Question about Sony KP-57HW40 57" Rear Projection Television
Sony KP-57HW40 Rear Projection TV black screen red light blinking
MikeNJ1964
  • 398 Answers
SOURCE: Sony 57 in Rear Projection TV
If the picture is playing fine and you notice that the background is getting more and more red, until it is too red and the set shuts down, it could be that the red screen control is set just a bit too high. If this is the case, you can probably correct this yourself. If you are watching a perfect picture and then it suddenly flashes a very bright red, with thin red lines in the pictureand then shuts down, it usually means that the red picture tube has developed a short in it, between the cathode and heater. A good tech might be able to remove the short by arcing, but if the short persists then the red tube will have to be replaced. Either way, this is something that should only be done by a qualified tech.
Posted on Aug 27, 2007
ctf1800
  • 4402 Answers
SOURCE: SONY KP-57HW40 TUNS OFF AND STANDBY LIGHT BLINKS 6 TIMES
6 blinks is usually associated with failure of the horizontal deflection amplifier - which shuts down the high voltage system as well.
The repair requires testing to determine the exact parts that have failed. There are, for example, a few hundred parts and a section of the Jungle IC chip involved. So, repairs could require something as simple as replacing some inexpensive passive components OR as complicated as replacing the jungle chip (very expensive).
most of the time it's the horz. transformer and transistor.
Posted on Dec 20, 2007
Wise Frog
  • 13 Answers
SOURCE: Sony wide screen projection tv model kp-57wv600.
I found this solution from SONY's website.
The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
I hope this helps.
Posted on Aug 05, 2009
raklein62
  • 360 Answers
SOURCE: tv wont come on and a red light is blinking
Can you unplug the TV for about 15 seconds, and then plug back in and watch the stand-by light. Tell me how many time the stand-by light blinks in regular intervals. If it doesn't blink at all, you need to change a fuse on the g-board. Once this is done run back through the stand-by blink light process, and more troubleshooting can be done if problem isn't already solved. If the stand-by light just keeps blinking with a count over ten just tell me, and I'll look for other possibilities.
Posted on Oct 25, 2009
  • 1525 Answers
SOURCE: kp-65wv700 7 blinks
hello High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
shaun
Posted on Nov 11, 2009
Hi i have a kp-57HW40 sony projection tv. Right now it is failing, and when I turn it on I hear multiple clicks. The screen will not even light up, just stays black as it if were powered off. On the...
Thats the error for having a issue with the +5V which can be caused by either the A board or the B Board with the B board being the most likliest cause.
Jul 09, 2011 | Sony KP-57HW40 57" Rear Projection...
Red light flash timer stand by
Please count standby light blinks and let me know.
There would be pause of 3 seconds in blinks.
Also confirm is it Sony KP-57HW40 model?
Feb 10, 2009 | Sony KP-57HW40 57" Rear Projection...
Sony kp51 ws500 red screen, 8 blinks
The 8 blinks is pointing to a bad flyback transformer and may be common with this set. (We have one too.)
High voltage error -- blinks 8 times • T8005 is faulty. (D board)
Jan 01, 2009 | Sony KP-57HW40 57" Rear Projection...
SONY KP-57HW40 57IN BULB BURNT OUT
You need " A-1502-021-A " COUPLER (R) ASSY, CRT for your Sony KP-57HW40 TV.
It is available in Part Store.
Good Luck.
Oct 22, 2008 | Sony KP-57HW40 57" Rear Projection...
Sony KP-57HW40 57
Sounds like a convergance amp problem or possibly the S.D.K.'s are going out
Apr 20, 2008 | Sony KP-57HW40 57" Rear Projection...
Green screen
sounds like your green crt is shorting let me know if you need more assitance or if you would like to know where you can purchase a crt at.
Apr 10, 2008 | Sony KP-57HW40 57" Rear Projection...
Sony KP-57HW40
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about
30 seconds then goes to the self-diagnosis function. Something is wrong with
the video. Check video out, Q705, 732, 761 and other components on the C
board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
try turning up screen slightly.
Feb 19, 2008 | Sony KP-57HW40 57" Rear Projection...
KP-57HW40 w/ 8 Blinks
8 times, Diagnosis: High voltage error. Possible cause: T8005 is faulty. (D board)
Dec 23, 2007 | Sony KP-57HW40 57" Rear Projection...
Sony KP-57HW40 57" Rear Projection Television Logo
14 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
