Question about Bosch Washing Machines
Washing machine makes 'gravel' like sounds when draining water, as if there's something in it. Any help on troubleshooting what it might be? It still works but I wonder for how long. kind regards, Lena Hunter
  • paullenahunt May 08, 2009
    Thanks for the advice Kevin, will try looking into the pump, I downloaded the manual to make sure I don't pull the wrong parts.
    We'll try this tomorrow morning, I want some help from my husband before I break the machine completely :)
    Will keep you posted and if it works, I will accept your solution,
    thank you for your quick reply,
    kind regards,
    Lena Hunter
    Brigadier General:
  • 8,619 Answers
Hi
The sound is coming from the drain pump of the washer, it might have coin and/or debris stuck inside the pump which is making sound while the machine is draining. You'll need to open the back of the machine and will need to check for the same. Also remove the drain hose and clear the debris present.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on May 08, 2009
    Genius:
  • 1,847 Answers
It may well be one of the items you mention stuck inside the pump. Is there a filter on this washing machine? It could be behind a panel at the bottom. If you can't get to the pump through a filter, then you'd have to take the hoses off of the pump and have a look inside.
Unplug the machine and lay it over on its back or on the side opposite to the programme timer. You may need to disconnect the hoses too in order to lay it down.
Let me know if you need further assistance.
Kindly rate my solution.
Thanks.
Kevin
ANY IDEAS AS TO WHY MY MACHINE HAS STOPPED DRAINING? PLEASE
washing machines engage the drain pump at the beginning of a spin cycle
If there is still water in the tub after the spin then the pump is not working to pump the water out
I would check for something stuck in the impeller of the pump stopping it from spinning, burnt pump motor , no
power to the pump program board /relay, something blocking the inlet to the pump
Feb 10, 2016 | Washing Machines
Why is my washing machine not draining the water?
Hi Nick, it's probably because the drain is clogged or the drain pump is stuck or not operating. Basically there is a water draining system and something is stopping the water from going out. It helps a lot if you can post the make and model of the washing machine so a more detailed help can be provided.
Feb 09, 2016 | Washing Machines
Kenmore washer 80 series does not drain
When your washing machine won't drain, it could be as simple as a kinked hose or as complicated as a faulty impeller on the pump. Here are some steps to help you determine the problem and solution:
1. Pinched hose: Is the drain hose at the back of the washer been flattened or twisted in any area? A pinched hose could prevent the water from draining thoroughly. Gently straighten the hose, and make sure there is sufficient room between the back of the washing machine and the wall to prevent a repeat of the problem.
2. Clogged drain hose or pump: Does the drum spin normally, but the washing machine won't drain the water? Sometimes a piece of clothing, money, fabric or other debris gets into the water between the inner and outer tub. It may then make its way into a drain hose or even into the pump itself. The farther into the machinery a clog goes, the trickier it can be to remove. Call a repair professional for help.
3. Faulty timer: Does your machine fill with water and begin agitating, but the cycle never advances far enough to allow the water to drain? The timer that controls the cycles may be broken. Arrange for washing machine repair service.
4. Worn or loose belts: Are clothes still soaked at the end of a wash, even though the washing machine appears to go through the spin and drain cycles? The timer that controls the cycles may be broken. This is a job for the pros.
5. Faulty or jammed internal impeller on pump: When the spin cycle starts, do you hear a humming noise? The internal impeller that moves the water through the drain pump may be faulty or jammed. A grinding or grating sound is almost always an indication of a coin, button or other object colliding with the impeller. Have a washing machine repair expert determine if the impeller is jammed and can be cleared, or if the pump needs to be replaced.
6. Pump failure: Is your washing machine more than 7 years old? Your pump may simply have worn out. Even if it sounds as though it is running, the pump may not be working well enough to draw the water out of the machine. Replacement parts for pumps are generally unavailable. A new pump may be necessary.
For more troubleshooting steps, see Washing machine won't drain. I hope this helps!
Oct 08, 2012 | Washing Machines
Asko 620 washer won't drain well with heavy load
When your washing machine won't drain, it could be as simple as a kinked hose or as complicated as a faulty impeller on the pump. Overloading your washing machine can cause items to be swept into the space between the inner and outer tub, leading to clogs in the drain hose or pump. These clogs may be the reason for why your washing machine won't drain. Here are some steps to help you determine the problem and solution:
Oct 08, 2012 | Asko W6021 Front Load Washer
Whats wrong with our ge washing machine it keeps draining water,it is brand new just arrived.what do you think is the solutions to our problem. everything is being put together, we already install the...
make sure the drain hose is higher than the washer tub sounds dumb i know but if the drain hose is left lying on the floor going into a floor drain or something it will not fill up
Mar 23, 2011 | GE WBSR3140DW Top Load Washer
Bad pump??? Bought used and did a few loads OK but lots of sand/small gravel came out discharge. Fifth load would not drain basket. Error code said drain failure. Went to troubleshoot/diagnose mode and...
Is this a FAV6800A or FAV9800A machine? I would normally ask for clarification but I can’t post a pic with a clarification question. I’m an owner of a FAV6800A.
I assume the error code was “ND”.
Did you open up the pump housing to expose the impeller? Make sure it hasn’t broken loose from the motor shaft and is freewheeling.
Sounds like you have checked the Sump Cap for any clogs and drain hose to drain pump for a clog.
If your machine is not a FAV6800A or FAV9800A then please disregard my solution please don't vote on the solution.
This forum doesn’t require Machine Model Number or Serial Number which is a big mistake.....Rich
Jan 30, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My washing machine got to the spin cycle but didn't drain water
prolly cuz you didnt check your pockets first and either change or a set of keys fell out
Aug 15, 2009 | Washing Machines
Kenmore Washing Machine won't agitate, spin, or drain
It sounds like the motor needs to be replaced, you can drain the water by taking the drain hose from the drain and lowering down water will drain.
Jun 01, 2009 | Kenmore 24032\24036 Top Load Washer
MAV7000 clicking sounds in all cycles. sounds like a fan blade hitting an obstruction. noise volume decreases a bit when spin cycle occurs sounding like gravel. Spin locked up once. Strange metallic odor...
Sounds like there is an obstruction striking or rubbing against the impeller in the drain pump assy. It will require removing the front cover/ Drive belt from the bottom of unit/ Hoses from drain pump (be prepared for the water) a 3/8" socket to remove the pump & a needlenose plier to remove the obstruction... Hope this helps....Bill
Mar 04, 2009 | Maytag Atlantis MAV7000
Started a load of laundry water filled fine started washing and agitating and then heard a weird noise like something got stuck and went and it sounds like motor is running but will not agitate or spin and...
Please give a make and model of washing machine. I suspect that something has stripped out between the motor and the transmission, which is the noise you heard.
Jan 24, 2009 | Washing Machines
Washing Machines Logo
118 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
