Question about Apple iPod classic MP3 Player
My ipod wont work. when plug in both computer or wall dock, it just keeps blinking and resets constantly. nothing will work.
  • 342 Answers
Try resetting it on purpose. If that does not resolve the issue, you will need to attempt to put the ipod into disc mode for restoring in itunes. Below I have posted step by steps on all three trouble shooting steps. If your issue is not resolved after working them please do let me know. :)
Last Modified: January 28, 2009 Article: HT1320 Old Article: 61705 Summary Learn how to reset or restart iPod following a freeze.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on. ----------------------------
Putting ipod into disc mode http://support.apple.com/kb/HT1363 Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.) Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect" If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
-------------------------- PC and mac How to restore iPod (ARTICLE NUMBER HT1339)
Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
After a few moments, your iPod will appear in the Source panel in iTunes.
Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software.
The 4 possible restore options are: Restore Option
1: Restore - Restores with same iPod Software version already on iPod. Restore Option
2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available. Restore Option
3: Use Newest Version - Restores with the latest iPod Software available. Restore Option
4: Restore and Update - Restores with the latest iPod Software available.
If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
A progress bar will appear on the computer screen indicating that the first stage of the restore process has started.
When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Posted on May 08, 2009
The ipod will not charge nor work when docked, yet the radio works. The ipod will charge on a computer or wall charger. what's wrong with the docking part?
I just tried calling the company....what a joke that was...anyway, there is a reset button on the bottom of the radio.....you can press the reset button with something like a paperclip. This should reset your settings and hopefully start to charge the iPod while docked.
Aug 21, 2010 | Digital Products International Clok Smooth...
Ipod dock won't play music when ipod hoocked up. just blinks searching for ipod, finds nothing then shuts off
Try taking out all the outlets of the dock, and wait like a minute then plug it back in. Or click the reset button if it has one
Feb 02, 2010 | RCA RC65I iPod and iPhone 3G Docking Clock...
Ihome won't play ipod, even after resetting ipod I have de same problem. I got an itouch 2nd generation and docked it on a speaker that supports it. It worked fine for two or three hours, but suddenly it...
Welcome to the wonderful world of the iHome frying the Ipod.
Your iHome, has most likely fried the mainboard on your ipod.
to check plug a usb into the ipod and connect to the computer.
if it comes up disconnect the usb and try a headphones in the jack.
if it doesn;t play sound its fried and you will need a new mainboard.
if it does play through the headphone jack, your lucky and keep it off the dock.
I have fixed at least 30 ipods taken out by ihome docks and other docks.
they are terrible for the ipod. Even Apple sells the docks on their website
that shows how much they care about the product.
If this helps leave a vote on fixya
May 11, 2009 | Apple iPod touch
My ipod nano wont do anything
Try this
http://www.fixya.com/support/r561901-ipod_problems_start_5_solutions
if noting helps, see the bottom of the page for service information.
May 06, 2008 | Apple iPod nano
Ipod nano blinks
I bought an Ipod shuffle 2nd generation yesterday, it charged all night and orange light was still blinking. Tried listening to songs and sometimes it would play but most times wouldn't. Took it back for exchange and same problem. Then I realized the problem is not with the USB plug or computer reoconizing ipod but in the docking itself. I applied pressure on the top side of docked Ipod and bottom of docking station and the computer recognized the Ipod. Release pressure and lose connection. The problem is that the docking station and earbuds do not connect with ipod and the fixes provided by apple doesn't address or fix this problem.
Nov 21, 2007 | Apple iPod shuffle Second Gen. Silver (1...
Dock Connector Charging Problem
I had that problem one time and the only way to get rid of that icon was to plug it into my Bose sound dock. You could also try another brand of sound dock to see if it works. Good luck
Nov 11, 2007 | Audio Players & Recorders
IPOD SHUFFLE NOT RECOGNIZED
I had the same problem where my shuffle just turned off as if it ran out of battery power, and when i tried to plug it in the computer it wouldnt recognise it or i would get an unknow device error. I tried many of the 5r as much as i could but didnt work. Then finally yesterday i tried something new. I pluged the ipod into the computer and left it pluged in to the usb port and i noticed that every time i would lift the ipod from the dock (not all the way) that the light would blink green one time. So what i did was i positioned the ipod back on the dock then lifted it until the green light blinked and i turned it on, and it works now, the battery is charged. However i havent tried to plug it back in the computer to see what happens but i can listen to my music now.
Nov 07, 2007 | Apple iPod shuffle Second Gen. Silver (1...
Apple iPod classic MP3 Player Logo
189 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
