Question about Encore ENPS-2012 (ENPS2012) Print Server
Encore ENPSWI-2012 not "discovered" by Encore Config Utility
Encore ENPSWI-2012 both on wired and wireless mode is not "discovered" by Encore Config Utility under Windows XP and VIsta.
Any suggestion?
2 Suggested Answers
Ezrahite
  • 2632 Answers
SOURCE: Have connected an Encore ENHWI-N3
Welcome to Fixya. If you want to connect your windows 7 computer to the Encore ENHWI-N3 router you need to check if the settin is correct. You need to browse the router settings page and manually add the network on your Windows 7 Computer. Check if the Security and the Network key is the same as on the router.
Manually Add the settings on your computer. go to Start, Control Panel, Network and Sharing Center, At the left of the screen click on Manage Wireless Networks, Then remove the save networks on the computer then click Add. Then Select Manually Create a Network Profile
Make sure that the Security Type, Encrytion Type and Passphare or Network Key is the same with the router. Put a check or tick on Start this connection automatically.
To access the router page just open a browser then type 192.168.0.1, the Default username is admin and the password is admin.
Click on Wireless then Security Tab. If the Security is WPA or WEP make sure thet you will save the same settinmoz-screenshot-2.pngmoz-screenshot-3.pnggs on the computer. See Image below.
WEP
WPA
On the encryption make sure if it is TKIP or AES and save the settings on the computer. You can also refer to the manual below.
Encore ENHWI-N3 Manual
If you have questions please let me know. Thanks for using Fixya.
Posted on Mar 09, 2011
Can't find the PIN of this product
Good morning. There is no PIN to find on the router. You get the PIN from the Wireless client and enter into the router setup screen.
The wireless router supports two types of WPS, the WPS via Push Button and WPS via PIN code. If you want to use the Push Button, you have to push a specific button on the wireless client or in the utility of the wireless client to start the WPS mode, and switch the wireless router to WPS mode. You can simply push the WPS button of the wireless router, or click the 'Start to Process' button in the web configuration interface. If you want to use the PIN code, you have to know the PIN code of the wireless client and switch it to WPS mode, then fill-in the PIN code of the wireless client through the web configuration interface of the wireless router.
Here is the link for the Owners Manual for your router..
http://www.encore-usa.com/us/sites/default/files/product_documents/ENHWI-N3_UM.pdf
Hope this helps..
Nov 03, 2012 | Encore ENHWIN3 Wireless Router
Tip
Troubleshoot Dell Bluetooth that does not work
<p>According to the official website of the Bluetooth wireless technology is used to transfer data over short distances through the use of radio broadcasts shortwave and mobile devices to send. Dell Bluetooth adapters are compact, wireless devices used for keyboards, mice, printers and communication headset to connect. Sometimes no sign of the adapter to be read as the adapter in wrong mode in Windows 7, XP or Vista operating system. Dell suggested the installation of a utility that will re-configure the wireless adapter mode if the Bluetooth does not work. <br /> <p><br /> <p>1. Insert the Bluetooth adapter on your electronic device or computer. <br /> <p><br /> <p>2. Go to the site of Dell's technical support for the utility to install your adapter mode will change. In "Support Tools", select "Hardware" and select "Bluetooth Devices" in "a problem" (or see link in Resources below). Under-350 Bluetooth, click the download link to start the installation. <br /> <p><br /> <p>3. When the download box appears, choose "Save File". In the Save As window, again select "Save." Check the box next to "Close this dialog" with the installation. <br /> <p><br /> <p>4. The installation is complete, select "Run Program". Follow the instructions on the screen can. <br /> <p><br /> <p>5. Avoid close all boxes when the program runs automatically. The utility will begin to reconfigure the device from the Bluetooth adapter. Restart the computer when the program is completed. <br /> <p><br /> <p>6. Try using the Bluetooth device. If operational problems occur, contact a Dell Support representative for assistance. <br />
on Jun 26, 2011 | Computers & Internet
I installed this router on repeater mode, connection to existing router and signal is perfect but have no access to internet... in the access router the internet access is perfect. please let me know how I...
this is from Encore-usa.com
How to use ENHWI-N3 / ENHWI-N34D / ENHWI-2AN3 / ENHWI-2AN34D / ENHWI-3GN3 as a Repeater?
