Question about 5303L 2Way LCD Remote Start Security System
Avital 5303l repogram - 5303L 2Way LCD Remote Start Security System
HOW TO OPEN TRUNK WITH AVITAL KEYLESS REMOTE
all depending if your trunk work with negative ,or positive pulse if it is positive you have to used a 5 pin relay and if its negative just connect it straight
May 17, 2015 | 5303L 2Way LCD Remote Start Security...
Will avital 5303 work with a 2010 prius
It should go to this site http://www.the12volt.com/installbay/forum_posts.asp?TID=52897 it shows your Pirus if you go under the tab vehicle wireing, manufacture, model.
Apr 07, 2014 | Avital Vehicle Parts & Accessories
Avital 5303 would not work after changing the battery in the remote
be sure the polarity of a battery when you fix it in the remote unit
Feb 03, 2014 | 5303L Security/Remote Start System
TPMS malfuntion for Kia Sportage 2008
It is caused from data interference by the bypass module. A different firmware will need to be used or a different bypass all together. If Frys recently installed it, then they should be responsible to fix under warranty.
Dec 29, 2013 | 5303L 2Way LCD Remote Start Security...
What do you need to install Avital - 2-Way LCD Remote Start with Security to a dodge magnum 2005
A security or transponder bypass.. there are a few different companies that make them.
Sep 25, 2013 | 5303L 2Way LCD Remote Start Security...
The full trigger alert icon is illuminated on my avital 5303
What is the full trigger alert icon? Please describe it.
Jan 17, 2013 | 5303L SecurityRemote Start System
How do i reset my remote start car alarm avital 5303
i have a avital 7352l remote start my fob got smashed under the hood of my car still locks and unlocks car but went to use remote start and it tried to start car but it didnt then i got into my car and try to use my key and it didnt crank at all can anyone help me solve this problem?
Feb 21, 2011 | 5303L Security/Remote Start System
5303L 2Way LCD Remote Start Security System Logo
37 people viewed this question
Top Avital Vehicle Parts & Accessories Experts
D. E. Hev
Colin Stickland
Colin Stickland
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
