Question about Mr. Heater Heating & Cooling
Dewalt DXH185KT Turns off after a few minutes.
Why dewalt dc500 vaccum only works for a few seconds
It sounds like the batteries are at the end of their lifespan.
Jun 14, 2014 | Dewalt DC500 Canister Wet/Dry Vacuum
Why do i loose pressure after a few minutes
Quite often it means that your water supply is too small... not enough gallons / minute.
Jun 04, 2014 | Dewalt DPD3100 Gas Pressure Washer
My dewalt 18v xrp battery wont take a charge
Depending on how old or more to the point how many times you have already charged the battery, it may be worn out. All rechargeable batteries do reach a point where they won't charge up anymore. If you have fully discharged the battery and tried to fully charge it up again and it won't take a charge or only lasts a few minutes on a charge it may be time to recycle it and buy a new one.
Aug 22, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt radio channels are locked
I took out the rechargeable battery and the 2 aa batteries for a few minutes this reset everything and it works fine.
Dec 20, 2009 | Dewalt Audio Players & Recorders
Dewalt 18v nicd battery not holding any charge! what can i do
if it is under warranty ,take it back .if it isnot then bite the bullet and buy a new battery ----try TOOLKING
Nov 02, 2009 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
My dewalt dw 402 grinder, starts fine, runs for a few minutes and then shuts down. Brushes appear to be fine.
Pull it apart and clean the armature, you will find something between the brush contacts getting larger and making contact thus shorting it out, so clean the armature with fine point object do not gouge the material out of the area between the copper plates. Also blow out any metal dust you may see.
Jul 31, 2009 | Dewalt Small Angle Grinder 4 1/2"
Dewalt chop saw blows breaker after a few minutes of use. Bearings bushes and armature ae good. Is the gear box dragging so much that it powers off and blows the circuit breaker? Where in San Antonio,...
You can register with Dewalt ServiceNet(www.dewaltservicenet.com) and order parts direct on-line. In San Antonio Tx there is a local source located at 500 Culebra Ave San Antonio Tx 78201 ph#210-732-1221. The service net also provide exploded parts view of your machine which is very helpfull.You may have warranty an this machine in the event of any factory defect associated with this machine which can be determined on the service net....good luck
Jul 28, 2009 | Dewalt Chop Saw D28700
Why does my drill run hot
Maybe ur drill is not heavy duty type.You need to rewind the motor,but if i were you buy a new one.YOu may use the old one but its good for few minutes after using it.
May 19, 2009 | Dewalt 18v 1/2" Compact Drill/driver Kit...
Heating & Cooling Logo
112 people viewed this question
Top Mr. Heater Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Mack Baxter
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
