Question about Peachtree Software peachtree complete accounting 2006
Peachtree 2006 install windows 8.1 - Peachtree Software peachtree complete accounting 2006
Thanks for your sharing and I'd like to share another experience to upgrade to windows 8. Guys you can try this site: https://www.facebook.com/Windons-7-Key-581343735370307 to get a cheap and genuine win 10 pro key to activate windows 10. It works 100%.
Posted on May 31, 2016
Can't remove Peachtree Pro 2008 from Vista Machine. It comes up with a fatal error.
This is caused by Internet Protocol (IP) routing resolution in Windows Vista and Windows 7 favoring to push all communication from Peachtree and it's database (Pervasive) through IPv6. Windows Vista, and Windows 7 by default, resolves a computer name into an IPv6 address, however the Pervasive Database is only able to communicate with computers that have IPv4 addresses. There are two methods that resolve this issue. The first method explored in this document is preferred.
Note: This answer contains information about how to modify the registry. It is strongly recommend that you backup the registry before you modify it. You should perform these steps only if you are familiar with editing the Windows Registry. Please contact your local IT Administrator or Computer Consultant for assistance if needed.
Method 1:
Disabling IPv6: To disable the Internet Protocol Version 6 in Windows Vista and Windows 7, follow the steps:
  1. Press the Windows key + R to open a Run prompt. Type REGEDIT in the Open box.
  2. The Registry Editor window appears. Locate and click the following registry subkey:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip6\Parameters\
  3. Double-click DisabledComponents to modify the DisabledComponents entry.
    Note: If the DisabledComponents entry is unavailable, you must create it. To do this, follow these steps:
    a. In the Edit menu, point to New, and then click DWORD (32-bit) Value.
    b. Type DisabledComponents, and then press ENTER.
    c. Double-click DisabledComponents.
  4. Type 0ff (that is Number: ZERO Letter: f Letter: f) and then click OK.
  5. Close the Registry Editor window and restart the computer for the changes to take affect.
    Please refer to Article ID 929852 in Microsoft's Knowledge Base for more information regarding this process:
    http://support.microsoft.com/kb/929852
Method 2:
Note: This method is not recommended for laptop users. In some cases, the laptop is used at both work and at home. If the HOSTS file contains the IP address of one location and not the other, this will cause the error, "Peachtree Cannot be started, please reboot" as outlined in Answer 19062.
If you do not want to disable the IPv6 protocol in Windows Vista or Windows 7, follow these steps:
  1. To do this go to the computer that stores the Peachtree data (server).
  2. Press the Windows key + R to open a Run prompt. Type CMD in the Open box.
  3. At the command prompt, type ipconfig. Write down the IPv4 address in the form of ###.###.###.### (example 192.168.1.100).
    Click to Enlarge:
    Figure 1
  4. Close the command screen. Right-click the Computer icon and choose Properties.
  5. Write down the Full Computer Name exactly as it appears including all upper and lower case letters. (example PtreeServer)
  6. Press the Windows key + R, and type C:Windows\System32\drivers\etc in the Open box, click OK.
  7. Double-click the hosts file and choose open with Notepad.
  8. On the first blank line enter the IPv4 address of the server you wrote down in Step 3. Then enter 5 spaces then type the Full Computer Name exactly as it was found in Step 5.
    Click to Enlarge:
    Figure 2
  9. Select File from the main menu and choose Save. Close Notepad.
  10. Open Peachtree.
    Note: If you remove the computer from the network (such as with a laptop), then the Hosts file will need to be changed back to the default in order for Peachtree to work properly.
  11. Press the Windows key + R as stated in Step 2. Type C:\Windows\System32\drivers\etc.
  12. Double-click the hosts file and choose open with Notepad.
  13. Delete the information you entered in Step 8.
  14. Select File from the main menu and choose Save. Close Notepad.
Dec 05, 2010 | Sage Peachtree Pro Accounting 2008 Full...
I am denied access to change the accounting period in peachtree
I've seen this before with peachtree. What happens every time you work on an accounting file peachtree locks the contents of the file. Occasionally the software never gets the chance to unlock it. This can happen if the computer shuts down unexpectedly, a file gets corrupted etc. You should find in your installation depending on the version a scan utility that can scan your accounting main file and see if there are problems and correct them. If not next try a re-install of peachtree and run the updates and try opening the file. Finally if not it is time to restore an update you have prior to the problem.
Sep 04, 2009 | Peachtree Software Peachtree Complete...
Everytime i try installing sage peachtree on xp sp2 system keeps asking me to update pervasive
You probably have a earlier pervasive version installed or no version. You will get this error when either of those occur. Pervasive workstation is all you need. There should be an option to install it from the peachtree cd. If not open the cd and browse for a pervasive directory and run the setup.
If they didn't include it then you can download it from Pervasive. You should get V10 workgroups install and that error should go away.
Mar 12, 2009 | Sage Peachtree Premium Accounting 2009
Federal Income tax
No it has not been corrected. After yesterday's experience with the sales tax not working it finally came out that apparenty Peachtree had installed a bug that would cause the system to fail after a certain age. Your techs from your premium side that attempted to fix it before that notice failed miserably. I know there is a code somewhere inside it that cause the problem but they apparently cannot find it. I believe it is an attempt by Peachtree to force the customer to upgrade which I do not want to do.
Feb 27, 2009 | Peachtree Software Peachtree Complete...
Customer Sales/Invoice Window
Exiting Tally
Internal error . contact tally solutions
Software Exception c0000005
(Memory access violation)
Feb 04, 2009 | Peachtree Software Peachtree Complete...
Problem using Peachtree2004 on window vista..
Looks like you are using illegal program or... someone has somehow stolen your software key before you noticed. If you are not using this software on your another computer, try to contact software creators http://www.peachtree.com/company/contactus/
and explain the situation
Jan 23, 2009 | Peachtree Software Peachtree Complete...
Using Peachtree Complete Acctg 2003 w/ Microsoft Vista
may be need to reinstall it again then make update for it
Dec 09, 2008 | Peachtree Software Peachtree Complete...
Peachtree Software peachtree complete accounting 2006 Logo
313 people viewed this question
Top Peachtree Software Computers & Internet Experts
Gene Jakominich
Gene Jakominich
Level 1 Expert
Don A
Don A
cashofy
cashofy
Are you a Peachtree Software Computer and Internet Expert? Answer questions, earn points and help others