  • For Advance Users, you can download this document.
  • The reason why people use a Encore wireless repeater is because some wireless remote client computers are out of range from the main network's access point (wireless router), or the wireless client is in the dead spot or the device you want to share to the network have no wireless interface card.
    The function of a wireless repeater is basically to extend the wireless signal coverage. Wireless repeater does not authenticate, screen, secure, connect to the internet, give IP address to clients, broadcast names, etc., these are the wireless router's job. Repeater only repeats what the main wireless router does to the wireless clients.
    Checklist:
    • You should know the wireless security type of the existing wireless AP/router, is it a WPA, WPA2 or a WEP?
    • The wireless security key, or password or passphrase of the existing wireless router
    • Your existing wireless router's SSID
    • We recommend that the existing network you are about to add the Repeater on have a DHCP server running and able to lease IP address to all network clients. If you are not sure about this, please ask your ISP or the person who installed your network.
    Hardware Checklist:
    • Computer with wireless device turned off. This is only to set up the repeater, once finished the wireless can be turned on again.
    • The computer must have an available RJ-45 network interface card and web browser installed.
    • A working wireless router or Access Point with one available RJ45 port
    • RJ-45 UTP/TP Ethernet LAN Cable
    • The Encore Router is set to factory default. If your Encore Router is brand new and just pulled out of the box, no need to reset. If changes were made to any settings to the Encore Router before, make sure you "hardware reset" the Encore Router to the factory default settings. Check the User's Manual on how to "hardware reset" the router.
    PROCEDURES:
    1. Hooking up hardware connections:
    1. Both PC or Laptop and the Encore Router should be turned-on.
    2. Disable the wireless client from your PC or laptop computer (if not done so)
    3. Connect the Ethernet cable to the PC or laptop computer and the Encore Router. (This can be done while PC computer and router are turned on.)
    2. Switching mode from AP Mode to Repeater Mode
    1. Using your computer's web browser such as Internet Explorer or Safari Firefox, enter 192.168.0.1 to the address field then hit enter. You should see the Encore Router's User Interface screen still in the AP Router Mode
    2. On the upper right corner of the user interface menu, click on the drop down menu and select "Repeater Mode". Click the "OK" button to the warning box. Wait around 35 seconds until your screen comes back to Encore user interface screen, this time the screen is now in the Repeater Mode. If for some reason you were asked by the repeater to enter the username and password, enter the default username and password (admin/admin) and your Encore Router is now in Repeater Mode.
    NOTE:
    As of this moment your repeater is not connected to any router or network. It has to be configured further to be able to be connected to your current network and access point router.
    3. Connecting your Repeater to your existing network access point or router:
    1. As soon as the Encore Router switched to the Repeater Mode, you should be able to see the same Utility Screen with fewer selections on the left pane.
    2. From the Main Menu screen click on "Wireless" located on the left pane.
    3. Click on "Site Survey" button, a new Window dialogue box will pop up showing a list of Access Points reachable by your Repeater
    4. Check your existing network's access point SSID then click on the radio button that corresponds to your access point router then click "Connect" button.(If you can't find your existing AP router, click on "Refresh" repeatedly until your access point show up, or your location is too far from your existing AP router).
    5. Click on the "Encryption" drop down menu, select your existing access point wireless security, enter your existing router's wireless security key or passphrase then click "Apply". If you get a FAILED message, repeat this procedure again, a wireless hiccup might be interfering, otherwise you now have a working Repeater.
    6. Check your repeater connection by going to your internet browser and open a web page of your choice. If successful your new wireless repeater is working.
    7. Disconnect the Ethernet cable and setup your computer back to its original wireless settings. At this stage, the Repeater is now invisible to any wireless client computers. When connecting a new wireless client within the repeater's wireless range the process is the same as there is no Repeater device at all, the SSID of the wireless router will just be extended in range around where the Repeater is physically located.
    4. Connect your remote wireless client to your wireless router
    1. Using your wireless client utility program, look for your existing router's SSID and connects to it, if this is a new client you will be prompted with the wireless security key. Your repeater is invisible to all wireless clients. All it does is to repeat the wireless router signal as it is to extend its range. Once you have converted the Encore Router to Repeater and successfully connected to your existing router there will be no more configuration needed to the repeater. If you happen to see two identical SSID's of your existing router, this means your wireless client is within the same range of your existing router and the new wireless repeater, then your client don't need the repeater's service.
