Goldair 3108 How do you remove the goldair 3108 bathroom heater from the wall bracket
Where can I get wall brackets for this unidentified heater?
Hi Lawrence:
I'd suggest that this should be the contractors problem.
If he can't get replacement brackets then he should be getting a replacement (new) heater.
It's referred to as "Ownership of the problem".
I hope you have held back part of his payment.
Aug 30, 2015 | Heating & Cooling
Switching on
The switch is failing.
Dec 19, 2013 | Heating & Cooling
I have removed the piece requiring the hex tool. However, I can't get the base off the wall. How can I remove it?
The base is probably connected to wall with toggle bolts, thus meaning , as you try to unscrew the bolts that keep spinning, pull on the bracket away from wall as you unscrew the bolts and it will come off.
Aug 31, 2011 | Moen 24 In. Towel Bar...
How do you remove the eva towel rack holder
The Moen YB2824 is attached to the mounting bracket with a set screw through the base. You would simply need to loosen this set screw to remove item from the wall.
May 07, 2011 | Moen YB2818 Eva Towel Bar Bathroom...
I don't know how to take my Gatco 4515 "Tiara" Robe Hooks off the door now that I'm moving. Please help. Thank you.
I'm not 100% sure about this model, but I have a similar hook by another brand. Here's how mine is removed:
When you look at the hook, there's a small hole at the 6 o'clock position, (pointing down, right next to the wall.) This hole is actually a set screw that can be turned with a small hex-key (aka allen wrench)
thomascha103_7.jpg The size needed is pobably about 2 mm, or 1/16 in.
Turn the set screw counter-clockwise for a few turns to loosen the hook from the mounting bracket. When the set screw is backed out far enough, the hook will detach.
After he hook is removed, you'll be able to see the mounting bracket that is screwed into the wall. Remove the screws with a screwdriver, and take the mounting bracket with you. You'll need it to attach the hook to the new wall.
If there is no set screw or hole visible from any side, then your Gatco hook might be removed from the mounting bracket by twisting the entire hook counter-clockwise.
If anyone else out there has experience with this particular brand, please chime in and correct me if I'm wrong.
I hope I've been helpful. Good luck.
Jan 19, 2011 | Gatco 4515 Tiara Robe Hook Bathroom...
Hi, I have a Goldair oil column heater which is a
im sure it has a fuse-able link that will melt when the temp gets to high. it is a safety option
Jun 05, 2010 | Heating & Cooling
I have a sink in bathroom I have removed cabinet and there is nothing to hold up sink can that be anchored it is round sink with 1/2 inch lip caulked to bottom of counter i also want to remove do i have to...
I DON'T RECOMMEND TRYING BOLT THIS TO THE WALL UNLESS YOU HAVE THE WALL BRACKET THAT COMES WITH THE SINK,NOT ALL SINK ARE DESIGNED TO BE WALL HUNG.
Apr 20, 2010 | Home
Tighten up a loose Moen Eva towel bar wall mounted bracket
u have to really push hard up on the spring and at the same time pull towards u
Apr 18, 2010 | Moen YB2818 Eva Towel Bar Bathroom...
Need heat element for fasco wall mounted bathroom heater, the element is M shaped
try to found a local manufacture for heating elements, like http://rezistoterm.xhost.ro/ , give them the old heat element and the power of the bathroom heater (ex: 3000W and 220v, or 2000W and 110V) and they wil macke new oane and much chep like an original one.
Feb 14, 2010 | Fasco Heating & Cooling
How to Install Towel Ring
Place the mounting bracket against the wall and trace around the inside of the two ovals on the bracket. Gently drill a hole into the center of the traced oval. If you hit a stud, you will not need the anchor. Carefully tap the drywall anchors into the holes. Screw the bracket onto the wall, using the screws provided, into the two anchor points. Make sure the set screw is backed out far enough to set the escutcheon over the mounting bracket. Place the escutcheon over the mounting bracket, top first. Tighten the set screw with the Allen Wrench provided.
Aug 27, 2008 | Kohler Bathroom Accessory Set with Classic...
Heating & Cooling Logo
76 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
