Question about Whirlpool MH1150XMQ Microwave Oven
My Whirlpool over the range microwave works but
My Whirlpool over the range microwave works but the food is not heating
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
xz
Posted on Sep 29, 2010
MicrowaveSvc
  • 9098 Answers
SOURCE: Over the range microvawe Whirlpool MH6140XKQ1
Either a shorted high voltage rectifier diode or magnetron.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
I'm confident this will be a FixYa! We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 28, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave doesn't heat
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
The diode is a fairly cheap fix, and the mag will cost more.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
(if it's not shorted, it's probably okay)
http://www.gallawa.com/microtech/xformer.html
Posted on Dec 25, 2008
breddi2
  • 126 Answers
SOURCE: Ge Microwave space saver over range working but
It is a good possibility that the stirrer has failed. In the top of cabinet is a round cover,there is a small round plug in the edge of it,pry plug out and put it in safe place,rotate the cover < twist locks > gently let it down and stirrer will be either setting on cover or still attached. If you notice any damage< it is a round aluminum disc that is flat > then you need a new one. If you don't see any damage put it back in < put in hole and turn until you feel it line up with shaft and push into place,< gently >.Make note of position and put cover back on < stirrer does not lock on shaft so you have to hold it up until you get cover under it in most cases. Run a short cycle and remove cover to see if it turned at all. If not the motor is bad < turns stirrer during operation>. This is the first time that question has been asked of me and it is the only thing that I can think of if it heats glass and not food.
Posted on Apr 22, 2009
  • 670 Answers
SOURCE: Bosch Microwave HMT8625 range - Microwave not working
Sounds like the magnetron has failed. There are some high voltage circuits that feed the magnetron and you can potentially get hurt if you don't know what you are doing. Would recommend you have it serviced by a professional if you want it fixed, otherwise look for a new one since the cost of repair can come close to the price of a new microwave oven.
Posted on Dec 24, 2009
BNUTZBCRAZY
  • 130 Answers
SOURCE: microwave not heating items, also range vent not operating
the unit inside the microwave that heats called the "magnetron" has gone bad or the circuits that power the magnetron and other parts of the unit have failed. if its under warranty still, send it back to the manufacturer. if not you can call some repair shops and see how much it would be to service it, but its most likely going to be cheaper to purchace a new microwave since they are relatively cheap these days, they dont make them long lasting anymore, they are a "disposable" product these days
Posted on Jan 15, 2010
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
Why did my whirlpool microwave display quit, everything else works. less than 2 years old
Over the range ovens of all brands are prone to failure of the electronics due to heat and steam from the food that's cooked on the range below them. It's not extremely common, but you do see more of these types of failures on these as opposed to counter top models.
Apr 26, 2014 | Microwave Ovens
My over the range microwave will not heat anything anymore. It will turn on but the food does not get cooked or warmed.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 06, 2011 | Whirlpool Microwave Ovens
Our Whirlpool over the range microwave makes a clicking sound for a few seconds then shuts the microwave off. The microwave is unusable. The sound seems to be coming from the control panel.
If the cooling fan is not working, that would explain the shutdown problem. The function of the fan is to cool the magnetron down when it is warming or cooking the food, if the fan fails to run, the thermal fuse will detect heat rise causing a shutdown with in 5 seconds or more, the clicking suggest fan issues. I would recommend a whirlpool technician to go through the system.
Jan 27, 2011 | Whirlpool MH7140XF Microwave Oven
Microwave not heating items, also range vent not operating
Jan 14, 2010 | Whirlpool MH3184XP Microwave Oven
Microwave heating problems
Many over-the-range microwave ovens suffer from intermittent problems caused by excessive moisture from the range/stove entering the microwave cabinet and collecting on the circuitry. Often the problem is with one or two simple connections that may need tightening or soldering. But, to repair these components, the microwave cabinet needs to be opened. So we recommend that you seek the assistance of a qualified appliance repair technician.
Oct 03, 2008 | Whirlpool Microwave Ovens
MICROWAVE NOT HEATING
I have the same problem. Everything seems to work except it doesn't heat up food.
I remember last time when it was working. I pressed the start botton before I closed the door. So it didn't start automatically, and I pushed start and it worked(it still heat up the food), but it doesn't work now. Help Please!!!
I have a Whirlpool Gold GH5184XPQ.
Thanks in advance
Aug 27, 2008 | Microwave Ovens
Whirlpool microwave mh6150xls makes noise while running
The oven may not be seated properly. check the bushes at the bottom.
Apr 07, 2008 | Whirlpool MH6150XMS Microwave Oven
Whirlpool MH1150XMQ Microwave Oven Logo
677 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