    NOTE:
    If you are using Windows 7 and your existing access point security wireless is set to WPA2 (AES), make sure your Windows 7 wireless security type properties is set to WPA2-Personal. To check go to Windows 7 Wireless Network Connection, look for your REPEATER router, right-click on it then click Properties, check the settings in the "Security" tab.>
    NOTE:
    When checking the wireless site survey, you may see two routers with the same SSID (names), these are your Access Point and the REPEATER tied together. This also means you are within the reachable range of both Access point and REPEATER.
    5. To check the Repeaters user interface
    At this moment, the Repeater is invisible to any client. The client's IP address is drawn from the DHCP server most likely to be also your wireless router. Therefore the IP address of the repeater is also invisible to the clients. Follow steps below:
    1. Disable wireless connection or turn off wireless in the client PC computer
    2. Connect Ethernet network cable to the RJ-45 port of the client PC computer
    3. Connect the other end of the Ethernet cable to one of the LAN ports of the repeater.
    4. From your computer, set the network card IP address to Static IP Address entering 192.168.0.102, Subnet Mask 255.255.255.0, leave the rest as blank.
    5. Open IE or Internet explorer or any other web browser software and run 192.168.0.1, you should be able to see the Encore Repeater user interface screen. (Changing any settings in the repeater may affect its performance)
    That should help :)
    Christopher
    May 15, 2012 | Encore Enhwi-2an3 Wireless-n Router
    I lost my cd of Encore 802.11n Wireless LAN USB Adapter
    Click here You can download driver and utility from above link. It's in zip format extract it then install. Let me know if you need further assistance. Thanks for using FixYa.
    Jun 07, 2011 | Encore 802.11n Wireless LAN USB Adapter...
    I need an installer for encore ENHWI-G2
    Please Find the below details for Encore 802.11G WIRELESS LAN ROUTER
    Feb 28, 2011 | Encore 802.11G WIRELESS LAN ROUTER...
    Cannot connect my laptop wlan to encore enhgi-g2 with my pc.
    What is the Operating system on the laptop ?
    If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network.
    If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network.
    If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network.
    For MAC you will see the AIRPORT icon at the top.
    Check the wireless settings of the router first . Make sure that you have all the wireless settings of the router. If you are not sure about the settings, then open the router set up and check the settings.
    Click Here
    for step by step instructions on how to connect to the wireless network and troubleshooting steps
    Dec 13, 2009 | Encore 802.11G WIRELESS LAN ROUTER...
    Please help I can't conect to Router MR814V2 with wireless card Encore ENPWI-G2
    On Windows XP, the OS will prevent a connection to an unsecured wireless network such as what you have.
    You can try:
    Double click on the red WiFi icon, click on the "Change the order of preferred networks",  Click on "Add", type in the Network name (SSID) of your router (you can get this by using the connected PC and log in to the NetGear's Webbased Interface), set Network Authentication to "Open", set Data encryption to "Disabled",  OK, reboot your PC.
    Alternately, you can set the PC where the Encore ENPWI-G2 card is connected to manual configured settings rather than Auto obtain. Follow what is in the connected PC's settings except that the  last number of the IP add be different (ex. connected PC > 192.168.0.100, set the unconnected PC to 192.168.0.101, all the rest subnet, default dns be the same. Of course the 101 must not be in use, if double IP add, change to 102).
    In some instances, you may need to use the Encore WiFi configuration utility (normally comes with the drivers in the installer CD) rather than the Windows buil-in WiFi Config utility,
    Hope this be of some help/idea. Post back how things turns up or should you need additional information.
    Good luck and kind regards.
    Oct 10, 2007 | NetGear MR814 Wireless Router
    Encore ENPS-2012 (ENPS2012) Print Server Logo
    232 people viewed this question
    Top Encore Computers & Internet Experts
    Michael Galve
    Michael Galve
    Prashant M
    Prashant M
    Are you an Encore Computer and Internet Expert? Answer questions, earn points and help others
