Question about Electrolux Vacuums
Electrolux Nimble Vacuum Clogged Base hose
I've had the nimble for a few months now and my problem is the entry way on the base of the Vacuum where the brushes are is clogged. I've tried using another vacuum to **** out the blockage but it seems to go up into the area where the motor is and I cannot stick a snake or wire to clear the blockage. Will removing the hexagonal screws allow me to access the hose? The hose that has the 1 screw is the hose that is blocked to be exact. I cannot reach any more into it to pull out the blockage, any advice on how to do this??
reddevil6
  • 1673 Answers
SOURCE: Eureka the boss vacuum cleaner brush won't turn
Take the top cover off, remove the torx screws on each side of the motor housing, remove the screw on the back holding the hose, then you just have to compare the 2 before putting on the new one. Can't tell for sure without a model number to get you a picture. What isn't on the new base, take off the old base and put it on the new one.
Posted on Mar 02, 2008
  • 86 Answers
SOURCE: Clogged Hose
Hi, this sounds like you have something stuck quite firmly in the hose!! If you use a good sturdy stick then you should be able to move the object without any damage to the hose. Check along the outside of the hose first just incase something has pushed its way out of the hose wall.
Get back to me.........
Posted on Jan 02, 2009
SOURCE: hose is clogged, can't remove hose.
hello,i have a 2996AVS,i have worked on many vacuums like this,if you look down on the top cover where the wheel height knob is,on the far left & far right side's there is a chrome phillips head screw on each side,remove these two screws,the top cover will lift off,just pull up on the back part of the cover and it will lift off,then you can see where the hose attaches,there is a small slot where the hose clips in,use a small flat head screwdriver or pocket knife and insert it in the slot,there is a raised lip on the hose you can see, slide the driver in the slot right on top of this raised lip and slide the small screw driver in until it is under the slot,this will pry up the slot and you can pull out the hose from there,on the rear of vacuum there is a clear plastic attaching cup that locks the hose to the unit,just squeeze the two clips together and pull and this section will come off,then you can clean out end to end of hose,just line them up and push them back in when your done,then reinstall top cover and tighten screws,also check your belt why you have the cover off,it it ffeel's loose or hardened,or slick and shiny on inside of belt,this will cause thr roller brush to slow down or stop ,hope this helps you. r.man
Posted on Jan 29, 2009
SOURCE: Re: model 3522-5 Bissell proforce bagged vacuum hoses clogged
Worked perfectly. Thanks, jade_greeney. We thought we were going to have to shell out $100+ for a new vacuum.
Posted on Jan 12, 2010
askdyson
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: Dyson stowaway hose seems clogged..
    Sorry to hear you're having a problem with your Dyson. You should find the issue easy to resolve - please visit the Support section of our website and follow these simple steps to make sure everything is correct with your machine:
    http://www.dyson.com/support/help.asp?article=1009&product=DC21-MOTORHEAD_US
    It's also a good idea to wash your filters, which should be done every 3-6 months. You can see a video guide demonstrating how to do this here:
    http://www.dyson.com/support/help.asp?article=1011&product=DC21-MOTORHEAD_US
    If you've tried these steps and are still having difficulties, please get in touch with us free, on 08002980298 (UK), or 1866MYDYSON (US), so we can run through some checks over the phone.
    Kind regards,
    Jack
    Dyson Customer Service
    Posted on Jun 28, 2011
    Electrolux EL/8602a. How can I replace power cord?
    take lower body covers off to access end of power cord , un clip the 2 wires remembering the proper routing and colors, hook up your new cord and re assemble
    below is a link to new power cord
    Electrolux Nimble EL8602 OEM electric power cord replacement part cable...
    Jan 30, 2016 | Electrolux Vacuums
    How to replace el8602a power cord
    Electrolux Vacuum Cleaner EL 8602A How to replace the ...
    www.manualsonline.com/.../vacuum.../how-to-replace-the-power-cord-o...
    Question About Electrolux Vacuum Cleaner EL 8602A. How to replace the ... How toreplace the power cord on Electrolux EL8602A. Asked by gerry nickel on ...
    Rewiring the Power Cord for the Electrolux Model G ...
    ? 4:27
    https://www.youtube.com/watch?v=4uqNa7mVBO8
    Jan 30, 2012 - Uploaded by Jayson1940D14
    Rewiring the Power Cord for the Electrolux Model G ... How tochange the Electrolux 725 Suspension Plate - And Get Access To The Motor ... Brown Vintage ELectrolux Canister Vacuum Cleaner 1401-b - Duration: 0:17.
    Electrolux Nimble Upright Vacuum, EL8602A - YouTube
    ? 3:49
    https://www.youtube.com/watch?v=-anwdD4fK-o
    Nov 11, 2014 - Uploaded by Michael Callender
    Electrolux Nimble Upright Vacuum, EL8602A Best Price ... Dirt Devil UD70095 Power Reach Multi Cyclonic Pet Bagless Upright - Duration: ...
    Jan 30, 2016 | Vacuums
    Brush not turnning
    The brush roller is driven by a belt installed on the motor shaft. The belt could be broken or off the shaft. The brush roller could be clogged inside the end caps with debris which prevents rotation. To solve the debris problem, it will be necessary to remove the belt from the motor shaft, then note the orientation of the end caps and remove the brush roller. Next, remove one end cap and check for clogging material. Remove the material. Slide the brush roller shaft away from the end of the brush roller to check for clogging material at the opposite end. Remove the material. Slide the brush roller shaft back into position and reinstall the end cap. Reinstall the brush roller in the correct position. Reinstall the belt. Check for proper rotation of the brush roller.
    Apr 08, 2014 | Electrolux EL8905A Nimble Brushroll Clean...
    Electrolux Nimble attachment has no suction
    This is a problem I have come across many times. You have not reached the clog yet. You will have to take this totally apart and find where the clog is and remove it.
    Jan 29, 2014 | Vacuums
    Belt replacement
    Disassemble the power head, and you will see how to replace it.
    Mar 15, 2013 | Electrolux nimble EL8605A
    El8602a thermal switch
    need more info. have you check the belt?
    Feb 13, 2013 | Electrolux Nimble El8602a
    How to repair roller on Vacuum cleaner
    it migh be the belt.stretched and hardened from heat replace and try again
    Feb 02, 2012 | Electrolux Vacuums
    Vacuums Logo
    Top Electrolux Vacuums Experts
    Mack Baxter
    Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
