Question about Brother HL-3045CN Laser Printer
I have Brother HL-3045CN laser color printer and now my printer is printing documents with Toner scatter or toner stain Marks on papers. I means the prints are coming with blackish background. I changed the black toner but still blackish light marks are coming with every prints. OMER
JayBlair
  • 328 Answers
SOURCE: brother intellifax 4100 prints full page all black
Good chance the High voltage power supply is bad. Not worth repairing. A new unit costs about 259.00.
Posted on Aug 01, 2007
Soulvisitor
  • 1113 Answers
SOURCE: Marks on the page
More than likely it is drum, pull it out and see if marks are on it's surface, dont touch drum surface, normal user replacable part, can also be the fuser at rear thats a job for a tec
Posted on Jan 01, 2008
  • 2072 Answers
SOURCE: black mark on right side of paper
You either have some white out or some other dirt on the scanner or some sections of the scanner are bad. Open the area where your originals feed into, and look for about a 1/2 inch wide strip of glass, that is the scanner window. When that gets dirty, or fails, that causes the problem. Most likley dirty, some whiteout or ink on the scan window.
Posted on Mar 18, 2008
  • 215 Answers
SOURCE: change toner error brother 2820 mach has new brother toner ctg
with machine on, open front cover, press the "options" button, you should see "replace drum?" press the "start" key then 1 then 0. display should show accepted for a couple of secs. then show cover open. close front cover and message should be gone. if not, you will have to contact Brother.
hth,
razors
Posted on Jan 28, 2009
SOURCE: Dark smudges on paper from my Brother MFC4800
Need to replace your drum unit (DR250)
Posted on Feb 25, 2009
What are the steps to reset toner lights for Brother HL 2240
Try this Toner reset sequence (worked on Brother HL-5350DN)
With Printer off open the toner door
Hold the Go button as you turn the printer on.
All lights will turn on. Keep holding Go until status light goes off.
Press the Go button 2x.
The Paper, Drum & Toner light will come on
Press Go 6x
Status light will turn red
Close the front.
Jul 02, 2014 | Brother Hl2240d - Hl-2240d Laser Printer...
Brother 2170
there are a lot of reasons that causes spots on every copy.
these are some..
1. The drum is already old and has spots on it - replace
2. The toner cartridge is almost empty - replace
3. Damaged surface of hot roller. - replace
4. Toner scattering going to the paper tray. - clean
Feb 14, 2013 | Brother HL-2170W Laser Printer
Brother HL-4040CDN printer colors are off, tend to be pink
There could be a number of causes for the problems your describing, but one of the most common causes of discoloration and issues with toner is a faulty ribbon sensor. A broken sensor will be unable to accurately read the ribbon and apply the correct color. I hope this helps
Sep 02, 2012 | Brother HL-4040cdn Color Laser Printer...
There is a paper jam...how do I unjam it
Hi dorothyhover,
Here's how you would clear paper jam from your Brother HL 1430:
1. Remove the paper cassette completely from the printer.
2.
Pull any jammed paper up and out of the printer.
3.
Open the front cover and remove the drum unit assembly.
4. Pull any jammed paper up and out of the printer.
Do not remove the drum unit assembly with additional force at this time if you cannot remove it easily. Instead, pull the edge of the jammed paper from the paper cassette.
5. Open the rear cover and pull the paper towards the back of the printer, the fuser may get dirty with toner powder and may result in toner scatter on the next printed page or pages. Print a few copies of the test page until the toner scatter on the printed pages clears.
6. Close the rear cover and install drum unit assembly, close the front cover.
Hope it helps.
Thank you for using Fixya.
Apr 28, 2011 | Brother HL 1430 Laser Printer
Will not feed paper
Unplug the printer and wait half an hour. You want the internals of the printer to cool down, otherwise they might burn you.
Open the top of the printer, and remove the toner cartridge, there will be visual instructions printed on the top of the cartridge on how to remove it. Take care to place this on paper towels, as toner can be shaken loose and will stain anything it lands on.
You should be able to see a paper jam under where the toner cartridge, reach in and remove this jam.
After you've removed the jam, replace the toner cartridge and try printing again.
Mar 06, 2011 | Brother HL 2140 Laser Printer
Brother HL-5250DN Laser Printer TONER LIGHT ON & NO PRIN PAGE
When the toner light is on this means the toner is empty and needs to be replaced before it can print again. Replace the toner and you will be able to print again.
Jun 05, 2010 | Brother HL 5250DN Laser Printer
Printer not printing documents HL-2140 model
when the toner light is on this means the toner cartridge is empty and ned to be replaced. After its replaced it will start working normally again.
Jun 02, 2010 | Brother HL 2140 Laser Printer
My hl 5150D will not print. when isend document
1/ Check waste toner may need empty. 2/ You maybe out of toner. remove toner and give it a good shake will get a few more prints usually. Need more info from you. Have you check paper paths. Have you rebooted both printer and computer. Remember you must remove power supply on both for ten seconds for true reboot.. Good luck
Oct 10, 2009 | Brother HL 5150D Laser Printer
My Brother HL 5240 has Status toner, drum and paper lights on, I bought it on 4/30/08, new toner, plenty of paper, it showed on computer: printer is off line, but it was connected with computer. Really...
The drum light will flash on my brother HL-5240 Laser Printer when printing but it continues to print just fine. Does this mean the drum needs to be replaced?
Aug 07, 2008 | Office Equipment & Supplies
Brother HL-3045CN Laser Printer Logo
27 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
