Washing machine not draining water during washes
Washing machine not draining water after washes have manually drained washing machine but water continues not to drain.......wouldnt have a clue where to start in fixing it...thanks for any advice...!!
  • jusjon27 May 14, 2009
    I drained the hose and found the water coming out just fine but when I turn the knob to spin it has a buzz sound
  • Samuel Charles Spriggs May 11, 2010
    It sounds like the water pump. Does it circulate water when it's agitating?
I have had the same problem. Someone told me to clean the pump filter. I have a front loader and the pump filter is in a little door down the front of the washing machine. You turn the thing in there counter clockwise (water may cascade out - keep bucket handy) then clean flint/soap out of the filter.
This didn't work for my washing machine however, so if anyone has any ideas (ie. how do you actually check if the hose from the washer to the sink is blocked - mine doesn't detach) would be most appreciated
Posted on Dec 09, 2011
    Sergeant:
  • 175 Answers
Hi..The problem most probably is your pump is not working
or the hose that the water drains out is blocked.
check it out..
thank u..
kindly rate my response..
Posted on May 08, 2009
Indesit WDG1295W. Why doesn't it drain?
The pump and connecting lines could be choked with debris the filter didn't catch.
Dec 26, 2015 | Washing Machines
Hi i have a SIMPSON ESPRIT 600 TOP LOADER WASHING MACHINE. The wash cycle works fine however during the drain and spin cycle, the water wont drain. The machine makes a noise during the drain cycle but...
My guess would be replace the pump, it is normally driven by the motor and if the wash cycle is good the motor is operational. You have to investigate to find the actual part to replace.
Dec 03, 2014 | Washing Machines
Water drain open even washing mode and during spin water not drain
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | LG Washing Machines
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Simpson Aquarius washing machine 7kg: water
SOUNDS LIKE A PLUMBING PROBLEM WITH DRAIN PIPE .YOU COULD FIT NONRETURN VALVE TO DRAIN FROM WASHER BUT THAT WOULD NOT STOP SINK FROM OVER FLOWING
Jan 08, 2010 | Washing Machines
Roper washer leaks when filling
It's in the drain hose somewhere,during the fill the water gets as deep in the drain hose as it does in the washer,during the wash the pump runs in reverse keeping the water level in the hose low,during the drain the hose is filled again.
Prop the washer up in front on a couple bricks or boards,start putting in water until it starts to leak and take a peak under the machine.
Sep 27, 2009 | Washing Machines
I manually put water in my washer; water stuck inside
drain hose kinked or belt off pump . lower drain hose to floor if empties the pump is the problem
Apr 17, 2009 | Whirlpool Washing Machines
Washer continuously fills but drains at the same time during rinse cycle.
you have the drain pipe too low into tthe house drain pipe, raise the washers drain pipe up , you only need four inches down into the hous drain
also the house drain pipe needs to be as high as the lid of the machine before you put the washer drain tube into the house drain
you have a syphoning effect
Apr 20, 2008 | Washing Machines
Water not draining during cycle
Did you check the lid switch?? Is it spinning???
Oct 05, 2007 | Washing Machines
Washing machine not draining, not occuring on every cycle. The "F2" code flashes during the cycle. "F2" indicates a drain problem. Is this the control panel or the motor that pumps out the water?
Possible your outlet filer is blocked, clean this out and refit. Refer to manual; the outlet filter requires periodic cleaning according to your usage; things shd be fine...
Aug 30, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
297 people viewed this question
Top Washing Machines Experts
