Hello & Welcome to FixYa
If you have already cleaned the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair. It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test it for continuity before replacing. Please get back to me if you have any other questions.
Kevin
Dec 02, 2011 | LG DLEX2801 Electric Dryer
I have replaced the heating element,thermal fuse, and checked the heating element thermal cut-off. the dryer still won't heat. Checked all wire connections.
okay, sounds like it should. I would check the outlet to ensure I have the 220 volts, if I don't then this is the problem. If I have the 220 volts then i would remove the vent hose and feel if there is any hot air coming out. If not then I would say it may be something in the controls and would investigate behind the controls for a loose or burnt wire. Hope this helps Tim
Aug 28, 2010 | Dryers
I have an similar problem with my Amana Dryer LEA30AW.
First Clean out your filter, Assuming the element is okay and cut-out are fine it should run okay, you could also try running it on low heat will take a bit longer but hey if it works great..Good luck
Oct 01, 2009 | Dryers
Will not heat
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
Jul 16, 2009 | LG DLE7177 Dryer
No heat on dryer just air.
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
3. Thermal fuse
Jul 12, 2009 | LG DLE2532W Electric Dryer
Whirlpool electric dryer that will not heat up, dryer comes on and turns, but no heat
2. Heating element
3. Thermal fuse
Jun 18, 2009 | Whirlpool Dryers
Kenmore Dryer not heating
thermal fuse kit.it is blowing due to improper ventilation.their is a clog somewhere from dryer to where dryer vents outside.thermal fuse is located at top of your elemnt cage.you will replace the thermal fuse and your high limit fuse at the bottom of the elemnt cage.but have your venting checked or swept out.
Mar 09, 2009 | Dryers
Dryers Logo
41 people viewed this question
Top Dryers Experts
