Question about LG WD-16115FD Front Load Washer
LG Intellowasher 7.2kg WD80130F
My washing machine washes the clothes, spin and then stop and the "pre- wash" and "time save" lights start to flicker.  The only way to let it work again is to switch it off and start the whole program from the beginning. Most of the time I have to do that several times.
Can it be a computer panel problem and if it is so, do I have to replace the whole panel?
  • Anonymous Nov 15, 2007
    I have the same problem - cleaned the drain filter, still no good. All pipes are straight, no kinks.
    Eventually found a coin inside the pump - tilted the machine with the drain filter out, programmed it to Pump, and it eventually spat the coin out!
    Washed OK 2 times after that - now it's screwed again!!!
  • palsefan Mar 22, 2008
    same problem
Where is the drain filter located
Posted on Mar 11, 2008
We had same fault a Henrihet.
We have now changed drain pump moter. All ok now.
Posted on Sep 10, 2008
Have the same problem - cleaned the drain filter, still no good. All pipes are straight, no kinks.
Posted on Apr 06, 2009
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
My washing machine AEG lavamat 86800 (1998) blinks C9 and says no centrifuging and pre-wash. Thank you J.
1) Hold in the Pre-wash & soaking buttons TOGETHER;
2) At the same time, turn the knob clockwise from the OFF position, to "Short Spin". All the LEDS light up.
3) turn the knob anti-clockwise to "energy saving"
4) Machine is reset and the door release clicks.
Switch your machine off and then back on again.
Jan 17, 2011 | AEG Washing Machines
Spin mode does not work
Dear "FixYa,"
I have fixed the problem with my washer.
I started clothes washing machine with one load of clothes.
Wash and rinse process completed, as it came to spin,
Machine stop, only I heard was running motor. I opened
machine and found coupler is cracked (broken) and was
unable to rotate the gear.
I replaced new coupler and machine started to work normal.
Thank you
Kanu
Apr 18, 2009 | Whirlpool Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Not fnishing wash cycle!
Erratic behaviour in wash programmes can often be due to clogging of the path between the tub and the pressure sensor which senses the water level in the tub. Clogging can result in water level being incorrectly detected (may read as too high or too low) for the stage of programme that is executing, which can result in a halt of the programme.
Jan 04, 2008 | Washing Machines
Pre wash not happening
poss blocked filter which also controls your pressure system, on your machine I believe if the prewash ligbt is flashing it would indicate a blockage there
Jun 13, 2007 | Hotpoint WMA46 Front Load Washer
LG WD-16115FD Front Load Washer Logo
2,880 people viewed this question
Top LG Washing Machines Experts
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
