Question about Fasco ICP Heil Tempstar Furnace Inducer Motor 1001609 HQ1001609FA K37MYNW-344
K37mynw 344 noisy - how to clean? - Fasco ICP Heil Tempstar Furnace Inducer Motor 1001609 HQ1001609FA K37MYNW-344
I am unable to retrieve my forgotten password. My cell phone changed from @62 344 7303 to 262 344 0340. Thats where I need my text message to go
Password to which email service?
There should be a "Need help?" or "Can't access your account?" or some similar link on the sign-in page.
Sep 02, 2014 | Computers & Internet
I want to find the right walking foot for the Janome 344
Janome has an even feed foot for their machines. Any janome dealer should carry them.
Feb 23, 2010 | Janome L-344 Mechanical Sewing Machine
Code 344 camshaft sensor ciurcut intermitint 05 pt cruiser
im having exactly the same problem with a 2004 pt. took it to a dealer they told me ecm, replaced it and still the same problem. i changed out the cam knock sensor and the crank sensor. same thing. if i erase the code it will run perferct for an hour sometimes then same thing, light comes on and wont accelerate, over 2000 rpm. weird. im lost, it makes no sence.
Jun 03, 2009 | 2005 Chrysler PT Cruiser
Kenmore dishwasher, model 665.170 344 01. "Clean" light keeps flashing and will not stop. Have tried everything in the manual and the light still will not stop flashing.
If the clean light flashes 7 times, pauses then repeats...
If the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive).
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Jul 18, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Filter queen 95X (1991) Motor is noisy but still work fine. Can there be a loose screw inside ? Can I open the motor and look inside ?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=766802
Generic problem for all Vacuums
Posted by alexun on Jul 10, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The sounds coming from the motor sounds like it is the 2 sheet metal fans that do loosen up and start to make noise; and if you are handy and can do service work yourself you can replace the fans, but make sure you mark the wires when you remove the wire and the motor. If you have questions feel free to contact your local vacuum cleaner dealer in your area or cal the Filter Queen cust serv line listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.filterqueen.com/
Customer Service 1-800-344-1840
custserv@filterqueen.com
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 10, 2008 | Vacuums
Fasco ICP Heil Tempstar Furnace Inducer Motor 1001609 HQ1001609FA K37MYNW-344 Logo
27 people viewed this question
Top Fasco Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Fasco Heating and Cooling Expert? Answer questions, earn points and help others
