Question about Bosch 24 in. SHU53 Built-in Dishwasher
Touchpad--No Response The touch pad and Countdown timer display will NOT respond except when the Rinse Only pad is pressed. The Countdown timer displays "9" when this pad is pressed. As expected the light and display turn off after 30s. If after 30s or longer the Start/Cancel pad is pressed with the dishwasher door closed, then the Countdown timer displays "2H" and the dishwasher runs through the ?Auto Clean? or ?Heavy Wash? cycle. Not sure which since neither pad is lit. Is the problem the touch pad or the control board? Please advise. Thanks.
    Problem Solver:
  • 7 Answers
The "2H" is an error code indicating the control panel needs to be replaced.
Posted on Jul 29, 2009
See the notes about cycles taking forever. The relay that controls the heating element commonly gets warm enough to melt the solder around the connection, and the internal water heater stops heating. The "2H" indicates how much time the onboard computer thinks it will take to wash the load, based on previous loads, but if the last cycle was longer than 99 minutes, it shows 2 Hours. Repairing the controller board (or replacing it) should solve the problem. This is such a common problem, Bosch should have had a recall, but didn't.
Posted on Aug 05, 2009
Set clock and be able to tell am from pm setting
The Clock uses a 12-hour cycle with a.m. and p.m.
1. Check that the oven is off.
2. Press CLOCK.
3. Press TEMP/TIME "+" or "-" arrow pads to set the time of day, including a.m. or p.m.
4. Press CLOCK or START
The Timer can be set in hours or minutes up to 12 hours and 59 minutes.
1. Press TIMER.
2. Press TEMP/TIME "+" or "-" arrow pads to set the length of time.
3. Press START to begin the countdown. If enabled, end-of-cycle tones will sound at end of countdown.
4. Press TIMER twice to cancel the Timer. Do not press the CANCEL/OFF keypad because the oven will turn off.
5. If the TIMER is running, but not in the display, press TIMER to display the countdown for 5 seconds
Delay Start:
The Start Time keypad is used to enter the starting time for an oven function with a delayed start.
Hope this answers all you questions about your stove.
Jaye
Nov 04, 2013 | Whirlpool RF263LXTQ Range
Dishwasher won't run
It is the touchpad that is faulty.. coz if the control board is faulty the unit may not respond to any button at all.. So just get a new touch pad.. If you want to buy it online.. then let me knnow i will get you the link..
Mar 13, 2008 | Kenmore 16372 / 16374 / 16379 Built-in...
Buttons on microwave
testing every step and fix it. God bless you see the diagram attached
Microwave Buttons Don't Work
Touchpad and Control Panel
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad
If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board
If the microwave buttons don't work the user control and display board are most likely defective and will need to be replaced. If some of the buttons work and some don't, it is more likely a touch pad problem and the touch pad will need to be replaced.
Main Control Board
If the microwave buttons don't work the main control board is most likely defective and will need to be replaced. If some of the buttons work the touch pad is likely the problem. If none of the buttons work the problem may be in the main control board.1_24_2013_5_23_47_pm.gif1_24_2013_5_24_54_pm.jpg
Jan 24, 2013 | Goldstar MV-1501 Microwave Oven
The touch pod on my microwavw 9je635 wont do anything when i press the boutos for timing fuction
follow this steps and fix it. God bless you
Touchpad
Main Control Board
If the microwave buttons don't work the main control board is most likely defective and will need to be replaced. If some of the buttons work the touch pad is likely the problem. If none of the buttons work the problem may be in the main control board.1_24_2013_5_54_53_pm.gif1_24_2013_5_55_10_pm.jpg
Jan 24, 2013 | GE JE635 Microwave Oven
Watre fills for 1 sec than shuts off timer runs shows f 21 or f 31
F21 F 22 CCU /touchpad/LED assembly unable to transmit/receive data to/from the CCU central control unit
Possible causes/procedure:
1. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the
touch-pad/LED assembly and Central Control Unit (CCU).
Nov 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The touch pad inside the fridge will not arrow down how can we resovle this/
its most likely a board related problem...anytime the touchpad does not respond ..its usually the board..there are exceptions and those are a defective touchpad....do not see many of those however...Bruce Denton
Dec 12, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a kenmore elite calypso that does not respond to most key presses, except when pressing "normal" the "whitest whites" button lites, and when you press "wool/silk", the "jeans/colors" lights, "buly...
Is the panel lock on??
Hold down the power and delay start button at the same time. In about 3-4 seconds a beep will occur and the red key lock will turn off.
If this reset does not work - unplug for 15 minutes and re-try.
If unplugging for 15 minutes does not reset the controller -
your Main Controller board or touchpad has Failed.
Upon inspection you may have a visible sign one or the other has a burned component on it.
CLICK HERE to see the controller board.
The touchpanel is available in white, graphite, or bisque. CLICK HERE
The Touchpanel is the culprit on 95% of these machines in my experience.
I believe (hard to remember without having the machine right in front of me) there is a fuse you should check on the Motor Controller board that may have popped when the touchpad started acting up too.
Choose wisely - grasshopper - as purchasing and installing the Touch panel will equate to almost 1/2 of a new appliance with a warranty :D
Thanks for using FixYa!!
Aug 24, 2009 | Kenmore Elite 45986 Front Load Washer
Touchpad no response at all
CHECK CONTROL CIRCUIT AND RELACE TOUCH PAD..
Nov 06, 2008 | GE JVM1650 1000 Watts Microwave Oven
Lapptop touch pad not responsive
there is an option to enable/diable touch pad by clicking combination of fun+f5 or f6 or enable it from setup.
Oct 21, 2008 | Computers & Internet
Bosch 24 in. SHU53 Built-in Dishwasher Logo
581 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
