Lexmark Z33 printer hooked up to older 2000 Milinium Microsoft. Can't get any other printer to download into old system. Lexmark, great printer has been installed for years. My accounting is stuck in this system, can't get printer to print. Turns on, runs paper through, new printer cartridge, but no print comes through. Help! Callie
If you go to this link (above) these drivers are for Windows 2000 which
is actually a different operating system than Windows Millennium. And
too I can not locate drivers for Windows ME. If you need them perhaps
you can locate the original installation cd that came with the printer.
I am hoping your computer is the 2000 because that has the NTFS (new
technology file system) as the other know as FAT32...
Windows2000-2003server-WinXP are all NTFS.
Remove the old print driver through Add and Remove Programs, in the control panel. Disconnect your printer from your computer until your are instructed to connect. Install the new software you download and run the program setting it up as per instructions. Connect printer, You also may want to open the tools in the printer and run the printer alignment. Hope this does it for you, Please leave rating thank you kindly
my lexmark z33 needs to be installed each time i connect it to the laptop. i have the installation...
(More)
my lexmark z33 needs to be installed each time i connect it to the laptop. i have the installation cd, but i waste a lot of time connecting it each time i want to use it.i cannot let it connected trough the cable because i need my laptop elsewhere. please help
my printer was printing at first, but now will not print anything else. I have the usb hooked up so...
(More)
my printer was printing at first, but now will not print anything else. I have the usb hooked up so i don;t know what is the problem
Get ink blob on leading edge of paper. Prints one line and then get message that there is a problem...
(More)
Get ink blob on leading edge of paper. Prints one line and then get message that there is a problem with printer. Have cleaned area behind front rollers of much deposited in. Lexmark Z33 is 7 years old. Has had normal home use.
My Lexxmark Z 33 Inkjet printer will not print in black. It has a new black cartridge but it is no...
(More)
My Lexxmark Z 33 Inkjet printer will not print in black. It has a new black cartridge but it is no use. Can you help?
