Question about Behringer POWERED MIXER, 20 CH, 400 WTS AMPLIFIER => Model PMX5000 Car Audio Amplifier
I have a jensen 4 channel 400 watts car amp. cannnot turn it on
2 Suggested Answers
  • 61 Answers
SOURCE: What is the actual watts per channel @ 8-ohms and 4-ohms on the Behringer PMP3000?
Those specs would be right - I have this same board but the amp was fried by a previous owner. I pulled the amp board out and tossed it and use the mixer now to drive an external amp. Great board. This amp is rated at 1200W "peak", bridged into an 8ohm load. That would equate to about 900W RMS bridged into 8ohm or 450 per side into 4ohm loads per side. You can't daisy chain all 4 speakers....impedance would be too low. You can run two of your 8ohm speakers per side - that results in a 4ohm load per side for the amp. That would give you amp delivery of 450W per side. Your speakers are rated to handle more than that so you're fine. For the record.....you could run one speaker per side no problem....just lower power output.
Posted on Aug 19, 2012
I have to hook up 4 amps in my car. 4 channel 700 watt ken wood, 2 channel 800 watt Sony, 4 channel 740 watt Jensen ,and a 2 channel Rockford fosgate. Which is best way to hook them up so I'm not ki
Pace posted on Saturday, March 05, 2005 - 01:08 GMT Your subs are dual 4 ohm voice coils so if you want to bridge your 2 channel amplifier to your two subs then wire them parallel, meaning the + to + and - to - ( Do this to both subwoofers), Then run a wire from one positive and one negative on each sub and bring the two positives together and the two negatives together and hook both positives to the far positive connection on your amp and connect both negatives to the other negative on your amp,
This will create a 4 ohm load on your amp.
Although if it's a two channel and you have two subs it's usually pointless to bridge them because if you use one channel per subwoofer its going to be the same as if both subs were bridged. example) 800 watts x 1 bridged power of your amplifie (4 ohms) is the same power as 400 watts x 2 at 2 ohms.
Nov 26, 2012 | Computers & Internet
I have a 12 inch auduobahn 400 watt that is a special edition d jones. what is the best and most efficient way to install it with a jensen 400 watt 2 or4 channel mosfit power amp.
Is it a 2 or 4 channel amp???? Does it have a lpf (low pass filter)??? If its a four channel it prolly wont sound too great. If its a 2 channel you need to bridge sub to amp. Usually its the 2 outside terminals on the amp. Might have a diagram on the bottom of amp
Feb 27, 2012 | AudioBahn Car Audio & Video
How do i bridge all 4 channels on the jensen 400 watt 4 channel lxa amp ?
  • This amp is not "bridgeable" at all. You will either blow the front end or blow the low end voice coil in your sub.
Regards, Tony
May 24, 2011 | Jensen LXA400 Car Audio Amplifier
I have a 600 watt 4 channel bridgeable amp and I want to get all 600 watts to 1 speaker. How do I do that
You will not be able to do that with a 4 channel amp. You can with a two channel amp, but not a 4 channel amp. You can get, depending on the amp, 300 from half of the amp to one speaker.
Aug 21, 2010 | Jensen Car Audio & Video
How many watts is this amp
Specifications Power Output: 100 Watts RMS x 2 channels at 4 Ohms ≤ 1% THD+N Signal-to-Noise Ratio: 80 dBA (reference: 1 W output) Additional Power Output: 200 Watts RMS x 2 channels at 2 Ohms ≤ 1% THD+N
400 Watts RMS x 1 channel bridged at 4 Ohms ≤ 1% THD+N THD+N (Distortion): <0.25% (reference: 1 W output) Frequency Response: 20 Hz to 20 kHz (-3dB) Maximum Input Signal: 5V Maximum Sensitivity: 100mV Dimensions: 14.37 x 9.72 x 2.5 (365mm x 247mm x 63.5mm)
Jan 03, 2010 | MTX 4002 Car Audio Amplifier
How many watts RMS are?
Hello melesk82,
The Jensen XA4150 is a 4-channel amp that outputs 75 watts times 4 channels into a 4 ohm impedance.
Hope this helps.
Oct 03, 2009 | Jensen XA4150 Car Audio Amplifier
DON'T KNOW WHAT WIRING KIT TO USE FOR 400WATT 4 CHANNEL AMP
well i will let you know now that 400 watts running into two subs like that will never match. You will want to run only one sub or get a bigger amp. But for that amp a standard 6 gauge power wire will be sufficient to run it. The ground wire about 4 gauge is good.
Feb 23, 2009 | Jensen VM9510 Car DVD Player
400 watt jensen amp not hitting.
Not to be mean but jensens have never hit as far as i know
Jan 29, 2009 | Jensen LXA400 Car Audio Amplifier
Speakers
Hi Trim God,
I do not reccommend that you push the Pioneer speakers over 100 watts.  The jenson will already drown the car with bass through your pioneers so much you will want to turn off the bass boost when playing some low bass hip hop songs. It changes from one venue of song to another, so I just keep the jenson bass boost off and use my head unit to adjsut the sound to fit my listening prefences. I am telling you man, you will be blown away .  Hook up the pioneers straight to the Channels,. do not bridge.  I put Subs in my truck though.  I used the Pass output to send the audio to me Jenson 2 Channel 600W amp. I drive one 10 inch enclosed JBL Class A/B Sub. I bridged the output of the 600 W amp to the 10 inch sub  in my Z28.  The pioneers never get drowned out.  I did smoke my 2 channel Amp one time. and also took out a MTD 10inch sub. I am talk shooting flames and smoked the whole car up. I think if you bride the XA4150 to the pioneers, you will have the flaming smoke problem in no time.
Oct 02, 2007 | Jensen XA4150 Car Audio Amplifier
Protection light comming on.
I'd be inclined to check to make sure there isn't a short circuit somewhere in the output lines. Maybe a wire is crushed against the car's body or bare wires touching or badly fitted RCA plugs. All of these things could activate the protection circuit. If you have a multimeter it would make life easier but don't forget your speakers will show up as 4 ohms so that's not a short. BMW
May 31, 2006 | Jensen 100W x 4 Amplifier KA5 Car Audio...
Car Audio & Video Logo
15 people viewed this question
Top Behringer Car Audio & Video Experts
xxxxxx xxx
Are you a Behringer Car Audio and Video Expert? Answer questions, earn points and help others
