Question about Sewing Machines
I need needles for a Jaguar 055D serger - Sewing Machines
4 Suggested Answers
SOURCE: need manual for jaguar epochlock 055d
For 10 USD : http://www.tradebit.com/filedetail.php/153176694-jaguar-epochlock-055-056-serger-instruction-manual
Posted on Nov 16, 2011
  • 539 Answers
SOURCE: jaguar overlocker 055d foot control
Contact http://kenssewing.com Toll free # and experienced techs. Jimmy
Posted on Apr 07, 2012
SOURCE: jaguar epochlock 055d over locker I need owner manual. Don't
i have a manual for this machine
Posted on Aug 08, 2012
I have a easy lock serger Model SL4300 and I need to know the needle size and what brand should I get, lost my manuel
Manual:
http://www.sewingpartsonline.com/instruction-manual-simplicity-sl4300.aspx
Free Manual For Simplicity Easylock Serger Model Sl4300
Parts:
http://www.sewingpartsonline.com/simplicity-sl4300-serger-machine-parts.aspx
This site shows Organ and Schmetz needles but most quality needle brands would be suitable for your machine. A standard 130/705H needle will work. Just be careful as I believe my machine recommends no needles larger than a size 90.
SL4300 Overlock Serger
Jul 12, 2017 | Sewing Machines
Have an Toyota 6600 model Serger. The knives won't cut, won't stitch and tread keeps breaking from the right hand needle...
you might want to replace the knives
you might have the serger checked for a timing problem
Serger thread breaks
1. Is the serger threaded correctly?
2. Is the needles inserted correctly?
3. Is one of the needles bent or damaged?
4. Is the tension adjusted too tightly?
5. Is the tension adjusted to accommodate thickness of thread being used?
6. Are you using inferior quality thread?
7. Is the thread feeding of the cone/spool freely?
8. Is the needle size correct for the type of fabric being used?
9. Are the needles being used the correct one for the serger?
10. If all of the above suggestions don't help then the serger needs to be checked for a timing problem at a sewing machine repair shop.
Nov 05, 2013 | Sewing Machines
Singer Stylist 11 Serger problems with right need skipping stitches how can I solve the problem
SKIPPED STITCHES ON A SERGER
1. Is the needle bent or worn--replace
2. Is the needle inserted correctly into the needle holder--check needle
3. Is the Serger threaded correctly--rethread
4. Is the presser foot pressure right for the fabric--adjust
Jan 04, 2013 | Sewing Machines
Jaguar overlocker 055d foot control
Apr 06, 2012 | Sewing Machines
When we thread the serger . the thread is still skipping
Are you using the corfect serger system needles in it? Most domestic sergers will take the regular domestic needle 130/705X but work best with a serger needle with has a groove down the front as well as the regular back scarf. This helps with the thread pickup from the looper by the needles. Sergers also run much faster than domestic sewing machines so the tolerances are very fine.
My Bernina came with ELX705 needles and it does run better with these in it. Also you need to use mid size needles, don't go too small, probably a size 80 or 90 is best.
Check out this page for some good info as the different serger manufacturers do have their own recommended needle sometimes. http://sewingmachine221sale.bizland.com/store/page78.html
Always refer to your manual (or ring the manufacturer if lost) to double check what needle they recommend be used in your serger, it does make a difference.
May 19, 2011 | Sewing Machines
Please can you tell me if it is possible to do a rolled hem on delicate fabric using a Jaguar Epochlock 055D overlocker and if so how
There is a definite art in doing a rolled hem at the best of times and on a delicate fabric you have to be good, there is no way of explaining you need to be shown.
Nov 01, 2009 | Sewing Machines
Needle for a singer tiny serger
Hi, ALthough it is called a "Tiny Serger", it will still take regular singer serger needles.
Apr 23, 2009 | Singer Tiny Serger TS380
I have a white superlock 228 jaguar serger problems with right needle
Couple of things I could think of: tension disks need cleaning, there is a site that tells how to clean them, maybe 2 as I recall. Other thing is it is a much older serger, (I have one I am slowly working on to bring up to working level), so it could be that a tension spring internally has lost its tension. It might need a trip to the repair man if that is the case. Another thing is are you using correct needles for the machine? Have you changed them recently? Even new needles can be bad, so if you have to change three times to triple check it can be worth it.
Aug 14, 2008 | White Sewing Superlock 2000 ATS Mechanical...
Sewing Machines Logo
49 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
