Question about Samsung RF4287HA
Water Dispenser Temperature Control/switch-off
Is it possible to control or switch-off water dispenser temperature? I don't want cold water.
Not on regular models. Most models have a water tank in the fridge compartment which makes the water temperature to stay just above freezing temperature.
Wanna a play with your unit. Then remove the tank and just add two pipe ends together. Eliminating the tank. Then you should get room temperature water after about 5 seconds of cold water. Be careful just connecting the two ends of pipe after removing tank might lead to freezing pipes if your fridge temperature is close to freezing temp.
Posted on Nov 26, 2013
4 Suggested Answers
SOURCE: i have a rs21dcns fridge
The water stops flowing from the dispenser when the external water filter needs changing, stick a new filter and it should start working again, it sometimes takes a few minutes to clear the air after the filter change.
Posted on Sep 07, 2008
jumptrout51
  • 3361 Answers
SOURCE: water temperature from the water dispenser
You may not have filled the water reservoir when you hooked up the fridge. Run about 2 gallons of water through the dispenser. Then wait about 12 hours before you draw more water. This way the dispenser will fill and have time to cool down. It should stay cold after this.
Posted on Aug 29, 2009
  • 117 Answers
SOURCE: temperature light for samsung american
hi dont know what model you have , have alook at this video may help ?
Posted on Nov 11, 2010
How to make the water colder in the water dispenser
The water reservoir is in the fresh food section,(right hand section), of your refrigerator behing your crispers. Turn your temperature control to a colder temperature for this section and it will make your water colder. Good Luck, Appliance Specialists
Dec 31, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Washer only has cold water. Hot water is good to machine but only cold water enters machine on warm cycle, no water ar all on hot cycle.
Hello there
The Water System temperature sensor is normally what is wrong with these units with this condition that you are experiencing
The water system consists of the hot and cold water inlet valves, a water temperature sensor, a water
flowmeter and control and the dispenser distribution system along with a traditional pressure switch.
Water Inlet Valves -
The hot and cold water inlet valves are located at the back of the washer. These valves receive a control
signal from the Central Control Unit to manage the temperature of incoming water. The temperatures
are determined by the specific wash cycle selected and a temperature sensor located in the wash tub.
To improve cleaning of heavily soiled clothing and to provide a sanitizing feature, the water temperature
can be increased through the use of a heating element located in the bottom of the tub
Dec 25, 2009 | Maytag LAT3600A Top Load Washer
Water line keeps freezing.....
Probably the easiest possible solution might be to raise the freezer temperature a bit. If the freezer does not have a built-in thermometer that shows the temperature, get one and sit it inside the freezer. Wal-Mart should have these.
The temperature in a freezer should be around zero, plus or minus a few degrees. If the freezer shows a temperature significantly less than zero, you could certainly adjust the temperature control to raise the temperature a bit without causing any problem.
The water line runs outside the freezer for most of its run. However, it must come inside to reach the water dispenser. This short distance is where it would be susceptible to freezing.
Oct 20, 2009 | Hotpoint (HSM25IFTSA) Side by Side...
Water temperature from the water dispenser of our new refrigerator is equal to the environment temp.it is not cold at all.is it normal?the dispenser produces ice cubes but not cold water
Aug 29, 2009 | Samsung Refrigerators
FROZEN WATER FILTER - UNRELIABLE TEMPERATURES
About the dual water control valve the side that feeds the ice maker could be defective. Fill the ice maker with tap water and let freeze. If it dumps and does not refill the water control valve will need replaced. Here is a link to the water control valve.
WR57X10032 Water Control Valve
As far as the temperature control here is a link to the Temperature Control Here=>
WR55X10095 Temperature Board Encoder Below are some photos. If I can help answer any questions let me know, Sea Breeze appliancepartsse@yahoo.com 6b49f39.jpg053ba1a.jpg
Jul 28, 2009 | GE Profile Arctica Stainless Steel Top...
No water from water dispenser in Whirlpool et1fhtxmq03 refrig.
Most likely the water control valve on the back of the refrigerator. One side controls the water to ice maker and the other side sends water to the water dispenser. This is providing the water didn't freeze during the very low temperature setting set before you turned it back dow. If you can locate the model number I will be able to get the part number for the water control valve. There is a way to test it with an OHM meter, just let me know, Thanks, Sea Breeze
Jul 26, 2009 | Refrigerators
The water from my water dispenser isn't cold.
Hi, Only thing you can do is check the temperature in the fresh food section and it should read 34-27 degrees. The temperature controls should both be set at half of the #'s on the dial.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 05, 2009 | Whirlpool GD2SHGX Refrigerator
No water flow to ice maker
Two possible answers on this one. The water control valve for the ice maker is defective or the switches inside the front of ice maker are stuck.
Please send the model number listed for your refrigerator so I can help you find the ice maker switches and parts break down for your refrigerator. Below is my website address.
http://servicepartstec.blogspot.com/
Let me know if I can help you more, Thanks Sea Breeze
Mar 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dispenses without pushing lever
There is a solinoid valve that opens when you push the switch in. It has apparently failed and is leaking. Sometimes taking it apart and cleaning it will fix the problem.
Jan 28, 2008 | Kenmore 53542 / 53544 Side by Side...
Samsung RF4287HA Logo
274 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
