Question about All-Clad Oven Probe Thermometer T-223
All clad oven probe thermometer has min f - All-Clad Oven Probe Thermometer T-223
Oven thermometer only displays lo
I just had that LO reading. Pulled back on the tip of the thermometer. Seems I had it inserted into my turkey too far. Probably up against a bone or too close to the center. Good luck! Happy Thanksgiving 2016!
Dec 25, 2013 | Farberware New Classic Alert Oven Probe...
What are digital probe thermometers? Are they used for cooking meat?
yes - digital probe thermometers are very good for testing whether meat is cooked. The thin sensor is inserted into the fattest part of the meat. A wire then runs from the sensor out of the oven door, so that you can keep an eye on the temperature without having to keep taking it out the oven.
Feb 14, 2013 | Home
When i put my oven on to 350 it takes a long time to heat, then the beeper beeps to let me know the oven is ready BUT it is not at 350. I have an oven temperature gadget and it shows it is at 275. ...
Standard oven thermometers use a bi-metal coil, which is slow to react. When we test oven calibration, we use digital thermometers with a remote temp probe which are MUCH more accurate and MUCH quicker to respond to temperture changes. If your bake times are significantly longer or shorter than the recipes state, have a service technician test it.
Feb 19, 2011 | GE Kitchen Ranges
I have a polder digital thermometer with two probes--but I didn't get instructions with them.. Can I insert the probe in the oven with the meat cooking or use only with the meat out of the oven to test it...
Timer is not identified for certain.
1) Some Polder timers have in-oven thermometer, and others say not to use thermometer inside oven.
2) The 12453 dual-sensor says inside-oven is ok
3) The 894 dual sensor says inside-oven is ok
4) TM360 dual probe says inside-over is ok
Polder timer manuals appear on following link:
http://www.polder.com/productinfo.html
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Oct 30, 2010 | Polder Triple Digital Timer Model 891-90
I've misplaced the operating instructions for my williams sonoma remote meat thermometer. I can't get the probe unit/base to sync with the remote transmitter or to show a temp on the base unit and find a...
This is for a model ET-903WS: Turn the base unit on first. This is the unit with the larger display & buttons. Hold the power/mode button (upper left) down until you hear 3 beeps and the display lights up. Mine then displays "BEEF" and shows 160, with 3 blinking spaces. Next, plug the probe into the smaller remote unit. You should get 1 beep, the remote will display the temperature and the base will now display the same temp where the blinking spaces were. The first couple of times I tried, the base would not display. Unplug the probe, turn the base off holding down the same power/mode button and start over. I've had to do this as many as 4 times but it has worked perfectly while I wrote this!?! I really like this thermometer because I can put the meat on the grill go inside and have a drink while watching the game and then a friendly voice comes on when the internal temp is within 10 degrees of your target and says: Your food is almost done...your food is almost done." If you sleep through that, she comes back on at temp and says "Your food I'd done...your food is done". I take most meat off at the first warning and wrap it in foil. Watch the probe and it will continue to rise for about 20 mins. Enjoy.
Aug 08, 2010 | Microwave Ovens
The oven doesn't come close to keeping a REASONABLE temperature. It fluctuates sometimes 75-100 degrees. I'm not talking about opening the door and then waiting to re-establish the temperature it was set...
If you just bought it, have it replaced, or repaired under warranty. If it is an old oven, replace the temp probe first (if it electric) It senses the temp inside oven, It is the least expensive part of the fix. If that doesn't work, replace thermostat/temp control board. When you replace a board, you replace the probe too. It will be needed either way. If just changing the probe works, you saved yourself some money.
Apr 06, 2010 | Kitchen Ranges
How do I use the thermometer in my Kitchenaid Superba?
I found the answer by checking the Kitchenaid website to find the manual. My model is KEMS308sss04, this is found on the right door frame. Website is: http://shop.kitchenaid.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10162223.pdf
You can preheat oven, but then turn off to set thermometer. Put probe in food. Put food in oven and plug in probe. The digital light asks for the temperature you want, type it in. Then the cooking method. I used convection bake at 325. Hit START. (The first time I didn't stop the oven and it didn't work. After stopping everything and starting with the probe before turning on the oven, it worked perfectly. Good Luck.
Dec 05, 2009 | KitchenAid Architect Series KEBC107KSS...
Oven does not reach set temp
What are using to measure temp ? Are you using a grocery store bi-metal or professional thermal probe ? and further to that, how long are you waiting to check temp. after range "beeps" or announces preheat complete ? The bi-metal type thermometers do take several minutes longer to reach actual temp as opposed to the ranges temp. probe. Does this unit have the "hidden" bake element ? That sounds like a huge temp difference. These units do require an additional 10mins of wait time after announcing ("BEEP") the preheat is complete (check your manual, it should confirm this) Elements don't go "bad" it either comes on (amp draw) or it doesn't.
hope this helps.
good luck
Sep 26, 2009 | Frigidaire Ovens
Digital oven temperate is wrong
Yes, that is the probe that sends info to the controller.
If it's not bad, then the controller is, but normally it's the probe.
Check that the controller has not been incorrectly calibrated before you change the probe out, although most do not allow a swing of more than 15-20 degrees. Yours may allow more though.
I am guessing you measured the actual temperature, to the set point temperature, with a know good thermometer.
Jan 30, 2009 | Frigidaire FGB24S5A Gas Single Oven
All-Clad Oven Probe Thermometer T-223 Logo
104 people viewed this question
Top All-Clad Home Experts
Donni Steen
Tom Chichester
Are you an All-Clad Home Expert? Answer questions, earn points and help others
