Question about Pride Health & Beauty
Charging dicator lights dont light up on fortress 1700 mobility scooter
Charging indicator lights do not light up.
  • 23 Answers
SOURCE: electric mobility scooter says charge is full but won't run
This sounds she has tripped her circuit breaker. It works just like the one on your house, when you ask too much of it it suddenly goes 'pop' and seems to be dead.
Looks like you have the same scooter as mine, it should be a little white button on the back of the base. If you follow this link, it will give you a pdf version of the older model pride victory manual, (Mine is a three, they are up to about 10!) See fig. 8 on page 20 and 'Circuit Breaker' on page 21. Also, Page 33 has the troubleshooting info. Hope this helps.
http://www.rentascooter.com/downloads/_manuals/pridemobility/Pride%20Victory%20Owner's%20Manual.pdf
Posted on May 06, 2010
  • 177 Answers
SOURCE: 1700 Fortress Scooter won't go forward or
Hi. Has the machine been in regular use before the fault occured? You say that the brake is in brake release mode, this mode is only ever used if you need to push the scooter by hand. It releases the brake on the motor, and also operates a switch to disable the controller from driving the motor. It does this because it would be to dangerous to drive the scooter with the brake disabled.
Move the lever back to its correct position. If it still does not work, then the disable switch might be faulty, or it might be a different fault such as a stuck brush in the motor.
Is this machine produced by shoprider ( Phisang ) of Taiwan.
Please let me know how you get on. Neil.
Posted on Jun 08, 2010
mcdevito75
  • 1970 Answers
SOURCE: Battery full on Ascot Mobility scooter but wont start
mcdevito75 here, Double chek the connection at the battery and motor.
Posted on Jun 26, 2010
gewiz
  • 1263 Answers
SOURCE: my mobility scooter batteries are put on charge
hi, now that could be one of three problems,
1. first check the charger ,is it possible to try the charger on another scooter ?
2. The batteries will no longer accept a charge ,this creates a fault condition with the charger. (try these batteries on another scooter if possible).
3. the actual charger plug in, you need to check the pins here , just the outside ones with a electrical meter, no voltage implies a bad connection to the batteries.
Regards
GeWiz
Please rate this reply.
Posted on Dec 18, 2010
SOURCE: gogo elitescooter lights indicate battery fully charged but scooter will not go
Make sure the free-wheel lever is engaged and the charger is unplugged from the scooter before you try to turn the scooter on. If the battery gauge goes up when you turn the scooter on and there are no beeping sounds you should be good to go.If the battery gauge drops to the red when you try to accelerate slowly, your batteries are shot. (Typical replacement in 24-48 months).If there is any beeping when the key is first turned on then there is a problem and the number of beeps indicates the problem found by the computer during the POST. [Power On Self Test]
Posted on Jan 04, 2012
Put key in lights blink then go out
if they are brand new , never been used you could be right
but if they have seen service --not a factory priblem
Apr 09, 2016 | Health & Beauty
On the power bar first 2 bars flash and the scooter stops it is fortress 1700 ta.
Do you have the owner's manual to interpret the flash code?
It could be the batteries need replacing..the most common
problem with scooters.
Jan 24, 2015 | Health & Beauty
Scooter not charging when plugged into the charger
measure the voltage of the batteries thru the charging socket of the scooter, the outside 2 pins.
Sep 20, 2014 | Health & Beauty
Fortress scooter 1700
i need my stc sim pin number nuber is 0534298898
Jan 14, 2014 | Health & Beauty
When I turn on the vehicle the battery light indicates a full charge but the beeping sound will not stop and the vehicle will not go! It is a Fortress 1700.
The beeping indicates a failure of the motor.This is caused by either the brakes are seized or the controller for the motor has failed.
In the first case just remove the rear cover and , using a big flat screwdriver, just push the brake pads away from the disk. In the second case there is nothing you can do, you will have to contact the manufacturer - Handicare - or the dealer from which you have purchased it and find out which is the closest location that can service your scooter.
Jun 06, 2011 | Electric Mobility 4 Wheel Power Electric...
1700 Fortress Scooter won't go forward or backwards. The beeping is continual and the driving light comes on if you turn it on. The brake is in brake release mode. The battery is charged up? What is the...
Jun 07, 2010 | Electric Strider Maxi 4 Wheel Mobility...
Which indicator light on my mobil line battery charge complete
the green light should remain on when fully charged.
Regards
GeWiz.
Jan 11, 2009 | RTO Mobil Line Mobility Scooter Chair...
Health & Beauty Logo
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
