Question about Zebra Eltron LP 2824 Thermal Printer
LP 2824 The printer works fine except I have to hold down the lid.  The light around the feed button is red, but if I apply pressure to the lid it turns green.  Is there something I can do to fix this?
  • cjguyer May 11, 2010
    I'm not clear on where to put the sticker.
  • Bob Ross
    Bob Ross Dec 09, 2017
    The sticker trick works perfectly.
Here's the right way to fix the problem.
Autosense Procedure, Configuration Label and Dump Mode:
Models: Orion (2442, 2443 and 2543), Transport (P-2242), Xport (P-2222), LP/TLP Strata (2684), LP/TLP-2722, 2742, 3742, LP/TLP-2824 ,LP/TLP 2844 and TLP-3842
  1. Turn off printer and have media loaded (on older Transports, with no ON/OFF switch, remove battery).
  2. Hold feed button down, and turn printer back on (on older Transports, re-insert battery) while holding down the feed button.
  3. When the light starts flashing, release the feed button.
  4. Printer light will turn green and advance a few blanks.
  5. After printer stops advancing and prints the internal information, press the feed button one time.
  6. You will get another label with the "Out of Dump" message on it.
Printer is now ready for use.
Posted on Apr 04, 2008
  • 53 Answers
Yes there are a few fixes, you need to recalibrate the lid sensor profile to fix the issue which takes a lot of time.
or there is an easy quick fix i came up with.
the main issue with the sensor is that it is an reflective IR sensor and requires a clean close surface to get a reflection. over time things get dirty. peel off a label and stick it to the lid above the lid open IR sensor, do not stick it to the sensor it has to be on the lid
Posted on Nov 09, 2007
SOURCE:
Zebra TLP 2844-z printer and when I turn it on the light is blinking green/red
hold feed button and release during 4 blinkings to reset. good luck
Aug 29, 2013 | Zebra LP 2824 Printer
I am having problem with the Zebra UPS 2844 model printer. It will not pring anything for some reason, even when I just reinstalled it.
This could be any number of issues. Without more detail, it is impossible to say what the problem could be. One easy way to see if the problem is your printer or you computer / application / driver is to print a configuration label. To do this, turn the printer off. hold down the green feed key, power the printer back on while holding the green feed key. When the light flashed red, let go. At this point, the printer will calibrate and then print a configuration label. If this works as planned, you can eliminate the printer hardware as the problem. From there, try changing the connectivity from USB to serial. Try another computer. just keep changing variables until you get a different result...
Jan 19, 2010 | Zebra Eltron LP 2824 Thermal Printer
Hi can you help ? My zebra TLP 2824 printer keeps printing out of alignment. I reset the printer by holding the feed button while powering on but instead of printing dump info the label moves for a while...
If you are using a ribbon remove it and perform a calibration, hold down feed key for 2 seconds as you power on, release key and wait for it to complete its calibration, when it has stopped shifting labels (wait for 10 secs to be sure) HIT THE FEED KEY to exit dump mode. If it has successfully calibrated it will feed a label each time you hit feed key. Re-install ribbon, make sure ribbon is pushed formly onto drive sprockets and then re-run the calibration..
If this does not fix problem. download firmware to latest version. This will automatically reset printer to factory default condition.
Nov 12, 2009 | Zebra TLP 2824 Printer
Printing a 2.25 in label on Zebra LP2824. Prints
Recalibrate the printer and you should be good to go. Do this by turning the printer off, press and hold the button and turn on the power. When the light flases red let go and it will calibrate, at the end it will do a printout. Reboot the printer and your fixed.
Jul 28, 2009 | Zebra Eltron LP 2824 Thermal Printer
Problem Printing
It appears you have a broken latch lock on 1 or both sides of the cover. There is nothing you can do settings wise. You will need to look into the printer for the broken section & probably replace the part(s) that are broken. I have a PDF file I can send you or you can download from Zebra.com RESOURCE LIBRARY section. The PDF is too large to post here. The latch is easy to replace if your slightly technical. Most replacement instructions are in the manual. Let me know if this helps.
Feb 09, 2009 | Zebra LP 2844 Thermal Printer
Zebra 2824 red light
Hold the feed button while turning on the printer. After a config label prints, turn the printer off and then on again, and try printing again.
Also, make sure the lid is closed far enough to engage the lid sensor. If the red light comes on again, press down a bit on the lid, hit the feed button and try to print again.
Sep 03, 2008 | Zebra TLP 2844-Z Thermal Label Printer
TLP 2824 don't print
Only one suggestion, do a memory dump, switch off the power switch (should be back corner of printer) , hold down the green feed button, power on and watch the feed button, take Your finger off it after the third flash.
Leave it for a moment and press once more, it might say something on the label like out of dump. Try a label again.
Do this two or three times if it still acts up.
After this all thats really left is to clean it with an alcohol swap or check settings in the program You're using
Some times they cant store the amount of print jobs being sent to them and the zebra just freezes up or spits out labels
Apr 08, 2008 | Zebra Eltron LP 2824 Thermal Printer
Zebra LP 2824 Comm port problem
I believe if you hold the button down that has the green ring around it and power it back on it resets the printer to the factory defaults.
Jan 12, 2008 | Zebra Eltron LP 2824 Thermal Printer
Zebra LP 2824
the error you are getting is a label size error. a label variance of as little as 1/203th of an inch can cause this.
you need to recalibrate the printer to the media, hold feed when powering up the printer letting go once the light flashes 4 times. this will force the printer to autodetect the label size.
if you are specifying the label size in you software or driver settings, measure and double check the label size
Dec 04, 2007 | Zebra TLP 2824 Printer
Zebra Eltron LP 2824 Thermal Printer Logo
1,587 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Gateway information...
Marvin
Marvin
Ekse
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
