Question about Amzer Non-slip Weighted Beanbag Dash Mount For Iphone 4
I have a Plexiglas disk and a sianbag should I attach the new disk over the orginal?
My Tom Tom won't stick to the dash mount. I have a plexiglass disk that came along with the mount. Should I attach it on top of the old disk?
The plexiglass in my backboard has become loose. What do I use to glue back together?
Not knowing what the other material is, you may want to try E6000. It will bond to the plexiglas, and the backboard frame material. You may wish to rough up the surfaces to help bonding.
Mar 17, 2015 | Crafts & Hobbies
Tom Tom will not stick to glass or dash board disc
Replace the mount with a new one if cleaning the rubber suction cup fails.
Use a 'alcohol wipe'
May 10, 2013 | Tomtom ONE GPS Receiver
Lost adhesive hook for Tom Tom dashboard mount
take a 2 sided tape and fix the tom tom dash mount.. it will temporarily solve your problem... then later u can buy a new one
Aug 24, 2012 | Arkon Friction Dashboard Mount with Safety...
The mounting bracket does not adhere to the slightly pebbled vinyl surface of my dashboard. Does the clear plastic cover, with the tab, come off or stay on? Also, there is a round black disk that...
The mounting bracket is meant for mounting on the windscreen. It won't stick to the pebbled vinyl surface of the dashboard as the surface allows air in. You take off the thin clear plastic cover. The black disk that came with the satnav can be stuck to your dashboard if you want to mount the satnav there. Clean the dashboard and peel off the plastic cover off the disk to stick it to the dashboard. Be sure not to put it where there's an airbag. You can then attach the satnav to the other side of the disk the same as to the windscreen.
To attach the satnav to the windscreen press the suction mount against the screen and press the lever towards the screen. To remove it pull back the lever and lift the tab on the suction pad.
Jun 25, 2011 | GPS
How do I attach my garmin to my dash mount?
The Garmin Nuvi 255w comes with a three piece dash mounting kit. A round disk smooth on one side tape on the other to affix to the dash (most dashes ar textured and the suction cup will not hold to textures) a suction cup arm with a ball end, and a bracket with a receiver for the ball. Snap the bracket and arm together, this can take a little effort. mount the disk to your dash in a place that doesn't obstruct your view of the road. then place the arm/bracket on the disk and push the lever down creating suction to hold the mount to the dash.
Another option it the beanbag dash mounts that hold the arm without sticking to your dash.
If this answered your question please check +. If not please elaborate on your queston
Apr 26, 2010 | Garmin nuvi 255W GPS Receiver
How do I install the tomtom in my car. It cam with a big round disk with adhesive on back that I assume goes on dash or window.. But ho do I mount the tom tom to that disk? The modle did not come with...
Some TOMTOM have the EasyFold attachment: It has a large ring that you push against the back of the GPS while twisting it a bit. In some TT GPS, notably the GO series, the windshield or dashboard attachment ends in a rectangular shaped piece that slides on the back where the speaker is located.
Dec 31, 2009 | Tomtom GPS
I need to replace the black disk that mounts on
buy a new one from the manufacturer od eBay. Make sure you thouroughly clean the dash with rubbing alcohol.
Dec 27, 2009 | Nextar GPS
34/58 screen damaged from cleaning.
If this is just the shiny "screen protector" on the tv, then yes, you can just use a peice of plexiglass or acrylic..
Jan 14, 2009 | Toshiba 65HDX82 65" Rear Projection...
How to mount tomtom 125 to the car
Alcohol works to a great degree to clean some surfaces. I have used lighter fluid to dissolve glue or adhesive residue that may exist. The alcohol will not work on a poorly cleaned surface. And lighter fluid does not seem to harm plastics. Use sparingly and clean in two or three apps.
Your solution seems to be that you are trying to attach the GPS suction cup to the dash without the plastic disc that comes with the unit. Glue the disc onto as flat a part of the dash as possible, Prefferably on the top of the dash. Then attach the Tom Tom with the cup onto the disc. A slight downward pressure while turning the locking handle is all that is necessary. I had a momentary adjustment time to learn how to lock mine. Love the TomTom GPS compared to the Navigon I returned to get an
XL330 S.
Dec 21, 2008 | Tomtom ONE GPS Receiver
Amzer Non-slip Weighted Beanbag Dash Mount For Iphone 4 Logo
22 people viewed this question
Top Amzer Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an Amzer Cell Phone Expert? Answer questions, earn points and help others
